Swapping 2012 Entune Subwoofer for ED e3.8
Discussion in 'Audio & Video' started by jstarko0329, May 3, 2012.
  1. May 3, 2012 at 1:30 PM
    jstarko0329
    jstarko0329 [OP] New Member
    Seeing that the elemental designs e3.8 is a great performing subwoofer, I had the idea of trying to swap the current JBL subwoofer that comes in the Entune package (double cab) for the e3.8. It would be great to use the same enclosure and the factory amp for a quick, small, and cheap upgrade that might not need modification to any of the factory material.
    I'm happy with the Entune package as a whole, but I find the quality of the sub to be the weakest link, so I'm curious to see how this would work.
    Has anyone tried this? Or, does anyone have access to the entune subwoofer/amp enclosure to take some measurements and see if the e3.8 would fit without heavy modification? Specifically, it would depend on the cutout diameter and the mounting depth. I'm willing to be the guinea pig if someone can take some quick measurements for me.
    The e3.8 is as follows:
    Magnet Width: 4.800"
    Cutout Diameter: 7.250"
    Mounting Depth: 4.375"
    Weight: 10lb
    Total Height: 4.900"
    Displacement: .05 ft³
    Outside Diameter: 8.375"
  2. May 15, 2012 at 8:58 AM
    TruckyTruck
    TruckyTruck Well-Known Member
    Tundra Crewmax TSS Off-Road 4x4, sr5/leather
    If feel the same way about the subwoofer and would like to do this as well. Do you notice a distortion when you are using the Bluetooth? Like a fuzzy sound in the tweeters when the person is talking. Other than those two things, this is the best factory sound system I've had so far.
  3. Oct 4, 2012 at 10:37 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    I do not know of anyone that has swapped out subs but I want to do this as well. I am tempted to buy someone's OEM enclosure and swap subs in that as opposed to tearing into mine.
  4. Oct 4, 2012 at 6:24 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    You can't just swap it out, and if you did, it will sound absolutely no different. There is hardly any power driving the sub in that amp. You gotta get rid or wire it seperately.
  5. Oct 5, 2012 at 4:02 AM
    dexterdog
    Oly WA
    2012 F150
    Sub swaps in 8th gen Accords were an improvement and there was not alot of wattage being pushed through the OEM sub. The key is picking the right sub. I think there would be an improvement.
  6. Oct 5, 2012 at 9:13 AM
    brian
    Elizabeth City, NC
    IF you could, lets just say its more work than its worth. You're just polishing a turd in the end.
    Which reminds me of my first upgrade to my JBL system. OP, look into a new head unit. A new head unit will give you more control over the bass, instead of flattening the EQ curve like the stock head unit will.
  7. Oct 5, 2012 at 9:25 AM
    Shauncho
    Shauncho Embrace your inner Bro-ness
    Shaun
    Thousand Oaks, CA
    '13 DCLB TRDSport PreRunner & '99 4Runner 4x4
    Tailgate Anti-theft Anytime Foglights Removed/Relocated Badges BHLM Window tint Goodyear Duratracs Satoshi Grill from Customcargrills.com
    really, I'd be happy if the factory sub had an eq and separate volume control without having to turn the bass down on the HU eq.
  8. Oct 5, 2012 at 11:14 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    45 watts per coil is 90 watts total. That's plenty of power as long as you know what you're doing.
    Truth be told, you need to get a more efficient speaker to make use of the limited power. I would guess the stock sub has some decent efficiency but it isn't all that high. The ed 3.8 is a great sub (I run two of them) but it's not terribly efficient. It could very well be a step back because you'll run out of power before you'll run out of woofer xmax (cone throw).
    Something like a guitar bass cab speaker would be best. Crazy efficient and will JAM on 90 watts. Problem is the FS wont be very low and the enclosure might need to be bigger than it is currently. I'd suggest stuffing the enclosure with poly fill.
  9. Oct 5, 2012 at 11:21 AM
    ItalynStylion
    Steven
    DFW, Tx.
  10. Oct 5, 2012 at 11:28 AM
    brian
    Elizabeth City, NC
  11. Oct 5, 2012 at 11:47 AM
    ItalynStylion
    Steven
    DFW, Tx.
    3.625" is very very shallow. I doubt the stock sub is any shallower than that. I'm not basing that off experience with the stock sub but rather knowledge of speakers in general. I'd be interested to test the stock driver and find out what it's TS parameters are.
