Swapping an 06 4runner engine for my 06 tacoma engine
Discussion in '2nd Gen. Tacomas (2005-2015)' started by shamfrog67, Oct 27, 2016.
  1. Oct 27, 2016 at 8:18 PM
    shamfrog67
    shamfrog67 [OP] Member
    todd
    Woodstock-Ga
    06 PreRunner SR5
    Okay... I'm one of the unlucky sods who's head gasket failed in my 06 Taco. Can't afford a head gasket job. Found an 06 4runner being parted out. Price is very fair (favor through a friend) so far all I know is I will have to swap oil pans. I can't really find much info out there about doing the install. It has been over 30 yrs since I did an engine swap in a car. So I'm a bit rusty, and this will be way more invved.... Any advice/tips would be greatly appreciated. Thanks to all in advance.
  2. Oct 27, 2016 at 8:26 PM
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    The only guy I would trust answering that question is @Torspd . I think you would need the computer also, but I'm not sure. Good luck.
    Torspd and 08tacobear like this.
  3. Oct 27, 2016 at 8:34 PM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    You can swap an engine but not change a head gasket by yourself? Don't get me wrong I'm down with it, but is it really cheaper to buy the engine, adapt it, and put it in than it is to buy a new head gasket and put it in yourself?
    08tacobear likes this.
  4. Oct 27, 2016 at 9:19 PM
    08tacobear
    08tacobear Well-Known Member
    08 taco DCSB pre runner V-6 SR5
    12v accessory plug right rear bed bin,1gallon air compressor setup in left rear bed bin, 3-window bed topper.
    I was wondering the same But I took a step further and just assumed he meant "he was one of those unlucky sods whose head gasket failed.....[and probably cause a catastrophic failure and internal damage and gummed up stuff so bad it is easier to just swap]". and maybe this is a 4 to 6 conversion but OP didn't state too much other detail.
  5. Oct 28, 2016 at 5:58 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    An engine swap is much easier and less technical that the head gasket swap. If this were a push-rod engine, the head gasket swap would be easier.
    The swap from the '06 4Runner will be a direct swap. Un-bolt, re-bolt, fill with fluids and drive.
    If it were an '03-'04 4Runner, it would be a much more indepth process.
    Just make sure you know the quality of the engine. It still fall in line with that year model having a head gasket weakness issue. As long as it has good compression, oil has been changed regularly, it will be good to go.
    T4RFTMFW and Tyler07 like this.
  6. Oct 28, 2016 at 1:50 PM
    shamfrog67
    todd
    Woodstock-Ga
    06 PreRunner SR5
    Torspd, you're correct about the head gasket replacement vs engine replacement. My biggest question.... is there any external parts I will need to swap ? Or is it going to be basically, a DROP in, plug in all the electronics and hook up all the other hoses and connections.
    Oh I will be taking a handheld to plug into the diagnostic port under the dash..the engine runs, 130k miles, just in a wrecked vehicle
  7. Oct 28, 2016 at 2:44 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It is drop in, and bolt to your attachments. I.E. radiator and electrical connections. The only thing that might be different are the engine mounts.
    The only differences between the '03-'04 4Runner 1GR and your '06 Tacoma 1GR, are the intake cam gears, and their sensors. There is a thread which I have gone into great detail on that topic.
    Yours in an '06 4Runner, you say, so their won't be any difference between any parts. Minus what I mentioned earlier.
    Nickel and MrCrowntown like this.
  8. Nov 2, 2016 at 7:37 PM
    shamfrog67
    todd
    Woodstock-Ga
    06 PreRunner SR5
    What about all the other accessories??? power steering, a/c, etc.... I'm thinking.it will be easier to remove from my engine and then reattach to "new" engine when it's bolted in.
  9. Nov 2, 2016 at 8:41 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    As I said before. It all bolts up. Everything. Plug n play. ALL OF IT!
