Swapping coils to 5100s- what coil compressor is everyone using(rent)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DougSD, Feb 16, 2018.
  1. Feb 16, 2018 at 3:29 PM
    DougSD
    DougSD [OP] Well-Known Member
    Doug
    San Diego, CA
    2015 TRD Tacoma
    Icon front 2.5 Coilovers, Fox 2.0 rear shocks, Hankook A/T tires
    Im going to swap stock coils over to my 5100s this weekend I've never had good luck with rental coil spring compressors as they are always jacked up when you get them from (O'reillys, Auto-zone, etc)
    What is the brands most folks are using? I have no need to buy any since this is a once in every 10 yrs deal but is one style better then another (opening length etc)?
    thanks!
  2. Feb 16, 2018 at 3:34 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    none.
    un-bolt the lower ball joint from the spindle (2 big bolts). Mark the LCA to frame cam bolts. Loosen them, then drop the lca down with a floor jack. Easy MUCH SAFER and quicker than a spring compressor.
    Sandman614 likes this.
  3. Feb 16, 2018 at 3:35 PM
    presta24
    presta24 Well-Known Member
    chris
    Cincinnati
    2014 Taco TRD 6spd, 2k3 SR5 4runner V8
    Scratches, dents, lots of squeaks.
    I have always used advance Auto. Be to be honest. If you can swing it, find a local shop to swap them. For me, I've swapped springs on my truck 3x, $50 is well worth the headache of doing it yourself. If not, it can be done, just a pita
  4. Feb 16, 2018 at 3:37 PM
    presta24
    chris
    Cincinnati
    This way does work and I've used it too. But just depending on how everything lines back up it can be defficault to get the top stem through the top hat and all the isolaters with enough threads to tighten the top nut down
  5. Feb 16, 2018 at 4:15 PM
    nd4spdbh
    SoCal
    Just keep compressing the LCA / strut assembly with the floor jack to push the stem up through and call it good.
    tcjacado likes this.
  6. Feb 16, 2018 at 4:20 PM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    This is slightly off topic, but this didn't work when I put 887s on my 5100s. The floor jack started to just lift the truck. Had to use one of those hook type deals.
  7. Feb 16, 2018 at 4:37 PM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    I tried this method the first time I put on 5100s and it wouldn’t work because my LCAd were seized. So as long as your LCA bushings aren’t seized then this is a better way to do it.
  8. Feb 16, 2018 at 6:06 PM
    nd4spdbh
    SoCal
    ah yeah 887's are pretty long n stiff i could see that happening.
    Didnt have any issue with my stock TRD OR coils.
  9. Feb 16, 2018 at 8:25 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Spring compressors are known as widow makers in auto shops. A proper strut tamer is best used that is mounted to a stand and has clamps to secure the spring so it doesn't fly out like a 9mm bullet.
  10. Feb 16, 2018 at 8:42 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    This is the safe way. I’ve used this many times. Super simple and easy. Here’s a video.
    https://m.youtube.com/watch?v=vkVLBOnAifc
  11. Feb 17, 2018 at 11:40 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Why do you have too loosen the LCA cam bolts to do this ?
  12. Feb 17, 2018 at 12:37 PM
    moondeath
    Pa, Gardners
    So the lower control arm can swing down and out of the way.
  13. Feb 17, 2018 at 12:41 PM
    nd4spdbh
    SoCal
    to add to this. The stock LCA bushings are a bonded rubber type of bushing. That is the inner and outer metal sections are glued to the center rubber piece so it can not freely rotate.
    This also brings up the point.
    DO NOT TIGHTEN THE LCA BUSHING BOLTS / LOWER SHOCK MOUNT UNTIL VEHICLE IS AT RIDE HEIGHT!!!! these 3 spots are all bonded rubber bushings and will tear if you tighten them at full droop.
    REDdawn6 likes this.
  14. Feb 17, 2018 at 12:45 PM
    lynlan1819
    Tacoma
    Lifted
    Got it,Thank's
  15. Mar 27, 2018 at 5:18 AM
    Glasskenny
    Glasskenny Well-Known Member
    Kyle
    2016 Inferno TRD Offroad
    I attempted the jack method on my passenger side last night. Decompressing worked great, new assembly install is giving some difficulties. I've got OME 888 coils on the 5100s but as I lifted the top of the strut would mis-align more with every pump of the Jack. The strut pivoted pretty freely with little pressure from the jack but after a few pumps I could not direct it through the top hat anymore. The 888 coils may be too stiff for this method but I do not know why the strut does not pivot more, the guys in the video below seem to not have much of an issue aligning the strut as the spring compresses. Any ideas on why this may be?
    https://youtu.be/jo0FJSi-KYs
  16. Mar 27, 2018 at 9:26 AM
    Taco4Life89
    Taco4Life89 Well-Known Member
    NM
    2015 DCSB TRD OR 4x4 6 SPEED
    I took mine to a local shop and had them do it for $20 each side. Easier than using one of those sketchy spring compressors you rent from autozone. I can never get them to compress right.
