Swapping from 16" to 17" wheels?...
Discussion in 'Wheels & Tires' started by Larry, Aug 29, 2010.
  1. Aug 29, 2010 at 4:40 PM
    Larry
    Larry [OP] CARL
    CARL
    Does this set the truck up a little?
    Also, if I change out the 245's on my 16" steelies to 265's does that raise the stance a bit?
    And if I went to 17" wheels with 265's...again...this sets my truck up even more from the 245's...or the 265's on the 16"ers?
    Point is: I'm not looking to build a rock climber or mudder...but I'd like to give the stance more of a truck look and less of an SUV stance.
    TIA...as always.
  2. Aug 29, 2010 at 4:42 PM
    Bobo_1
    Bobo_1 Well-Known Member
    Bobo
    Maryville, TN
    09 TRD Sport L-Bed
    You need to be using a tire calculator. This one will answer most of your questions except stance which is probably more subjective.
  3. Aug 29, 2010 at 4:51 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I went from the 245 series 16" baja wheels to 265/65 R17 on sport wheels. They're extremely close in overall height but quite a bit wider. In my opinion, they look a lot better than the original 245's.
