Swapping front seat cushions and covers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by N919HJ, Mar 6, 2021.
  1. Mar 6, 2021 at 7:32 AM
    N919HJ
    N919HJ [OP] Well-Known Member
    Ohio
    2007 Double Cab TRD OR
    My Tacoma’s drivers seat is starting to show some where and is not as comfortable as it use to be. Before I start taking things apart, I was wondering if anyone has ever tried this. I would like to swap my front seat bottom cushion and cover with the passenger side. It looks pretty easy. Google wasn’t very helpful.
    PzTank and 478DblSport like this.
  2. Mar 6, 2021 at 1:55 PM
    Bashby
    Bashby Active Member
    That’s not a bad idea, I don’t see why it wouldn’t work. I’ve r&red a few seat covers before but never on a Tacoma. It’s a pain to get the cover back on just right but if you don’t get in a hurry you can probably figure it out.
    N919HJ[OP] likes this.
  3. Mar 6, 2021 at 2:52 PM
    N919HJ
    Ohio
    Unless I get a definitive “no it won’t work”. I think I’m going to try it when it gets a little warmer around here.
  4. Mar 6, 2021 at 3:02 PM
    478DblSport
    478DblSport Thermonuclear Protection
    Byron, GA
    07 Silver Streak Mica PreRunner DC TRD Sport
    | EXTERIOR | DiamondBack SE Tonneau Cover, Havoc HS2 Hoop Steps, Tailgate Hose Clamp Mod, Shortened OEM Antenna, DeeZee Bed Mat | INTERIOR | Flyzeye V2W (Amber/White/Amber), RAM Mt A-Pillar Mod, Audio: Pioneer AVH-X5700, PDX-5 (119Wx4+410W), Polk Audio MM6501 (F) & MM651 (R), JL Audio CP108LG-W3v3 (Sub), w/Monster, Rockford, & Streetwire cabling, Metra Dash Kit.
    Wow hadn't considered that... of course my wife probably wouldn't be too happy. Very interested if it'll work.
  5. Mar 7, 2021 at 3:35 AM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    When I installed my seat heaters The seat covers are easy to work with. your going to need a good pair of side cutters to cut through the hog rings take your time and it can be done. Wait till you get a nice warmer day and the sun will help relax the fabric
    PzTank and N919HJ[OP] like this.
  6. Mar 7, 2021 at 5:10 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    When I modified my driver's side seat foam, I didn't cut my rings, just pried them open with a needle nose pliers. If you're moving the foam and covers, you should be able to move them without taking the cover all the way off the foam. I just don't know if they are shaped the same, side to side.
  7. Mar 8, 2021 at 5:10 AM
    N919HJ
    Ohio
    That’s good new’s. It sounds like this project just keeps getting easier and easier!
  8. Mar 8, 2021 at 5:18 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I did it in a 1st gen, didn't think it was possible to do in a 2nd gen due to all the electro gizmos and airbag nonsense but if it's possible I would like to know also.
  9. Mar 8, 2021 at 5:27 AM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Someone with access to the parts breakdown would be lovely to have here, so at least you know which parts Toyota thinks are interchangeable between the seats. Surely there are some YT videos out there of people doing various jobs on those seats so you can see for yourself what’s involved, what the guts look like, etc.
    At that point you could also consider what parts, if any, you could just get from a junkyard vehicle so you can do more remove and replace than swap. Maybe you’re trying to do this as all labor and no parts cost though which I get.
  10. Mar 8, 2021 at 5:45 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'm poking around and can't find the correct part number for the drivers lower pad, but the ones I can find are all around $120 at McGeorge Toyota. Not sure if you're looking to spend anything but it may be worth it to buy new becuase you know it'll fit and you know it'll last longer. Plus less work since you're only taking apart one seat. If you call McGeorge parts, they're really helpful at finding the correct part number.
    here’s a pad for the rear seat. Just an example of the nomenclature and price
    https://parts.mcgeorgetoyota.com/oe...60?c=bT0xJmw9MSZuPVJlY29tbWVuZGVkIFByb2R1Y3Rz
  11. Mar 8, 2021 at 11:55 AM
    boulderbean
    boulderbean Active Member
  12. May 12, 2025 at 2:02 PM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Vintage thread, but I looked into this swap a while back. It looks like a nightmare. The only vid I found on YouTube is sketchy with the dude mumbling to himself half the time. I think I'm gonna roll with a nice seat pad or covers instead before it wears out too badly.
  13. May 12, 2025 at 2:39 PM
    N919HJ
    Ohio
    I took my seats out last summer to have look. To me and the time I had to mess with it. It was just too big of a PIA. Good luck if you try it. Post up some pictures too if you think about.
