Swapping lca with a fabtech lift kit installed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Squidlipz, Sep 8, 2020.
  1. Sep 8, 2020 at 1:37 PM
    Squidlipz
    Squidlipz [OP] Member
    2007 Tacoma 4x4 Xtra Cab
    6" Fabtech lift running 33" Nitto Trail Grapplers
    Aloha everybody, kinda new to starting treads on the forums, and I couldn't find any threads about it, but I was just curious if anybody has swapped out the LCAs on their 2nd gen Tacoma that already has a 6" Fabtech lift kit? It looks like I'm going to have to separate the wheel bearing hub from the CV axle to make room to pop the LCA ball joint out. Any info would be appreciated.
    Aloha,
    Squidlipz
  2. Sep 8, 2020 at 1:53 PM
    reg0928
    reg0928 Well-Known Member
    Ross
    Crestone, Colorado
    05 TRD OR Access Cab
    3"OME, 255/85R16
    yeah I had to take the CV out of the hub when i did lower ball joints
    Squidlipz[OP] likes this.
  3. Sep 8, 2020 at 2:10 PM
    Squidlipz
    That's what I thought, thanks for your reply.
  4. Sep 8, 2020 at 2:12 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Does fabtech have different LCAs than stock?
  5. Sep 8, 2020 at 2:17 PM
    reg0928
    Ross
    Crestone, Colorado
    3"OME, 255/85R16
    No, different spindles
  6. Sep 8, 2020 at 3:14 PM
    Squidlipz
    The kit uses the stock LCAs but uses their custom spindles like reg0928 said. Makes it more difficult to pop the ball joint because the CV axle is in the way. It's going to be a mission to do, but my LCA bushings are toast and need replacement. It has caused my CV axle to fail twice already when 4wheeling. Not fun.
  7. Nov 30, 2021 at 7:00 PM
    Surftout21
    Surftout21 Member
    Bobby
    808
    2014 TRD 4x4 6” Fabtech Fox Dsc
    I need to replace my cv axels on my truck. I was wondering, do I need to disconnect lower control arm ball joint to spindle?
  8. Nov 30, 2021 at 7:08 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Yes
