swapping reg for syn oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cdnbanker, Jul 9, 2009.
  1. Jul 9, 2009 at 10:08 AM
    cdnbanker
    cdnbanker [OP] Well-Known Member
    is there any special process to changing the oil from standard to syn?
  2. Jul 9, 2009 at 10:12 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Nope.
  3. Jul 9, 2009 at 10:12 AM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
  4. Jul 9, 2009 at 11:54 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    X2
  5. Jul 9, 2009 at 11:54 AM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    Sold my truck Jan '13... Still hang around.
    X2... drain oil, replace filter, fill oil.
  6. Jul 9, 2009 at 11:56 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Drain, install new oem filter, replace drain plug washer and refill with your brand of syn. oil, I used Mobil1.
  7. Jul 9, 2009 at 1:03 PM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    I've read on bobistheoilguy.com that if your car has high mileage, 75K and over it would be a bad idea to change over to a synthetic. The reason being is that synthetics contain a larger amount of detergents. These detergents would eat away deposits causing your rings and seals to become loose that had settled over time; therefore causing your car to burn/use more oil than normal. Early on in an engine's life there should be no problem.
  8. Jul 9, 2009 at 2:52 PM
    URBIKESUCKS
    URBIKESUCKS Well-Known Member
    Ron
    Prescott AZ
    2014 DCSB TRD OFF ROAD 8speed auto from a lexus
    Habitat
    No special way just replace as you would your dino.
  9. Jul 9, 2009 at 3:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    False. It would be foolhardy for lubricant manufacturers to build a product that is incompatible with seals. The composition of seals presents problems that both petroleum oils and synthetics must overcome. Made from elastomers, seals are inherently difficult to standardize.
    Ultimately it is the additive mix in the oil that counts. Additives to control seal swell, shrinkage and hardening are required, whether it be a synthetic or petroleum product that is being produced.
    http://www.oilsandlube.com/myths.htm
  10. Jul 9, 2009 at 3:27 PM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    Further explanation....
    Additives to control swelling, shrinkage and hardening are required,
    is this a Valley of the Sun thing?
  11. Jul 9, 2009 at 3:37 PM
    Janster
    Jandy
    Lancaster, PA
    That might be somewhat true but not to that extreme as you make it sound.
    The amount of buildup in an engine that old - would not be cleared/cleaned away that quickly. Synthetics DO CLEANSE but not fast enough to remove 75k miles (years & years) of buildup.
    I started using synthetics in my 96 tacoma @ 60K miles and ran it until I sold it at 110k miles. Surely, it burned 1/2 quart in 4,000 miles - but guess what? I sold that truck 5 years ago with 110k miles. It's still running around town, so obviously....after 13 years.... the synthetic surely didn't hurt anything.
  12. Jul 9, 2009 at 3:38 PM
    steviestyles
    Colorado Springs
    Bone Stock
    I don't think from what I read over at BOIG claims that synth damages seals, it's more so that the synth oil removes carbon deposits and sludge out of an older engine; therefore breaking the artificial seal these deposits provided. Because of this, the engine consumes more oil. It's similiar to the claims of using high mileage oils with sealants for your engine's rings and seals and going back to regular oil. The seals will begin to break down? There was a lot of debate of this over on BOIG. If your well on your way to 100K i don't see at that point to switch over to synth...stick with the dino.
    http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1520302&nt=1&fpart=2
  13. Jul 9, 2009 at 3:40 PM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Does it come in a 6 pack?...
  14. Jul 9, 2009 at 3:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats an old debate, and the end is that if you have that much crap in your engine, its gonna die soon regardless of what oil is in it. Its been proven that switching to synthetic oils any time has no ill affects ont he engine. If it did, there would have to be warnings placed on the bottles saying "Not for use in High Milage engines", or whatever.
  15. Jul 9, 2009 at 5:12 PM
    steviestyles
    Colorado Springs
    Bone Stock
    If you read over the link I attached...I think the consensus is that Synthetic itself won't ruin an engine, but instead show the flaws of your ill maintained engine. Again I'm not debating for or against the use of synthetic oil. Some people benefit from synthetic oil, some will never utilize the full potential of a synthetic oil. I think with Toyota's 5K change interval, most users don't need synthetic unless you tow or off-road, or live somewhere where the weather is extreme. I will have to disagree with you on how quickly a synthetic removes sludges and carbon buildup. If you believe the synthetic oil claims, most remove carbon and sludge within 1 oil change.....that's pretty quick.
  16. Jul 9, 2009 at 5:25 PM
    Phillyguy
    Phillyguy Member
    Philadelphia
    09 DC 4x4 SR5
    Still brand new.
    Just recently came across this. I had a truck with 130k on it that was not maintained well (owner before me). It was running standard oil and had very little oil leaks. Once I switched to sythentic, about 2000 miles in I started noticing more and more leaks.
    Further investigation, it seemed the sythentic loosened up all the "self-healing artificial" seals the engine had build up over the years. So to the point of the previous post, it didnt hurt the engine, but exploited all the real problems with it.
    Don't think synthetic will hurt at all, infact most likely help your engine... but its possible some forgotten issues or self-healed cracks you were unaware of may surface.
    Could be a blessing in disguise to get things fixed before its too late!
  17. Jul 9, 2009 at 6:43 PM
    steviestyles
    Colorado Springs
    Bone Stock
  18. Jul 9, 2009 at 6:55 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    x2 :thumbsup:
  19. Jul 9, 2009 at 7:15 PM
    Phillyguy
    Phillyguy Member
    Philadelphia
    09 DC 4x4 SR5
    Still brand new.
    So thats why I had oil stains all over the road!! I guess the moral to the story is if you have an older truck thats not worth fixing, keep using the regular oil so you don't rip off the sludge scabs....;)
  20. Jul 10, 2009 at 3:37 AM
    Janster
    Jandy
    Lancaster, PA
    Ummm....the only ill maintained part about it, is someone using regular oil since the vehicle was new and allowing the sludge to buildup over time. That's the problem..... and that wasn't meant as a stab to anyone.
    If anything, regardless of what oil you use.....more often than not, your vehicle frame/body are gonna rot out long before engines fail (with regular maintenance).
