Swapping Seats in 2nd Gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by greystacoma, Oct 12, 2020.
  1. Oct 12, 2020 at 9:42 AM
    greystacoma
    greystacoma [OP] New Member
    Grey
    1999 Green Tacoma
    Hey there,
    I'm having some issues with my back riding in my 2nd gen. I'm wondering if anyone has ever swapped seats from other Toyotas or even other makes into a 2nd gen to upgrade the seat quality.
    If so, was it a massive pain in the ass?
  2. Oct 12, 2020 at 10:14 AM
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    Haven't done a seat swap, but if you haven't tried the 1" riser option on the rear seat mounts, I would look at it. A few hours in the truck would always give me low back pain until I installed them. It changes the angle just enough for me that I haven't had low back pain as a result of driving since installing. It may not work for you, but may be worth a shot.
    This is one of several options out there. I know there's a few guys on TW that make and sell them.
    https://www.tacomaworld.com/threads/fs-aluminum-seat-mod-spacers.561819/
    TwistedOmYoga likes this.
  3. Oct 12, 2020 at 10:29 AM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    If the OP does not mind, I'll re-ask the question.
    I have put seat risers in, and they do help - but not enough.
    My 2015 has 147K miles on it, and the seat has become uncomfortable over time. It's time for new seats.
    Both Corbeau and Mastercraft have seats and seat tracks for our trucks. However, I do not about the longevity of either brand.
    New seats will be giving up the airbags, but I am OK with that.
    Any experiences with aftermarket seats?
  4. Oct 12, 2020 at 10:33 AM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    I never had any issues with my seats in my '15 but i swapped in a set from a '19 just because i liked them better. Straight bolt in except for the airbags.
  5. Oct 12, 2020 at 10:37 AM
    doorsidedown
    doorsidedown Well-Known Member
  6. Oct 12, 2020 at 11:48 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    I'm running Scion FR-S seats in my 2014 Tacoma. @JdevTac did all of the footwork to get them to work with the air bag plug though.
    doorsidedown likes this.
  7. Oct 12, 2020 at 12:19 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    While it is still possible to do on the driver side, the passenger side is now impossible as MetalTech currently no longer sells the OCS bypasses, and the original guy who made them for metaltech is either MIA or is no longer making them entirely.
    Im sure some other company who makes bypasses for other makes could do this easily. It’s just a microprocessor unit. Otherwise it will be mismatched driver/pass seats, or finding seats from another Toyota model that are more comfortable and use the same passenger seat weight sensor setup to where it plugs right in. FRS seats unfortunately use a different sensor style.
    edit: I should say it’s impossible to do and guarantee a functioning airbag for the passenger. I’ve seen people just say screw it and do it anyway in the GX community but it’s not something I advocate for.
  8. Oct 12, 2020 at 1:15 PM
    jorgem
    jorgem Well-Known Member
    I need new seats as well, wore out the driver side and they are hard to find.
    Is there a way to bypass the air bag seat switch so it always works? Allowing aftermarket seats to be used.
  9. Oct 12, 2020 at 1:29 PM
    JdevTac
    Josh
    GA/WA
    2nd gen
    If you have a 2009+ Tacoma with the seat side airbags, you can google how to bypass those with an inline resistor. I forget the desired ohms rating. There are kits out there.
    The problem is if you have OEM buckets, the passenger side uses a series of weight sensors in the seat tied to a under-seat ECU to detect occupants. This requires a bypass that no one currently manufactures anymore. It’s not a simple resistor trick.
  10. Oct 12, 2020 at 1:32 PM
    jorgem
    Thanks for the explanation, mine is 2006
    OP didnt state the year on theirs.
  11. Oct 12, 2020 at 1:37 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    4Runner seats will swap in. But they’re power seats so need some extra wires
    T@coTim likes this.
  12. Oct 12, 2020 at 1:38 PM
    dantheman1540
    dantheman1540 Well-Known Member
    Dan
    Sugar Loaf Mountain
    2011 Access cab 6 speed 4x4
    Camburg UCAs, Bilstien 5100s/886, AAL, Falken AT3W, Allpro Bumper.
    Is there any option to drop the seat a couple of inches?
  13. Oct 12, 2020 at 6:33 PM
    TeXanTRD
    TeXanTRD Well-Known Member
    2013 TX TRD
    I imagine you're also tall. If this is the case, I feel your pain.
    The Desert Does It seat jackers were an improvement for me by raising only the front an inch and making me sit lower when I'm all the way back. I've even seen some people add shims for more height than what they already provide.
  14. Oct 13, 2020 at 4:41 AM
    dantheman1540
    Dan
    Sugar Loaf Mountain
  15. Oct 13, 2020 at 5:10 AM
    Scott B.
    Scott
    Georgia
    I like PRP seats. I wonder where I could sit in one before laying out the cash...
    dantheman1540[QUOTED] likes this.
  16. Oct 13, 2020 at 5:18 AM
    dantheman1540
    Dan
    Sugar Loaf Mountain
    That's exactly was has kept me from ordering them and trying this. I know 4 wheel parts sell them but I doubt they would have the style I'd want in stock.
  17. Oct 13, 2020 at 5:53 AM
    Icarus II
    Icarus II Well-Known Member
    Keith
    Southeast Pa.
    2007 Prerunner SR5
    Can you get an upholstery shop to replace and reposition the foam to your comfort? Gotta be cheaper than buying aftermarket seats and safer than disabling or changing seat belt electronics.
  18. Oct 13, 2020 at 6:14 AM
    Scott B.
    Scott
    Georgia
    I thought about that. Actually, it's not that hard to do yourself.
    Using factory foam would not really improve things - however, if I could find some more comfortable foam...
    That is an interesting idea. I could add some Katzkin leather at the same time.........................
  19. Oct 13, 2020 at 6:19 AM
    dantheman1540
    Dan
    Sugar Loaf Mountain
    Thats an option I just dislike subbing out work, especially since I don't know any upholstery shops near me.
    Key-Rei likes this.
  20. Nov 14, 2021 at 10:06 PM
    000doodie000
    000doodie000 Well-Known Member
    J
    2015 Taco TRD Off-Road
    Many and always modding Wheels Suspension lift Armor Electrical gadgets etc...
    Was the swap worth it? Are the FRS seats more comfortable? What about longer drives of 4+hours?
