Swapping the RC62F Manual Transmission for the RC60F
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BLtheP, Jan 2, 2025.
  1. Apr 10, 2025 at 12:08 PM
    #41
    BLtheP
    BLtheP [OP] Constantly Tinkering Member
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    It probably won’t go through if you’re shipping it to yourself. The best way seems to be order it to a dealer near you and pick it up. Any time I tried anything shipped it would either go through and cancel later or it wouldn’t go through at all.
    The bad part is if you don’t have a good dealer near you discounting.
    CygnusX191 likes this.
  2. Apr 10, 2025 at 1:39 PM
    #42
    lacab100
    lacab100 Well-Known Member
    Caleb
    '20 TRD OR M/T, Maggy S/C
    Yeah the "nearby" dealer i ordered from was 2hrs away.
    My local dealer 2mins away wanted to charge me 3800 list:eek:
  3. Apr 26, 2025 at 10:27 PM
    #43
    Broke Okie Ty
    Broke Okie Ty Well-Known Member
    Ty
    California/Oregon/ Now in Montana
    01 trd with some stuff
    Armor, winch, other stuff
    Is there a list of bell housings that will swap on the RC trans? I've been searching but nothing comes up. I'm looking for something that goes to the 2nd gen motors.
  4. Apr 27, 2025 at 3:42 AM
    #44
    BLtheP
    Plano, TX
    All I know of is the 3.5 bell housing that comes stock for the RC62F will work on both the 3.5 and 4.0. The RC series cannot be mated to a 2.7L unless you come up with something custom.
    The 4.0L and Tacoma 3.5L have the same bell housing pattern so that’s why it works on those two.
  5. Apr 27, 2025 at 5:04 AM
    #45
    JDSmith
    JDSmith The Overland Shop, VT
    Jesse
    Essex Jct, Vermont
    21 Pro MGM MT
    Always changing
    This is awesome! Great job. This definitely moved to the front of the mod line!
    CygnusX191 and BLtheP[OP] like this.
  6. Apr 27, 2025 at 8:05 AM
    #46
    Broke Okie Ty
    Ty
    Ok cool. They make a 4.0L adapter plate, so that will work.
  7. Apr 27, 2025 at 8:44 AM
    #47
    BLtheP
    Plano, TX
    Are you just trying to mate the RC60F up to a 4.0?
  8. Apr 27, 2025 at 11:43 AM
    #48
    Broke Okie Ty
    Ty
    no I'm working on something special. Also I'm probably going to order the rc61f as it has a better 5-6 split.
  9. Apr 27, 2025 at 6:12 PM
    #49
    808stateofmind
    808stateofmind Well-Known Member
    Kona
    '22 Lunar Rock TRD OR 4x4 DCSB 6MT
    Eibach pro truck 2.0/2R lift kit 1.5" AAL OME/ARB UCA BFG KO2, 285/70-17 SCS Blaze 10, 17-8.5, -10 offset ECGS bushing needle bearing replacement Clutch accumulator disk delete Poor mans TRD intake, K&N 57 series intake tube, K&N high flow filter, TRD flow accelerator
    unreal write up and swap! that low reverse gear must be so nice! awesome work!
  10. May 21, 2025 at 10:31 PM
    #50
    mountaincrawler
    mountaincrawler Well-Known Member
    Hillsboro, OR
    2010 4x4 OR MT
    3" Lift, 35s, 4.88s, Front eLocker, Steel Bumpers, Sliders, URD Clutch Details 3" Lift (AllPro Leafs with Walker Evans 2.5" shocks & Walker Evans 2.5" Non Res Coilovers) Total Chaos UCAs 35" BFGoodrich All-Terrain T/A KO2 17x9 Fuel Offroad Shok D664 4.88 Yukon Diff Gears (ECGS 3rd member) Harrop Elocker (front) Pelfreybilt Front Bumper w/ center hoop Pelfreybilt High Clearance Rear Bumper Pelfreybilt IFS Skid Plate Pelfreybilt Weld On Sliders URD Stage 2 Clutch and Flywheel Relentless Cab Mount Chop Plates ARB Air Compressor AllPro U-Bolt Flip Kit Amp Research BedXtender HD MAX Relentless Bed Rail DUAL Quick Fist Mounts Sport Grille OEM Roof Rack Marshall Offroad Fabrication Bed Bars TEPUI Explorer Series Kukenam 3 Roof Top Tent
    @BLtheP
    Sounds like the RC60F should also work on the 2nd gens with the 4.0 L (1GR); swapping out the RA60F? Do you know if there is really anything different for this than for the 3rd gen swap you did?
    Thanks! Awesome write up and thanks for being part of figuring this out along with others that pioneered this path. The RC60F really does seem to be the transmission the Tacoma always should have had. The ratios in the RA60F are especially ridiculous and the aluminum quill, are you f'in kidding me!
  11. May 21, 2025 at 10:36 PM
    #51
    BLtheP
    Plano, TX
    I don’t know all the details on the RA to RC swap, but since the 2024+ RC60F and RC62F swap in place of each other identically, there is no reason you couldn’t bolt in an RC60F the same way @BillDaCat8 did with the RC62F in his swap.
    The snag will be that since the 2024 RC60F is setup for the turbo-4, it will not have everything you need for your engine, and since you don’t already have an RC62F in your truck, you will need to hunt down all those parts (the shifter piece, shift tower, bell housing, maybe wiring brackets, etc). It’s a cakewalk swap for 3G since we already have all the necessary stuff on our sister transmission model. For you, you’ll need to grab all that from Toyota, junkyard, eBay or similar, and then also get the new trans and mix and match it all to work.
    Agreed, the aluminum non replaceable quill is complete crap. Overall I like the RC60F, although if I could mix and match ratios, I would choose the ODs from the RC62F personally. But oh well. I like it how it is too.
    #51
  12. May 21, 2025 at 10:39 PM
    #52
    mountaincrawler
    Hillsboro, OR
    2010 4x4 OR MT
    Ok, makes sense that it would be a bit more work, but still definitely worth it for the better ratios and getting rid of the aluminum quill. Thanks for the really quick reply!
    #52
  13. May 21, 2025 at 10:43 PM
    #53
    BLtheP
    Plano, TX
    I definitely agree that it’s worth doing and now that the 60 gear set is available, I do think it’s a better choice than the 62 gear set.
    I also think that paired with a regear, some meaty tires, and the 4.0, the truck would be a damn beast. The 3.5 is still pretty weak sauce, even with 5.29 gears and this transmission, but it’s a whole lot better than it was stock. I think the 4.0 would be better for sure. I say go for it. Find yourself a shifter stick and shift tower from someone who used a B&M or Core (or go with one of the short throws yourself), find the bell housing, the shift lever housing piece, and the rest of it you can probably get by just fine.
    3030-04080 - Transmission, T24A-FTS RC60F
    31111-04020 - Bellhousing, 1GR/2GR(Truck)/7GR RC6x
    31204-35100 - Clutch Release Fork, 1GR/2GR(Truck)/7GR RC6x
    31236-0K050 - Support, Release Fork, 1GR/2GR(Truck)/7GR RC6x
    31470-35210 - Slave Cylinder, 1GR/2GR(Truck)/7GR RC6x
    33521-04020 - Housing, Shift Lever, GRN3## Tacoma
    33530-35661 - Shift Lever, GRN3## Tacoma
    33506-04010 - Retainer, Shift Lever, GRN3## Tacoma
    33584-0K010 - Gasket, Shift Lever Retainer, GRN3## Tacoma
    Those are basically all the parts needed to mimic the stock 3rd gen setup, provided by @Jeff Lange
  14. May 21, 2025 at 10:45 PM
    #54
    mountaincrawler
    Hillsboro, OR
    2010 4x4 OR MT
    Also thanks for the reference to @BillDaCat8 's swap. I had been reading his thread as well, another excellent write up.
    #54
    CygnusX191 and BillDaCat8 like this.
  15. May 21, 2025 at 10:54 PM
    #55
    mountaincrawler
    Hillsboro, OR
    2010 4x4 OR MT
    Wow! Thanks again!! This is fantastic information and you didn't have to go to the trouble of concisely summarizing it for me when you have already provided so much detailed information in this thread and your other one.
    I'm running 4.88s and 35s, which puts me at slightly lower gearing than stock, so with the 4.0L it's definitely got some pick up to it, but is pretty rough on long highway hauls and I've literally said, "I wish I had a 7th gear". The double overdrive in the RC60F sounds like exactly what I want. I don't particularly need the super low 1st gear ratio but hey I won't complain about it either.
    I saw you were running 5.29s with 32s! That must've been crazy low lol and does make it sound like the 3.5L is pretty gutless. The 4.0L is definitely great for the trails, I'm guessing the 3.5L probably does better on the highway.
  16. May 21, 2025 at 11:03 PM
    #56
    BLtheP
    Plano, TX
    Yeah, with 4.88 and 35’s, you won’t be too far off from the 4.30s and stock tires I am now running. Which works fine, I just wish 6th had a bit more go. The 4.0 is probably better about that, slightly. Overall it does work really well. I don’t think the “low” 1st gear will bother you at all. It’s no different than a stock 2024 Tacoma.
    I did have 32’s and 5.29s for a while, and it was fantastic. 1st was quite short, but 2nd was finally reasonable to start in. And all of the other gears were wonderful. Reverse was nice and short too. 6th cruised at about 2700 rpm with that setup, which also worked well. Still 17-19 or so mpg most of the time. Now that I am on 4.30s, mpg is consistently better, and overall the gearing is pretty well balanced, I just still wish the top 3 gears were spaced out a bit more. I’d be totally happy if 4th was more like 1.10:1, 5th was like 0.90, and 6th was 0.70. The way it is, I’m automatically going to 4th for mild passes and 3rd for quick passes. 5th is not useful for passing, it’s only useful for a slightly slower cruise or a more zippy cruise when you may be in traffic and keep getting slowed down or something. Otherwise, it has absolutely nothing to really pass with, and so it really does feel like just another overdrive.
    The 3.5 is good at high range, its Achilles heel is having nothing down low, so when you try to pass quickly in 4th, it bogs down and barely wants to speed up. It’s other issue is the fuel cut if you hit redline. It literally will stop fueling for like 2 seconds, so you really don’t want to gear it to where you’re going to hit redline in the middle of a pass. You want whatever gear you use to be able to make it through the pass without hitting redline, but also be low enough to be quick enough to make the pass in a timely and safely manner. Those are just weird 3.5 quirks, I have never had to be so strategic in any other vehicle I’ve ever owned. I think really it’s the computer trying to protect the engine conservatively, which could be a good thing but it really kills the experience sometimes.
  17. May 21, 2025 at 11:27 PM
    #57
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    In due time, you'll learn how to drop small hints to the new misses on whats broken so it can be fixed.... (and upgraded or course).
  18. May 22, 2025 at 8:47 AM
    #58
    willhahn24
    willhahn24 Well-Known Member
    2016 Tacoma
    Nice work, very cool!
  19. May 25, 2025 at 8:15 AM
    #59
    mountaincrawler
    Hillsboro, OR
    2010 4x4 OR MT
    It does sound ideal for my setup. Crazy that the 5th gear in it is a higher overdrive than my 6th gear. I can pass comfortably in 6th at highway speeds but do have to drop to 5th if it needs to happen quickly. I'm also down at sea level lol, it's a different story when I go to Colorado.
    It would be nice to get some better mpgs on the highway and at the lower rpm it should be a little better. I also just get leery about running the engine at high revs for long periods of time. The 4.0L gets its power at the lower end so holding it at 3-3200 rpm for hundreds of miles just feels wrong. Will be nice to have that higher overdrive for sure.
    Its a shame they ditched the 4.0L for a more "street" oriented engine when most Tacoma owners want something with more low end grunt. Freakin tragedy that you can't even get a V6 in the 4th gen. Hitting the fuel cutoff is never fun and completely counter productive and potentially dangers for it to happen while trying to pass. I feel the same way about the stupid stability control system that will pull you into oncoming traffic because it thinks you're going to roll the truck. I've never been a fan of too much computer control/automation in vehicles, but I also enjoy the driving experience, which is why I have a manual, and don't want to just sit there while the car drives itself.
  20. May 28, 2025 at 8:09 PM
    #60
    BLtheP
    Plano, TX
    At almost 10K miles on this transmission, I did a fluid change for the first time since the initial fill. The transmission has a magnet internally for shavings, so I wasn’t really worried about “bad” fluid sloshing around in there. I removed the fill plug first and got a small dribble of fluid, so the level was good and full.
    Happy to report that the fluid that came out looked great and after the fill up, it seems to be shifting as good as ever (maybe better than it was but that could just be the placebo pill I had with dinner). For the record, I am using Joe Gibbs Driven 80W-90 GL4, and I think it’s the best of the 7 fluids I’ve tried.
    Aside from the little fluid leak scare that turned out to be nothing, this transmission has been a win and I highly recommend it if you can stomach the financial hit.
