swapping transmistions? 2WD to 4WD?
Discussion in 'Technical Chat' started by broken taco, Jun 30, 2013.
  1. Jun 30, 2013 at 3:14 PM
    broken taco
    broken taco [OP] Well-Known Member
    Adam
    San Diego
    01 TRD SR5 4WD
    Custom pre-runner front bumper with a warn winch, custom grill, glassworks unlimited fender flares, custom rock rails with kickups (modeled after Relentless Fab Rock sliders), rear bumper from streetacos.com (with custom rap around protection for fiberglass fenders and the hitch receiver hidden behind the license plate that is on hinges), Fox extended travel coil overs with reservoirs up front, Total Chaos upper control arms, limit straps, Diff Drop, Deaver leaf Springs, Fox shocks with reservoirs on back, BFG KM2 tires, HID off road lights on front bumper, 16w square pods from olympusoffroad for reverse lights, high lift mounted in the bed, onboard air, Flowmaster muffler, aftermarket air intake, alarm system. Alpine Deck, Alpine amp, Alpine speaker, JL W6 12" subwoofer, JL amp,
    I had got a new transmission in my 2WD truck right before i rolled it. To replace that truck I got a 4WD truck. I want to swap out the transmissions. Since the one on my wrecked 2WD truck is new.
    So my question is can the tail housing on the 2WD drive (the part connecting the transmission to the drive shaft) be taken off and the transfer case for 4WD be bolted on?
    So is the transmission the same and able to be swapped out just with a little modification?
  2. Jul 2, 2013 at 2:09 PM
    broken taco
    Adam
    San Diego
    01 TRD SR5 4WD
    so i couldn't just do it with the parts already on both of the trucks? i don't need the 2WD truck to run. I just want to put the tranny from the 2WD into the 4WD.
