Sway-a-way 2.5 shocks
Discussion in 'Suspension' started by BenJammn5, Jun 21, 2010.
  1. Jun 21, 2010 at 6:16 PM
    BenJammn5
    BenJammn5 [OP] RN
    San Jose
    09 TRD-Off Road PreRunner
    TRD cat-back with Spintech prostreet muffler, AFE Pro dry S intake, 16" SCS F-5, 3.5 BS, 305/70 GT Radial MT, King extended travel front/rear, 2" add-a-leaf, Maxtrack Spindles, Sway bar delete, DSM UCA, All Pro IFS skid, Cab mount chop, bed cab locks, Black badges, cali raised amber LED fogs, 6K FX-R Morimoto projectors with 55watt ballast, fog mod, cheap rear dust lamp from autozone, Hellas 500 behind grill, Color match Satoshi Grill, Hood scoop, rear bumper by BTF, color matched Glassworks bed caps, Wet Okole seat covers
    Installed these shocks yesterday. Got em revalved by Sonny at Downsouth. I didn't change the ride height just left em where they were at from the previous owner. I had 5100's at 2.5" previously and from fender to top of tire I measured 6.8 on passenger side and 6.5" on driver side. With the SAWS i'm about 7.8 on passenger side and 7.6 on driver side. I didn't put the sway bar back on and the truck rides okay.
    Took the truck off road a little and noticed it clunked when I'd hit small bumps. Even speed bumps at low speeds make the truck feel like a rock. My best guess is that theres too much pre load on the spring and the truck doesn't have anymore down travel so I'm hearing the "clunk" of the shock fully extending.
    What measurements do you guys roll at? I know most do 3", but how the hell do I know my truck is up 3"? I'm gonna back off the spring by approximately .5" and go from there.
  2. Jun 21, 2010 at 7:05 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    im at ~25" from center of front hub to fender w/ my 4" spindles and COs at ~1"...so i would say that ~23 from hub to fender would put you at ~3".
    but, like you said, 3" lift will only give you about 1" downtravel...and i say your correct on your extending assumption...
  3. Jun 29, 2010 at 11:18 PM
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Lakeside, Ca. 92040
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 34" x 10.50" x 17 Toyo Tires on 17" x 9" RaceLine Wheels
    Hi Ben,
    We didn't re-valve your coil-overs, we just re-built them and installed the new shaft in the one. And you are right, there was a ton of pre-load on them, as Sonny mentioned to you. And we had a HELL of a time getting the springs off and on, to service the shocks.
    You should probably back off the pre-load and see how it rides then. If you want us to make a change in valving, give us a call.
    Let us know....
    Marco
  4. Jun 30, 2010 at 8:04 AM
    BenJammn5
    BenJammn5 [OP] RN
    San Jose
    Thanks for the clarification on the rebuild, and I did back off the spring a lot. Truck rides great now! You guys did an awesome job. I will be returning Sonny's bar that I used to ajust the spring.
  5. Jun 30, 2010 at 8:27 AM
    takern
    takern Well-Known Member
    Tanner
    Virginia
    03 TRD Offroad stepside
    Deckplate mod, sliders, uniden cb, toolbox, dakar leaf pack, in search of coilovers, 255/85 16 bfg m/t waiting to go on
    just out of curiosity what are your new measurements? mine are a bit high as well and im gonna move em down at some point in time. im thinkin to about 2.5" above stock
