Sway-A_Way (SAW) Coilovers
Discussion in 'Suspension' started by DHwreckage, Oct 4, 2013.
  1. Oct 4, 2013 at 8:48 AM
    DHwreckage
    DHwreckage [OP] Well-Known Member
    Boulder, CO
    Moby Dick (FZJ-80)
    Does anyone know if you can upgrade the SAW coilovers to be extended length? maybe use the parts from kings or donahoe extended length? This would be for a 1st Gen Tacoma and yes i have upgraded UCA's!
  2. Oct 5, 2013 at 12:00 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    I think they're already extended length? When I talked to them awhile back they said I could pull 10.5" with their A-arms.....not sure what tape measure they're using though :rolleyes:
  3. Oct 5, 2013 at 12:24 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    your a 2nd gen. Could be possible.
    OP: best thing to do is contact SAW. I have never seen extended travel SAWs..only Foxes, kings or Icons.
  4. Oct 7, 2013 at 10:32 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    You can do it with SAW parts. They have been selling them for years. Kind of pointless with 4wd, with or without after market arms.
    Pull your lower mount bolt, pry the lower arm down a tad more than stock while rotating the axle and see for yourself.
  5. Oct 7, 2013 at 11:00 AM
    DHwreckage
    Boulder, CO
    Moby Dick (FZJ-80)
    Not really sure what you are showing me in that link....that is just the 2" SAW Coilovers from Wheelers and they are not extended length. Anyways i have the 2.5" CO's. Enlighten me please if i am missing something about that Wheelers link you sent me.
  6. Oct 7, 2013 at 1:45 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    Go to the link, look at the pic in the upper left, 2 different lengths. Now go down to the last sentence in the paragraph at the bottom. You should feel enlightened.
    As for 2.5" bodies give em a call. The pic on the 2.5" page actually shows a 2" on the left and a longer 2.5" next to it and there is no mention of different lengths.
  7. Oct 7, 2013 at 1:49 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    FYI..2.0 vs 2.5 has NOTHING to do with length of the shock man. It has to do with the shock bodies.
    it would appear you can get extended SAWs in 2.0 and 2.5s.
  8. Oct 7, 2013 at 1:51 PM
    DHwreckage
    Boulder, CO
    Moby Dick (FZJ-80)
    i just saw an option under the 2.0 for having aftermarket UCA's which "Might" mean there extended length for those but oddly enough there was no price increase for them so i dont really think that means there extended length and for the 2.5s there was no option that i saw. and yes i know what 2.0 and 2.5s are Blackdawg :p
  9. Oct 7, 2013 at 1:54 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The differenct between most extended vs standard travel coi overs..is a 1/4'' spacer inside the shock. the extended ones just remove the spacer. Lucky for you, SAW doesn't seem to charge more for that..I would have gotten those if i was shopping for CO and SAWs. even with stock UCAs to add uniballs later.
  10. Oct 7, 2013 at 2:01 PM
    DHwreckage
    Boulder, CO
    Moby Dick (FZJ-80)
    yea i bought my SAW coil overs in i think 2006 or 2007 :eek: way before i knew about extended and non-extended CO's
  11. Oct 7, 2013 at 2:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Im sure if you send em in to get rebuilt you can have them made into extended. Like i said its usually just a spacer.
  12. Oct 7, 2013 at 2:11 PM
    DHwreckage
    Boulder, CO
    Moby Dick (FZJ-80)
    I Thought the donahoes Ext. Length CO's had a longer eyelet section below the coil.
  13. Oct 7, 2013 at 2:11 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    As far as length, yes and yes again. SAW shock bodies and shafts come in ROUGHLY 2" increments, way more than the difference in the 2 lengths.
  14. Oct 7, 2013 at 2:13 PM
    DHwreckage
    Boulder, CO
    Moby Dick (FZJ-80)
    Extended Length Icons:
    Non-Extended Length Icons
    Notice the longer bottom, i.e extended vs non-extended
  15. Oct 7, 2013 at 2:13 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    sure you werent looking at 2nd gen COs? only 2nd gen CO have the long stems
  16. Oct 7, 2013 at 2:14 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    haha noooo
    those are 2nd gen tacoma CO on the top
    1st gen on the bottom.
  17. Oct 7, 2013 at 2:18 PM
    DHwreckage
    Boulder, CO
    Moby Dick (FZJ-80)
    Just FYI Thats what i thought but those images are pulled from the 1st gen ICON suspension section in Wheelers.
  18. Oct 7, 2013 at 2:23 PM
    DHwreckage
    Boulder, CO
    Moby Dick (FZJ-80)
    Looking at the ICON website you might be right, i must have only seen the 2nd gen Ext. Length Coilovers so i thought you could get a new shaft and make it EXT. but it doesnt look that wqay on the Icon website. Well i emailed wheelers and SAW so we'll see if i get an email back.
  19. Oct 7, 2013 at 2:50 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea im 100% possitive those are 2nd gen CO not 1st gens.
  20. Oct 7, 2013 at 3:00 PM
    Shauncho
    Shauncho Embrace your inner Bro-ness
    Shaun
    Parts Unknown...
    none
    ok, so I've been kinda curious about this too as I'm still learning about suspension as well. So what all is needed in order to run the Extended length shocks? Just aftermarket UCA's? And all they do is provide more droop?
