Sway-A_Way (SAW) Coilovers
Discussion in 'Suspension' started by DHwreckage, Oct 4, 2013.
  1. Oct 7, 2013 at 3:10 PM
    DHwreckage
    DHwreckage [OP] Well-Known Member
    Boulder, CO
    Moby Dick (FZJ-80)
    According to the manufacturers you need uniball UCA's to benefit from the extra droop you will get but i i believe you could run Ext. Length with stock UCAs you just wont beable to use that extra Droop the Ext Length CO's give you when paired with uniball UCA's so if you plan on getting the UCA's later i think it would make more sense to ge tthe Ext. Length CO's even if your run em with stock UCA's for a little bit. But honestly if i were in a 2nd gen id just get the All-Pro LT kit :cool:
  2. Oct 7, 2013 at 3:19 PM
    Shauncho
    Shauncho Embrace your inner Bro-ness
    Shaun
    Parts Unknown...
    none
    That's what I figured. Makes sense. Yeah...I'm on the fence about LT...but it's kinda leaning that way. All depends on if I can come up with the funds before I get too impatient.
  3. Oct 7, 2013 at 3:22 PM
    DHwreckage
    Boulder, CO
    Moby Dick (FZJ-80)
    Well with the All-Pro kit you dont need fiberglass fenders which is nice i wish they made a kit like that for first gens id be allover it but im not really sure what you have to do to the CVs that is if your 4x4, havent read into the kit too much seeing as i cant use it on my truck.
  4. Oct 7, 2013 at 4:56 PM
    DHwreckage
    Boulder, CO
    Moby Dick (FZJ-80)
    from Wheelers "So the only difference between your shock and the extended ones is a one inch spacer inside the shock that limits your up travel. You can tear apart your coilovers, get inside and take that out and in the meantime put new seals in your coilovers. But that is up to you. That is basically the only difference".
    So you are right Blackdawg! Guess i need to rebuild my CO's and take that fuckin spacer out!
  5. Oct 7, 2013 at 7:06 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    You might want to think on that a bit. How would a spacer limiting up travel have anything to do with "more droop" as they state? The bumpstops limit up travel not the shock. The "spacer" in guestion is just a damper to cushion the impact of the piston to the shaft end of the body at rapid full extension and by default limiting down travel. Thinner or no damper equates to more extension.
    Spend 15 minutes and do the CV bind check mentioned in post #4 and ask yourself if that is truly what you want going on at full droop.
  6. Oct 7, 2013 at 8:07 PM
    jgilbreath
    jgilbreath Well-Known Member
    Kerrville, TX
    99 Tacoma PreRunner
    Husky floor liners, SAWs 2.0
    The SAW 2.0 seem like a good deal when compared to other co. The only things i have seen close to their price are bilstein CO and fox 2.0 from all pro. But the fox only go up to two inches and i assume the saw shock is superior to a bilstein 5100. It also makes sense to get the extended saws with after market control arms not just for more travel but for better alignment, correct?
  7. Oct 7, 2013 at 8:10 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    :cool:
    Damn straight :p
    tear em down man!
    i think Wheelers worded that wrong. The spacer would impact the shaft travel as i think its attached to the shaft..but im not 100% certain on that. thus down and up travel are effective.
    Either way, an extended Co gains about 1-1.5'' more droop wheel travel and about 1'' up travel.
  8. Oct 8, 2013 at 10:38 AM
    DHwreckage
    Boulder, CO
    Moby Dick (FZJ-80)
    I have checked my droop on my truck and it can use more, no to little binding at full droop from what ive seen so far
  9. Oct 8, 2013 at 4:06 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    Where did you come up with the 1" additional up travel number?
    The "spacer" is technically known as an internal bumpstop. It is more or less a doughnut around the shock shaft between the piston and the shaft end of the shock body. Billies have it too. It is necessary to cushion the impact of the piston against the end cap of the shock at full extension and full extension only on systems where the shock is used to limit down travel. Removing it altogether would be a mistake.
    If you have "little binding" now you will have more with a longer shock. Am I missing something?
  10. Oct 9, 2013 at 8:25 AM
    DHwreckage
    Boulder, CO
    Moby Dick (FZJ-80)
    As for this im pretty sure that sway-a-way, or any company icon/kings/etc., would not sell extended coilovers which were just the same coilover without an internal bump stop im going to look through rebuilds and see if i can find this spacer they are talking about!
    I believe the little binding i have is due to the factory boot becasue it s only on the side that doesnt have a ripped boot :rolleyes: so with high angle boots i think it would be alleviated! Im going to put some new coils on mine in the next few weeks so ill see if i can find out how much more droop i can have before the tripod knuckles bind!
  11. Oct 9, 2013 at 1:14 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    Totally agree, it was Wheelers that said to toss it.
    Good plan, find out first hand, for yourself, on your truck.
    Lots of things can affect the exact point where binding will occur such as alignment, deformation of the rubber in upper/lower control arm bushings, bent/tweaked frame, spindle, arms and CV manufacturer. Years ago hytenor had a tripod come all the way out of the bell. At the time he was running the old adjustable Downey/Bilstein that was only 3/8" longer than stock. I have never heard of that happening before or since with any shock.
  12. Oct 10, 2013 at 3:15 AM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    so if thats not how extended coilovers gain the extra travel, how are extended travel coilovers built that allows for the extra inches?
  13. Oct 10, 2013 at 11:43 AM
    DHwreckage
    Boulder, CO
    Moby Dick (FZJ-80)
    so Here we go guys a definitive answer from SAW "
    All you would need to convert our standard 96-04 Tacoma to one with UCA, is to switch out the internal spacer. Yours has a 1.45" spacer and the UCA kit has a .685" spacer."
    The part number for said spacer is "56060-685 PISTON ROD SPACER, .685", 2",2 1/2", $4.00 each"
    So that is how you turn your Standard CO's to Extended Length CO's. So this spacer gives you .765"s at the shock but at the end of the LCA im sure it correlates to over an inch.
  14. Oct 10, 2013 at 11:49 AM
    steezemcqueen
    steezemcqueen 4Runner Abuser
    Dylan
    Crawlarado
    1997 4Runner Turbo and 2006 Tacoma
    Unicorn fart injection system
    All ICON, SAW, Radflo coilovers use the same coilover for the standard and extended travel versions. The difference is the bumpstop spacer.
    Also, you can't run the extended travel version without aftermarket UCA's because you will bind the upper ball joint. Thats going to cause it to wear out or snap really quick.
  15. Oct 10, 2013 at 4:20 PM
    #35
    Dirty Pool
    99 XCAB V6 MT TRD
    Well what do you know about that.
  16. Nov 5, 2013 at 12:18 PM
    #36
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    I think someone goofed. Should be refering to limiting downtravel.
  17. Jan 3, 2022 at 7:09 AM
    #37
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Thread revival haha, anyone know where to find the smaller shaft spacer these days, SAW has changed hands a few times and appears to be in the capable hands of aFe now but they don't have this part in the replacement parts catalog.
  18. Jan 3, 2022 at 8:44 AM
    #38
    Blackdawg
    Monte
    Wyoming/St. Louis
    @TMFF
    Speedytech7[QUOTED] likes this.
  19. Jan 3, 2022 at 10:01 AM
    #39
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    I don’t stock anything for SAW’s besides seals and bearings.
    Poly performance or kartek may have some stock.
