Sway Bar Bushing Bolts Size (Stripped Nut) - 2007 Tacoma PreRunner V6
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Zdosse935, Feb 13, 2024.
  1. Feb 13, 2024 at 10:04 PM
    Zdosse935
    Zdosse935 [OP] Well-Known Member
    Does anyone know the thread pitch for the sway bar bushing bolts on the 2007 Tacoma PreRunner V6??? I accidentally stripped the nut that was welded in the car frame where the sway bar bushing goes. When I checked the bolt thread it was fine but when I tried to put it back in, the bolt kept spinning. I am trying to get the same bolt but longer to put it through the other side of the frame and slap a hex nut at the end to call it a day. The hex bolt uses a 14mm socket to take if off.
    Thank you guys
  2. Feb 13, 2024 at 11:15 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Probably an M10 if it’s a 14mm. Just looking at it should give you the pitch thread or you can measure the amount of threads in one centimeter and divide by 10 to get the pitch thread.
    A 3/8 bolt would also work and usually takes a 9/16 socket which also works with a 14mm in a lot of cases (sometimes it’s a little tight in a 14mm socket but not usually).
    Zdosse935[OP] likes this.
