Sway bar bushings and end links
Discussion in '1st Gen. Tacomas (1995-2004)' started by CrippledOldMan, Dec 23, 2020.
  1. Dec 23, 2020 at 9:40 AM
    CrippledOldMan
    CrippledOldMan [OP] Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    I asked this question over in the "Stupid Questions" section, but never received a reply. So here it is.
    When replacing the sway bar bushings and end links, do I need to leave the truck on the ground with all the weight on the tires, or can I put it up on jack stands to replace these parts. Thanks for any replies or advice.
  2. Dec 23, 2020 at 9:41 AM
    Overlandcharlie
    Overlandcharlie Well-Known Member
    Tulsa ok
    2017 TRD OR access cab
    Toytec boss alumaseries C/O JBS UCAs CMC 1/4 “ level spacer Boss2.5 rear shocks Toytec AAL and 1” block Lo pro front recovery bumper X20 winch dynnema rope / factor 55 aluminum recovery clevis Lo pro light bar install with wireless remote RCI sliders Dobinson snorkel PRO aluminum skid TRD PRO grill Fuel 17x8.5 wearing Nitto 285s 285 spare and spare mount mods Rear recovery point Soft topper ( grey) modified tail gate snap Snail armor aluminum tailgate insert In bed - sleeping and storage platform ( with tool locker ) - carpeted Offroam RAM mount - cellular/GPS Maxtraxx knock offs and tons of recovery gear including more power puller synthetic Rugged ridge compressor ROAM storage Shiftsense mod .
    On the ground
  3. Dec 23, 2020 at 9:48 AM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    Thank you sir, just the info I needed. I've read where some did this with the vehicle on jack stands, and had problems. Just wanted verification.
  4. Dec 23, 2020 at 10:25 AM
    Overlandcharlie
    Tulsa ok
    Yeah so much easier On the ground and alignment of sway bar isn’t tweaked
  5. Dec 23, 2020 at 8:10 PM
    MCJohnston
    MCJohnston Well-Known Member
    Matthew
    CT
    02 Tacoma SR5 TRD 3.4L 4x4 X-tra Cab
    I’m sorry but I have to disagree. Leaving the truck on the ground is a pita. I have done hundreds of end links and bushings and not once left it on the ground. Plus trying to get behind the wheel to remove the upper link nut is a pain.
    Do one piece at a time. And you won’t have any issues.
    Vise grip the inside joint if there isn’t a spot for a wrench on the link, the nut almost never comes right off. When doing the bushings I loosen both, then replace one at a time and then sock em back down. Easy peasy.
  6. Dec 23, 2020 at 8:14 PM
    Bishop84
    Bishop84 Well-Known Member
    It's easier on the ground because the arms are unloaded.
    That said I never would bother with any tacoma model like this. Only 07+ tundras benefit from doing them on the ground now.
    Either way is fine, but be ready to fight, vice grips as mentioned are your friend.
    Also the bolts that hold the bushings to the frame *can* break, so if it feels off, stop and work them free, shock them whatever has to be done.
  7. Dec 23, 2020 at 8:20 PM
    MCJohnston
    Matthew
    CT
    I think it all depends on what you consider easier. Most end link too nuts are pointed outward, pull the wheel, vise grip the back and zip that sucker off with the impact. Do both sides, pivot the bar and get the electric ratchet on the inside nut at the bottom.
    Just my way though.
  8. Dec 23, 2020 at 8:22 PM
    Bishop84
    I'm agreeing, I work with hoists and jack stands haha. I lay on my back for no one!
    MCJohnston[QUOTED] likes this.
  9. Dec 23, 2020 at 10:05 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    Well Gentlemen, I'll take all of your advice to heart. When the weather warms up to a balmy 60 degrees or so, I'll take another look at it and see which method will benefit me the most. Thanks for all the replies.
  10. Dec 23, 2020 at 10:31 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I've zipped them on and off within minutes without ever putting a jack under the truck.
  11. Dec 23, 2020 at 10:50 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    I'm a little fatter than I used to be, but I can still squeeze my old butt under a 4x4 Tacoma, Just barely, but I do it every time I lube the drive train. The front end, I'm not so sure about, but we'll see if I can fit!! I did finally find a good way to grab and twist my oil filter on from the front, so much easier than the old way I was doing it.
    MCJohnston likes this.
  12. Dec 24, 2020 at 6:07 AM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    Remove it all together.
    I'm 3 linked in the front and run without one. My wife drove it as a daily for 4 years without issues. Save the money on bushings towards some upgraded CO's and UCA's.
    Good luck.
  13. Dec 24, 2020 at 6:28 AM
    goldentaco03
    goldentaco03 Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    For end links you pretty much gotta have the wheel off and jack it up...they're a pain to get off, especially if older or rusty. You will need to remove the lower shock bolt so the LCA and sway bar are no longer loaded.
