Sway bar bushings on an 08 Taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bonercitycowboy, Jul 12, 2017.
  1. Jul 12, 2017 at 3:34 PM
    bonercitycowboy
    bonercitycowboy [OP] Member
    Quick question. I got the energy suspension front sway bar bushings and i want to install them but do i need to jack up my truck to do so? thanks brosefs
  2. Jul 12, 2017 at 5:20 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
  3. Jul 13, 2017 at 7:09 AM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    :popcorn:.....sub'd
  4. Jul 13, 2017 at 7:56 AM
    Pigpen
    Dan
    Northwest Montana
    ^^ this
  5. Jul 13, 2017 at 7:58 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Two bolts on either side to be removed, pull brackets, pull old bushings, install new bushings, brackets back and bolted in, torque to spec, done. Might take you 10 min tops.
  6. Jul 13, 2017 at 8:00 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    the bracket has a slot, loosen both and find the one that has a slot and remove the non slotted one
    it the bolt binds on removal, soak in penetrating oil and screw back in and try again
  7. Jul 13, 2017 at 8:04 AM
    Pigpen
    Dan
    Northwest Montana
    All of this will be much easier to do if you remove the "skid plate" first. :D
  8. Jul 13, 2017 at 8:19 AM
    knottyrope
    Knotty
    Bahstun
    that skid plate is a pain if rusty, all my bolt broke off and have to drill them out to add in speed nuts
