Sway bar + coilover adjustment
Discussion in 'Suspension' started by ghostboy808, Jul 29, 2009.
  1. Jul 29, 2009 at 7:11 PM
    ghostboy808
    ghostboy808 [OP] Well-Known Member
    Silver Mica Prerunner TRD Sport
    Gibson SS, TRD S/C
    Does the sway bar have an effect on the coilovers when adjusting them? It seems I have the passenger side adjusted way down and the driver's side way up and the passenger side is still about a 1/2" higher than the drivers. It seems like no matter how much I adjust either side it's still off by 1/2" Anyone have the same problem?
  2. Jul 29, 2009 at 8:29 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    It's not the sway bar causing it. Its the fact that the battery, driver and gas tank are on the drivers side.
  3. Jul 29, 2009 at 11:08 PM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    Icons, Bilstein 5100, Rear Leaf TSB, 17x9 American Racing Chamber Teflon, 275/70/17 Goodyear
    he said though it does not matter how much he adjusts it, that i stays the same. This makes no sense however. All I can say is either crank up the driver side more or lower the passenger side. DO one turn up on the driver side and do one turn down on the passenger side until it is level.
    I have almost twice as much thread showing on driver side as I do my passenger side.
  4. Jul 30, 2009 at 7:16 AM
    Padilla1880
    Padilla1880 "Let's Ride!"
    Daniel
    Temecula, CA
    05 TRD OffRoad V6 SR5 PreRunner
    Taco Lean? If that's the case you should contact chris4x4 he makes a spacer to help correct that.
  5. Jul 30, 2009 at 7:36 AM
    Brunes
    Brunes abides.
    Rotorhead
    He's got adjustable coilovers- no need for the spacer- Just needs to keep working on the adjustments to get it right...it will be a big difference between the two sides... but that should do it...
  6. Jul 30, 2009 at 10:21 AM
    ghostboy808
    Gibson SS, TRD S/C
    Thanks guys, I got it to within 1/8" difference. You guys are correct when you say you have to have twice as much thread showing on the driver's side. I ended up doing like three turns down to one turn up between the two sides to get them even. In the beginning I wasn't cranking them enough to make a difference after settlement.
    The adjusting part is just a slight pain in the ass - jack up truck, adjust both sides, drive around the block check heights again, jack up, adjust some more, etc. After all that check again after a few days and it was different again. Repeat process till it gets closer.
  7. Aug 1, 2009 at 12:56 PM
    kosers
    kosers Member
    off road trd
    I had an 07 TRD Off-Road & I traded it in because I couldn't figure out a slight sway in the truck. This happened after the hubs froze to the drum--therefore holding the truck in place. I bumped the rpms up to 2.5 then instantly the truck jumped forward while being in 4-wheel drive and it has been swaying at high & low speeds (It seems the hesitation in the turning causes the swaying). I noticed a lot of wear on the outside edges of the front tires. Numerous dealers have told me that nothing was wrong; "I feel something different". Now my 2009 TRD off-road is exhibiting the same behavior... It was perfect when I bought it but after towing a boat the 1st time, while being 4-wheel. I accessed firm ground-on a flat surface, and stopped the truck so that I could put it back in 2wd. I noticed the sway from then on (again)... Ps, it's not the alignment.
  8. Aug 1, 2009 at 1:21 PM
    ghostboy808
    Gibson SS, TRD S/C
    what do you mean by sway? rocking back and forth or side to side? How did your hubs freeze to the drum? maybe backing it up into salt water a lot had something to do with it. not moving until you hit 2.5k in gear and then lurching forward seems like something was frozen in place.
  9. Aug 1, 2009 at 1:33 PM
    ghostboy808
    Gibson SS, TRD S/C
    how were you towing you boat into the water?
  10. Aug 1, 2009 at 1:44 PM
    Padilla1880
    Daniel
    Temecula, CA
    ^WOW! Total Failure!
