Sway bar contacting coilover despite relocation bracket
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kzart, May 11, 2023.
  1. May 12, 2023 at 9:14 AM
    kzart
    kzart [OP] New Member
    Kenton
    Denver
    2020 DCSB TRD Off Road
    Kings SPC UCAs Dakar Leafs BAMF hybrid bumper RCI skids Method Wheels
    long time lurker infrequent poster what can I say
    but in reality I don’t wheel nearly as hard as lots of folks here, so I’d doubt it was that
  2. May 12, 2023 at 1:19 PM
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga STRONG Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    Nothing wrong with that! :cheers:
  3. May 31, 2024 at 7:21 AM
    Mlofthou
    Mlofthou Well-Known Member
    Mason
    2021 tacoma
    Soooo... What did you end up doing? I'm thinking of yanking my sway bar out. Read the whole thread but need the ending haha
  4. May 31, 2024 at 8:25 AM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    Hopefully he just removed the sway bar. 700LB spring in the front = a pretty good reduction in bodyroll. Plus you will feel a difference as the shocks can articulate more.
    If you switch to a full aftermarket Leaf Pack, you will also feel a reduction in bodyroll as well.
    In some models (Sometimes the 2nd Gen taco, 5th gen 4Runner) when you add a sway bar relocation it drops the bar down and can also cause the sway bar to make contact with the Radiator support brackets, so you have to spacer them as well. This can then reduce ground clearance. I would just delete the sway bar when running these higher end shocks (2.5" diameter).
    The exception is usually with the 6112's you don't need a sway bar relocation kit bc the collars sit a little higher on the shock.
    Downside is a little more bodyroll, which is easy to compensate for. No more racecar driving on the freeway for sharp corners or exit ramps.
    Mlofthou likes this.
