Sway Bar Delete Review
Discussion in '1st Gen. Tacomas (1995-2004)' started by arctic04trd, Oct 18, 2017.
  1. Oct 18, 2017 at 9:33 PM
    arctic04trd
    arctic04trd [OP] VA7XTE
    British Columbia
    2010 DCLB
    Ok guys, so I recently removed my sway bar...
    :crapstorm:
    This is intended to be an informative thread, and I will keep everyone posted and updated on my findings and opinions. For those of you looking to remove your sway bar, stay tuned.
    2004 Tacoma TRD SR5 5spd 4wd
    OME 882s
    OME Nitrochargers Front/Rear
    OME Dakars
    OME D43XL Add-A-Leaf
    285/75/16 Goodyear Wrangler Duratracs
    16x8 Pro Comp 87 Rock Crawlers w/3.75" B.S.
    ARB Bumper & Warn Winch
    Approx curb weight:
    ~4500lbs = ~1000lbs over stock.
    Initial observations:
    On Road.
    The most obvious reason for this controversial modification is offroad performance. And I can understand why. It definitely punishes the on-road prowess (if this truck had any to begin with) of these Tacomas. It drives much less controlled on the road, with an estimated 20-30% more body roll (butt dyno) in corners doing the posted speed limit. Anything exceeding that would "likely" ( :anonymous: ) cause 40-50% more body roll than if the sway bar were attached.
    Off-road.
    Unbelievably smooth. Washboard is like butter. Potholes are an merely a mental occurrence, not a truck-rocking obstacle. Before, I noticed a lot of side-to-side motion whenever hitting potholes with one tire. Also improved is dips and ruts. They now launch the truck into a smooth dive, with a controlled return. All in all, very happy with trail performance. Do NOT take off-road corners at speed. Additional body roll/suspension flex coupled with lack of traction will most likely careen your 2 ton mini truck into a sideways trajectory. This is fine, if it were not an embankment riddled with daunting conifers and looming larches. (Tamaracks. Though I'm unsure what you Americans call theses trees :notsure:)
    I will keep this tread updated with my findings. Today is the first time I had a chance to drive it without the sway bar, so I will let you know what the coming weeks/months bring. :mudding:
    Edited 18/10/17 - Typos
  2. Feb 10, 2018 at 8:29 AM
    arctic04trd
    British Columbia
    2010 DCLB
    Update: 10/02/18
    Drives great in corners. With the regear I have slowed down as well. Which is an awesome thing. I routinely now drive at the speed limit:D
    Looking into ADS or Icon coilovers. With the heavier spring included in those suspension setups I think the away bar delete will become transparent. Time will tell.
    Definitely recommend for those running 882 coils and nitrochargers. Love it so far :thumbsup:
  3. Feb 10, 2018 at 9:08 AM
    tony2018
    tony2018 Well-Known Member
    Would extending the sway bar work for both on and off-road? I know you can't use it off-road because of articulation but what if you could extend it.
  4. Feb 10, 2018 at 9:12 AM
    arctic04trd
    British Columbia
    2010 DCLB
    You mean the sway bar end links? Perhaps, but I think it would still limit wheel travel. And the links might be too long to provide and on road stabilization.....but I have zero experience.
  5. Feb 10, 2018 at 9:15 AM
    tony2018
    Hm, probably disconnect them when I'm about to hit a trail. Yeah, that might work.
  6. Feb 10, 2018 at 10:13 AM
    arctic04trd
    British Columbia
    2010 DCLB
    I looked for some. Removing it was cheaper :rolleyes:
  7. Feb 11, 2018 at 8:12 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    When I first installed coilovers, I removed my anti-sway bar and I really hated it on the highway. It felt like the slightest side wind would make the truck wander. Keep in mind this was before I installed the updated steering rack guide and did the steering shaft roll pin mod thing. Those 2 things would probably have helped a great deal. At that point I put the bar back on and left it alone.
    Later on I installed some wheelers offroad front super bumps. They are designed for a 2nd gen, but they can still mount on a 1st gen. These almost touch at ride height, but they compress much more than the stock bumps. I then removed my anti-sway bar and didn't notice a difference on the highway anymore. The ride was much smoother since without the bar, bumps from one side of the truck are not transferred over. I have been driving with this setup for about a year and I love it.
    Pictures under compression:
    rgljr831, BCbuggy and arctic04trd[OP] like this.
  8. Feb 11, 2018 at 8:16 AM
    tony2018
    so extended bumpstops, I was looking at sumo springs and tembren's bumpstops. Wonder if any 1st gen owners used these.
  9. Feb 11, 2018 at 8:17 AM
    arctic04trd
    British Columbia
    2010 DCLB
    I ordered energy suspension regular height. Plan on stacking a washer or two underneath. Still haven't figured out how to remove the old ones haha
  10. Feb 11, 2018 at 8:19 AM
    tony2018
    Are the studs on the ES long enough for you to use washers?
  11. Feb 11, 2018 at 8:20 AM
    arctic04trd
    British Columbia
    2010 DCLB
    I think so. But it won't be hard to buy longer ones. I haven't checked yet..
  12. Feb 11, 2018 at 10:05 AM
    Mkorsholm18
    Mkorsholm18 Active Member
    Martin
    Metro Atlanta
    03 Dcab TRD
    3in toytec lift 285/75/16 BFG KO2 16" Procomp alloys Full 4xinnovations skids
    You will notice the biggest difference (on road) if you tow or carry heavy loads in your bed.
    After I removed my sway bar, I hauled a 500lb motorcycle in the bed on the highway, and it was quite unstable.
    However it increased off-road performance astronomically. I would recommend it as well
  13. Feb 11, 2018 at 10:12 AM
    tony2018
    toss up indeed. thanks for the insight and review op and to rest of members too.
  14. Feb 11, 2018 at 10:12 AM
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    My personal recommendation is to leave the sway bar on, but remove the end links when hitting the trail.
    tony2018 likes this.
  15. Feb 11, 2018 at 11:50 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    I don't think you can just remove the links. It needs to be completely removed.
    Yeah. I'm kinda curious what the ratio of Tacoma's rolled into the ditch had this mod done... I'm sure it was partially to blame for my first trucks demise...
    I ran sans sway bar for 5 years. But recently re-attached it. It's going to stay on from now on. Too many close calls throughout the years. The trail has to be pretty dramatic for me to notice it on there. And if it's that hampering it takes 20 minutes to remove it.
  16. Feb 12, 2018 at 2:37 AM
    arctic04trd
    British Columbia
    2010 DCLB
    So ya think maybe speed was a factor? I know for a fact I drive way slower with these big tires and a regear than I did stock. And offroad I take it easy as well. I know the sway bar is a safety, but it's also remarkable what a little less skinny peddle will do for you. YMMV
  17. Feb 12, 2018 at 6:15 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    You can probably just disconnect one end link from the LCA and tie it off on the sway bar, save 15 minutes :)
    Wulf likes this.
  18. Feb 12, 2018 at 7:20 AM
    FirstTimeFirstGen
    David
    Pacifica
    You can absolutely just remove the end links. That's what i do when i hit the trail. The bushing tends to hold the sway bar in place or your lca will push it up if it drops too far.
  19. Feb 12, 2018 at 7:27 AM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
  20. Feb 12, 2018 at 7:38 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
