Sway Bar Disconnect from Front Range Offroad
Discussion in 'Group Buys' started by toutenhoofd, Dec 4, 2013.
Thread Status:
Not open for further replies.
  1. Dec 10, 2013 at 7:04 AM
    #41
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Yeah, they are, but I don't agree with the swaybar statement for IFS in their FAQs.
    I'd rather have the lighter wheel have some contact and some traction than none at all. Having the swaybar on, or locked if you have a disco, will give you less articulation and lift the wheels off the ground sooner. And that will stop you from moving forward if you don't have a diff lock or A-TRAC.
  2. Dec 10, 2013 at 7:15 AM
    #42
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    I have eibachs and i tried no sway bar for a bit, didn't really like it, handling was sloppy and there was too much body roll. Probably a good idea to keep if you drive mostly on road like myself.
  3. Dec 10, 2013 at 7:24 AM
    #43
    scocar
    scocar Patron of the Farts
    Yeah, I'm still trying to figure out why I'm not dead after a year and a half of mostly daily driving.... :rolleyes:
  4. Dec 10, 2013 at 7:33 AM
    #44
    BradyT88
    BradyT88 Well-Known Member
    I agree. I have had mine off for about a year and a half now and I don't exactly drive slow either. I am running 33's with a 3" suspension lift and a 1" body lift so I am not exactly short either. It there some sway in the corners, yeah, but most aftermarket coils have a much higher spring rate than OEM and counter that body roll decently. I don't think anybody I roll with runs sway-bars at all and we do just fine.
    If you have a linked solid front axle, I'm pretty sure sway bars equal "you don't die on a corner" but for IFS they are not nearly as important. IFS suspension doesn't flex nearly as easy as solid axle rigs do.
    Just don't drive a truck like a "racecar" and you will be just fine. (I put racecar in quotes because you can still do alright in a corner, just feel it out. Just don't expect your truck to corner like a car does, they are just too tall and heavy, even in stock form).
  5. Dec 10, 2013 at 7:41 AM
    #45
    scocar
    Precisely. Anyone driving their truck like it is a sports coupe is going to have trouble anyway.
  6. Dec 10, 2013 at 7:51 AM
    #46
    BradyT88
  7. Dec 10, 2013 at 12:01 PM
    #47
    stumpjumper509
    stumpjumper509 Well-Known Member
    spamuel
    50nasty
    02 dcab overland
    donahoe ext front tc arms arb with warn demello crusher slider/rear safari snorkel trd supercharged with mods cvt shasta air comp with tank battery charger dakars with rr hoes
    ^ ya see what happened was..... haha
  8. Dec 10, 2013 at 5:47 PM
    #48
    BradyT88
    That is a good argument. For what it's worth I didn't notice a change for the worse with the sway bar off, but I went from 5100's set at 0.85 with TRD Offroad coils and sway bar on to 5100's with 886's set at 0 and no sway bar. It had less sway in the latter, but maybe it would have had even less with the bar still on:notsure: On that note, not only are 886's stiff coils but they have a good amount of preload on them on 5100's so that is why I have less sway. My ORI's have significantly less sway than my 886's ever thought of. Seriously, they have almost no sway! But that is because we tuned them that way.
  9. Dec 10, 2013 at 6:01 PM
    #49
    bullaculla
    Da big big island!
    Yeah, high speed turns and sawing at the wheel while panic braking are completely different things. I have tried swerving while braking and my truck isn't too bad, and I'm not really a panicky type person anyway. Been a street biker for too long to freak about anything out while driving an automobile :D
  10. Dec 10, 2013 at 6:37 PM
    #50
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    Those are for the endlinks that attach to the LCA. Those unbolt with a wrench and an Allen wrench.
    When you Disco the Front half you can rotate the bar up and ziptie it up. I remember it took me awhile to find when to zip tie it and get it situated so it didn't contact anything.
    I used to disconnect the swaybar every trip. Then I just removed it permanently. Its been 3 years without it, No complaints.
    Anyone who claims the swaybar is better for offroad... Has clearly never wheeled an IFS truck with a swaybar and then without. I can see the argument that with the bar on it may shift the weight favorably... But that would only be in very limited instances. The extra 3" of travel you will get plus the ability of the tires being allowed to droop/stuff independently of each other defiantly make a huge difference. This is most apparent in off camber climbing instances. Without the SB you will gain a lot of stability and comfort.
    Watch the Front end move up and down. Then try to imagine the front end in the same situation with only an inch of travel. The truck would be a lot more offcamber and ride like shit.
    http://www.youtube.com/watch?v=3GdT5PSNHQ8
    http://www.youtube.com/watch?v=LqlDiAwJOqM
  11. Dec 10, 2013 at 6:46 PM
    #51
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    The quick disconnects are a great idea, no laying on your back trying not to strip an allen head. Takes you about 30 seconds to disconnect and then get ready to drive home. If I had a sway bar I would want one.
  12. Dec 10, 2013 at 7:31 PM
    #52
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    I have to say in the first video you took that ledge like a boss.
  13. Dec 10, 2013 at 7:41 PM
    #53
    toutenhoofd
    toutenhoofd [OP] Well-Known Member
    Nico
    Boulder, Colorado
    01 TRD Off-Road DC
    2.5" OME lift. 33" tires, sliders, ARB compressor, home-grown roof-top-tent.
    Well thus far it doesn't look like we will get 10 people, which is a drag. I personally like the safety of having a sway bar for my highway driving, and like the idea of being able to disconnect it before a hard trail run. I drive my family from Boulder, CO, to Moab, which is quite a bit of 70mph driving.
    Anyone else interested? Please chime in if you are, or send me a PM.
  14. Dec 10, 2013 at 10:46 PM
    #54
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    i'm definitely on board with the idea of disconnects -- most of my driving is on the road, and definitely don't want to run without one for highway driving. just need to see how they'd work in actuality, you know?
  15. Dec 11, 2013 at 5:26 AM
    #55
    toutenhoofd
    Nico
    Boulder, Colorado
    01 TRD Off-Road DC
    I'm the original poster and I'd post a photo of one installed, and/or a video, except that I've never seen one installed and I have no photos or videos. I'm just a Taco owner who wants one. I couldn't find any companies currently making them so I contacted Front Range Offroad. They said that demand wasn't great enough anymore and they stopped making them, but that if I managed to get 10 orders, they'd make a batch.
    Thanks.
  16. Dec 11, 2013 at 8:52 AM
    #56
    scocar
    Theoretically, I love the idea. One of my favorite areas requires several hours of highway driving in mountains followed by a multiday wonderland of offroad trail opportunities. Quick disconnects would be ideal for this sort of use.
    Nevertheless, I think the biggest issue will be where do the bar ends reside when not attached. Again, I checked this out on mine, checked the range of motion, and was very concerned that when disconnected, they would interfere with brake lines and suspension components. That's when I decided to just remove it on a trial basis and cautiously test how it handled with my 881s.
    Yes, there is a l slight difference with a little more roll/corner dive. But not so much that I have even worried about it. I drive really conservatively anyway with plenty of space because everyone on the road is retarded. That's a given. But I have tested evasive maneuvers with it and felt fine. For off-camber higher speed curves, I may back off a little more than I would with a swaybar, but that is more just a comfort issue, not a control issue. Same goes for roads I am not familiar with. I swear that I would be more concerned about my safety doing evasive maneuvers with weak worn out stock spring and shocks. I have virtually forgotten that it is gone.
    Further, I believe the early first gens and later first gens actually have 2 different end link styles, so one style of disconnects would be required for earlier first gens, and another for the newer style.
  17. Dec 11, 2013 at 9:20 AM
    #57
    BradyT88
    I am in your same boat basically. I drive about an hour each way to my wheeling spots and both of which are on the interstate, besides the fact that my Tacoma is practically my DD and there are a lot of windy roads in Idaho.
    Luckily I have not had to make any evasive maneuvers on the road, likely due to more conservative driving like you said, I very very rarely speed, if anything I usually do like 5 under the speed limit. I have had to make several at high speeds while offroading (usually finding a corner you didn't see until you are on it or that a corner is a lot sharper than it looked before) and it still handled those situations well. I have scared myself on a few occassions:anonymous: but I never felt that having the sway-bar would have helped those situations, mostly just because you still have sway with a sway bar and once that sway is maxed out you lift a wheel off the ground. I won't lift that wheel until I run out of droop/stuff.
  18. Dec 11, 2013 at 9:33 AM
    #58
    xcmtb83
    xcmtb83 Well-Known Member
    Iowa
    http://www.wabfab.org/component/option,com_virtuemart/Itemid,110/
    I have read a lot of mixed reviews about this guy but if you are set on getting some it might be worth inquiring.
  19. Dec 11, 2013 at 9:33 AM
    #59
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    ^ This.
    Known casually as the "Moose Test." It's my understanding that a stock Tacoma will pass the moose test with the sway bar on, without it, it will fail. I think it's really that simple. :D
    And sorry to the OP, thread has gone sideways. :laugh: :p
  20. Dec 11, 2013 at 6:37 PM
    #60
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Yes, a stock Tacoma without the sway bar will fail obviously. But that's not what we're saying. We are talking about aftermarket coils without the sway bar. Completely different beast.
Thread Status:
