Sway bar disconnects
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AlaskanTaco, Dec 17, 2011.
  1. Nov 4, 2012 at 11:03 AM
    Johnsredline
    Johnsredline Well-Known Member
    North Las Vegas
    Barcelona Red- Method Double Standards, Flowmaster Exhaust, K&N intake, black headlights and raptor style grille, ICON stage 4 suspension, allpro sliders
    I had given that thought. But I believe its easier said than done.
    One, because accessing the middle of the swaybar while on the truck is very difficult. Two, the swaybar takes some significant pressure I think finding pins etc that wont break would be challenging.
  2. Nov 4, 2012 at 11:17 AM
    YFZ450MOE
    YFZ450MOE When you blow off steam you get an eyepatch
    Moe
    Auburn, WA / Roseburg, OR
    09 white DCSB TRD (it's getting there)
    Icon Extended Travel 2.5" Coil Overs All-Pro U-Bolt Flip Kit Bilstien Rear Shocks Fabtech Add-a-Leaf Icon Upper Control Arms All-Pro Rear Bumper w/ Wrap Arounds & Hitch with custom LED plate light BHLM and Morimoto III D2S retrofit Satoshi Grill 2 Hella Black Magics behind Grill Bestop Supertop BAMF sliders
  3. Nov 4, 2012 at 11:17 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Yeah. In addition to difficulty accessing the middle, once disconnected, it'll be unstable because each side has only a single pivot point.
    I think the single end disconnect concept we've been discussing is the best overall general plan.
  4. Nov 4, 2012 at 11:22 AM
    YFZ450MOE
    Moe
    I may have to mount the middle bar part somehow moose.
  5. Nov 4, 2012 at 11:26 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    You can try.
    Just remember the bar has that bend in it. So the middle swings through an arc, rather than simply rotating in place like an axle.
    That'll make it harder.
  6. Nov 4, 2012 at 11:29 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I understand what you're thinking of, at least I think I do. You want to keep the sides connected at all times but the center is cut and you want to use a pipe with pins in it to connect the 2 halfs.
  7. Nov 4, 2012 at 11:33 AM
    YFZ450MOE
    Moe
    yep just noticed that. And things just took a turn for the worst.
  8. Nov 4, 2012 at 1:47 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Here's the other thread we've been discussing this on:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/48150-automatic-sway-bar-disconnects.html
    and
    http://www.tacomaworld.com/forum/bay-area-metal-fabrication/219398-swaybar.html#post5794037
    I've been in brief contact with a guy who formerly made these for FJ Cruisers. Because of a combination of limited demand and potential liability, he is NOT selling them any more. He gave me a couple of pics (I don't currently have permission to share; I asked) that make me think that the one pic above that we've been bandying about is his work.
    Now, Jerry from BAMF is very busy and doesn't have time to design these from scratch. But I think if we give him a design and perhaps pay a little extra denero up front for some time on the mock up and tooling, he still might be able to come through for us.
    So if you think you'd be serious about laying down - say - $250 plus your existing sway bar as a core - post up on that thread in the BAMF forum to let him know you're interested and serious. And that's just a number I pulled straight out of my ass. So don't give him or me any sh*t later if it turns out to be a totally off base number, OK? :D
  9. Jun 18, 2017 at 2:29 PM
    mntnbomber
    mntnbomber Active Member
    Travis
    Simi Valley
    07 PreRunner SR5
    I know this is an old one, but has there been any progress on this?
  10. Jun 18, 2017 at 2:58 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Just removed my bar a couple days ago. Love it!!!!!!!!
    Tridet167 and mntnbomber like this.
  11. Jun 18, 2017 at 3:52 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Nope.
    I cut the sway bar - fabbed up various pieces of flat steel to make a boltable/removable attach/detachment point, and took it to a welder.
    Trouble is, sway bar is tempered high carbon spring steel. So welding it is likely to fail and like pretty much all welders who are asked to weld springs, this guy refused.
    Someone else was going to try and cut it in the middle and install a pivot by attaching it mechanically. Trouble is, the bar doesn't pivot around the axis of the middle part of the bar. So when disconnected, that would end up creating a weird wildly gyrating bar that would bend and eventually break its attachment points.
    Short answer is:
    If it's a daily driver that sometimes goes on trails, leave it on and be happy.
    If it's a trail rig that you sometimes take on the street, take it off and be happy.
    OutbackHack and mntnbomber like this.
  12. Jun 18, 2017 at 3:58 PM
    02YotaGuy
    02YotaGuy Guy With A Red 80 Series
    Matthew
    Springfield, VA
    94 FZJ80
    Bumper, Winch, 315s, Sliders, OME HD lift, Custom rear swingout, roof rack, drawers, way too much to list.
    I removed my sway bar a few months ago,
    I'm still alive...
    Bebop likes this.
  13. Jun 18, 2017 at 4:32 PM
    Bebop
    Nick
    I don't see why everybody thinks your gonna die if you remove the sway bar. Anybody that has spent time in an auto shop will tell you that every Ford F-150 made from 1995-2006 has bad sway bar links and the bar does absolutely nothing, any kind of chevy truck from 2005 and up does the same thing. People drive around without the sway bar all day long and don't even know it. Don't even ask about the ford exploder
  14. Jun 18, 2017 at 5:25 PM
    mntnbomber
    Travis
    Simi Valley
    07 PreRunner SR5
    Just curious, have you tested how it handles in emergency maneuvers? Like swerving around freeway debris or a sudden stopped car in front of you?
  15. Jun 18, 2017 at 5:29 PM
    #35
    02YotaGuy
    Matthew
    Springfield, VA
    94 FZJ80
    I have, it's a little scarier and the body roll is more noticeable but I rarely use freeways and I always maintain a safe distance from the cars in front of me.
    mntnbomber[QUOTED] likes this.
  16. Jun 18, 2017 at 10:25 PM
    #36
    TexasTacoLT
    TexasTacoLT Well-Known Member
    Killeen, TX
    '14 TRD Offroad
    3" Lift (ToyTech Coilovers and AAL) Bilstein 5100 Shocks Total Chaos UCAs Method Double Standard 17" BFG All-Terrain T/A KO2 (Removed) 33" BFG Mud Terrain Tires Colormatched Grill surround HomerTaco mesh grill insert Legacy "Toyota" Emblem Shrockworks plate rear bumper All-Pro plate front bumper w/ foglights All-Pro rock sliders Smoked Tail-lights DIY Steel Tailgate reinforcement Locking Tailgate handle Tint (15%) w/ sunstrip Tyger Tonneau cover (Removed) Bestop Soft Topper Bushwhacker colormatched fender flares DIY 8-ball shift knob DIY Amber LED grill lights DIY Debadged WeatherTech floormats Sudued US Flag door decals T-100 style tailgate decal Two way radio w/ 3' whip antenna Warn 8000lb winch CalTrend Neoprene seat covers DIY Bed tie-down anchors
    I removed my sway bar about six months after I bought my truck. So, I've been running without it for over three years now. First thing I did was go to a big empty parking lot and test it to get a feel for how it felt during "emergency maneuvers". During quick, dramatic maneuvers, the body roll is noticeably exaggerated, but not to the point where I would call it dangerous. Granted, I wasn't doing 65MPH in the parking lot as I would be on a highway. I have however, had to take evasive action on several occasions on the highway, at highway speeds and the truck felt perfectly fine and I never felt like I was going to roll or lose control. I have a lot of added weight over the front axel, and during normal driving the difference is barely noticeable. I'd say being cognizant that your sway bar is not there and adjusting your driving accordingly is more than enough to mitigate any added body roll.
    WPNZ, flying_waitacoma and mntnbomber like this.
  17. Feb 27, 2018 at 11:54 AM
    #37
    TrabFTW
    TrabFTW Active Member
    Bart
    14 Tacoma TRD PreRunner Sport
    Pulling this thread back up again. What about when towing a small pop up trailer on twisties? Anyone tried that?
  18. Feb 27, 2018 at 12:08 PM
    #38
    Pigpen
    Dan
    Northwest Montana
    I tow a lot in the mountains. A camper, my raft and associated gear, firewood...I've never missed my sway bar with my 885 coils or when my stock coils were preloaded on the 1.75" 5100 setting.
    WPNZ likes this.
  19. Feb 27, 2018 at 12:14 PM
    #39
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Does this count?
    The trailer adds weight to the front (using a WD hitch) so if anything the truck is more stable with less body roll.
    WPNZ likes this.
  20. Feb 27, 2018 at 12:20 PM
    #40
    TrabFTW
    Bart
    Excellent! Thanks!
