Sway Bar End Link Quick Disconnects?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by therealprotaco, Jul 19, 2019.
  1. Jul 19, 2019 at 8:29 AM
    therealprotaco
    therealprotaco [OP] Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock Tundra TRD PRO DC
    I saw a thread about end links on the 2nd gen forum so I am assuming the situation is the same for 3rd gens but is the only reason no one is running quick disconnects on the front end link an issue related to where to put the sway bar when they are disconnected? Has anyone figured this out yet and installed a set of quick disconnects?
  2. Jul 19, 2019 at 8:31 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yep. There's a guy in the BST section that was selling some cool sliding QDs. Although the last time that I looked, they were gone. I will see if I can find it.
    That said, I believe that it was found that the Sport and Pro share the same sway bar part number. That thing is stupid stiff. Combined with the Sport springs, it was overkill. SB delete was a massive cure for me.
    Edit: Here's the thread:
    https://www.tacomaworld.com/threads/sway-bar-links.470412/page-2#post-14608189
    It doesn't look like the OP has them listed for sale. You might want to hit him up though.
  3. Jul 19, 2019 at 8:33 AM
    aaen
    aaen Well-Known Member
    Northern Alberta
    2016 DCLB 4x4 TRD Sport BBP
    Kings, ARB Summit Bumper, SMittybilt Winch, vagabond Drifter, Prinsu Cabrac, Crusinoffroad slidersand rear bumper
    Yup I took mine off as well, made the body roll a lot more noticeable and well I'm not taking off ramps at high speeds not that I ever did but it's worth noting.
    therealprotaco[OP] likes this.
  4. Jul 19, 2019 at 8:33 AM
    therealprotaco
    Gilbert, AZ
    I definitely don't want to remove it all together since I do a decent amount of street driving but disconnects seem like the easy "cure". I'm just not sure why none of the normal sources have offered them for our trucks unless there is a good reason.
    tonered[QUOTED] likes this.
  5. Jul 19, 2019 at 8:38 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I hustle around corners until the tires howl. I also let it drift in wet. Recently, I've also had a few quick emergency swerves. With the Sport springs (700lb?), I have yet to come away with any pucker factor. That is just me though. You should definitely do what makes you feel right.
    It does sound mall-crawly, but every time I go over the curb into my driveway at an angle, the more I appreciate the SBD. The fam feels the same way. LoL!
    There have been a couple interesting proposed mods, but I had big reasons not to like them. Those in the link above get my $0.02 approval. :D
    I did have a chance to drive a stock OR recently. There is a completely different feel there, and I would leave the SB alone if staying stock. I have no idea how a Pro feels.
  6. Jul 19, 2019 at 8:40 AM
    hoch
    hoch Well-Known Member
    Desert
    18 DCSB OR 6MT
    I had some on an old Tacoma. Sway bar kept clanking around, so I never ended up taking it off. Helped a little in articulation, but not enough to justify it. Hard pass for me. If I were doing hard trails on a regular basis, I'd be inclined to just remove it permenantly.
    If you do it: Some people bungeed the sway bar out of the way. But some were unfortunate and it ripped up the CV joint.
  7. Jul 19, 2019 at 9:51 AM
    Dr. Emmett Brown
    Dr. Emmett Brown Well-Known Member
    I've had mine off for 6 months now. Only time I ever got sketched was on the highway doing 85 on a slight bend and I hit a small dip and the truck felt like it got a little air. When I landed/had full weight on the ground again, the body roll was insane.
    Other than that I've never had an issue with my sway bar being off. Feels amazing off-road and going over bumps when one tire hits the bump first.
    Amchuge and tonered like this.
  8. Jul 19, 2019 at 9:59 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    We got something like that here:
    https://goo.gl/maps/o2fn5Wv4AGkG99C28
    The exit is marked at 50mph. Anything but a Model T can roll through it comfortably in the rain at 60.
    The dip is probably due to some soft soil. Only when I hit it at about 70 does the Taco hit the bump stop. It will do one wallow, then continue on. At 75-80 or so on my motorcycle, it feels about as (not) good.
    Prior to with the sway bar, it was just a corner.
  9. Sep 16, 2019 at 3:40 PM
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    someone needs to make a sway bar disconnect like what the Jeeps have with the antirock sway bar setup.. just needs to be flipped to the front and I like the idea of a locking hub being used.. or even something as simple as a splined slip sleeve that you can pull to allow articulation, and release to lock in the swaybar...
  10. Sep 30, 2019 at 4:57 PM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    There were projects that looked into using the jeep disconnect, I think I saw one successfully graft it to our bar. It's a lot of trouble just to stay clean and the parts are expensive.
    Personally, I like a firm grip on the road, removing my sway made the truck more unpredictable. I put the Toytec spacers on them and called it a day.
