Sway Bar + Garage Fire = ????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BKinzey, Apr 1, 2025.
  1. Apr 1, 2025 at 1:02 PM
    BKinzey
    BKinzey [OP] Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    Had my sway bar stored in the garage. Garage (and house) burned to the ground. I'm thinking of reinstalling a sway bar to the Taco and wondering how the heat may have affected the sway bar? Temperature was high enough to melt most aluminum items, others malformed.
    I had my OEM shocks w/springs stored in the garage too, those springs look funky enough I figure they are shot but the sway bar "looks" fine.
    What should I expect? Will the bar just be weak or will it snap? Could it be ok?
  2. Apr 1, 2025 at 1:12 PM
    MGMDesertTaco
    They don't cost that much to replace. Cheaper than what if and find out.
    SH10151 and hinmo24t like this.
  3. Apr 1, 2025 at 1:22 PM
    road2cycle
    road2cycle Well-Known Member
    Sonoma County, CA
    2014 Tacoma DCLB 4x4 Limited
    I think you already know the answer. Don’t chance it.
    O'DubhGhaill likes this.
  4. Apr 1, 2025 at 1:22 PM
    TacoTuesday1
    FL
    Upgrading to no sway bar is free.
    HWI and Ricardo13x like this.
  5. Apr 1, 2025 at 1:24 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    Attach a magnet to a string and go to the ocean. You’ll pull a couple for free :fistbump:
    inwood customs likes this.
  6. Apr 4, 2025 at 9:28 AM
    BKinzey
    Beauford
    Hollywierd, CA
    So I don't want to replace a sway bar if I already have one unless it is damaged.
    I had a sway bar, then I removed it. Now I'm thinking of putting it back on because for my use I'm not sure removing the sway bar was an "upgrade".
    b_r_o and O'DubhGhaill like this.
  7. Apr 4, 2025 at 10:13 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    I wouldnt use it. If aluminum stuff in your garage melted that means it got to around 1000 deg F. That is awefully close to the temps needed to heat treat steel.
  8. Apr 4, 2025 at 10:23 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    The sway bar would most likely still have the links attached, plus bushings. Those components are absolutely toast, and will be a pain to remove/replace after becoming toast. The bar itself - structurally should be okay for a short while. Funny thing about steel that has been in high temperatures though: it seems to be an open invitation for rapid corrosion shortly after exposure.
    I'd let it go.
  9. Apr 4, 2025 at 11:10 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Not to threadjack, just some nerd info on heat + rust -
    A few things are happening. One, any residual oils (even from the mill) are cooking out, leaving the steel completely bare. Two, carbon and other smutz will hold moisture against the steel. Three, depending on the alloy, there can be chemical changes to the affected areas that invite oxidation.
  10. May 13, 2025 at 2:19 PM
    BKinzey
    Beauford
    Hollywierd, CA
    Just a final resolution on this. I was offered one for free and I picked it up. That's when I noticed it had bushings on it. The burnt bar has no trace of them. They melted off. So the bar was basically useless to me.
    Thanks for the info.
    SUMOTNK and deanosaurus like this.
