Sway bar in the way??
Discussion in '5 Lug' started by 5luggertaco, Aug 13, 2017.
  1. Aug 13, 2017 at 8:31 PM
    5luggertaco
    5luggertaco [OP] Active Member
    Gio
    California
    2015 Storm Trooper White Base
    2.5 Icon Coilovers Total Chaos Control Arms 265x75r16 All Terrain 16 Blk Method Wheels Limited Slip
    hello fellow 5 lugger crew,
    Im having an issue with tire clearance (265x75x16) and need some guidance. Everytime I make a turn a hear a loud clicking sound which I believe is hitting the sway bar. I make sure the black box was removed and with the excess plastic so it cannot be that. So my question is should I remove the sway bar? and if so how would it effect the balance or the truck? or just ignore the issue.
  2. Aug 13, 2017 at 8:31 PM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Is there any sign of rubbing on the sway bar?
  3. Aug 13, 2017 at 8:35 PM
    5luggertaco
    Gio
    California
    their is a small amount on it. Will post some pictures tomorrow
  4. Aug 13, 2017 at 8:36 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    I removed mine and love it. A little more body lean but no more rocking when you go over a bump. Do you have upgraded shocks?
    SocalOC likes this.
  5. Aug 13, 2017 at 8:37 PM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    Do you have aftermarket shocks?Do you have sway bar relocation kit?
    Sway bar obviously affects your trucks body roll and sway when turning. Many people run without it. Many feel safer with it. It's up to you and how you drive
  6. Aug 13, 2017 at 8:40 PM
    5luggertaco
    Gio
    California
    I have some icon 2.5 coilovers up front and aftermarket control arms. but I did not install a sway bar relocation kit... let me look into that thanks dude
  7. Aug 13, 2017 at 8:42 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    oooooooohhhh your running mid travel... I'd say remove the swaybar if you dont like how it handles try to find a relocation kit.
    5luggertaco[OP] likes this.
  8. Aug 13, 2017 at 8:44 PM
    Radarninja
    Northern California
    06 taco
    If have two sets, one new one used. $15 and $10 plus shipping respectively if you want.
    Good luck either way.
    5 Lug Fury likes this.
  9. Aug 13, 2017 at 8:50 PM
    5luggertaco
    Gio
    California
    let me see if I have time tomorrow to remove the sway bar and see how it handles but thanks for the offer
  10. Aug 13, 2017 at 8:50 PM
    Radarninja
    Northern California
    06 taco
  11. Aug 13, 2017 at 11:19 PM
    SamGoingHam
    SamGoingHam IG: SamGoingHam
    Sam
    Phoenix, Arizona
    2014 TACO 5LUG LOCKED
    Take that shit off. Especially with mid-travel, you'll truly feel the front suspensions working independently instead of being linked together by the sway bar. Body roll won't even be much of a problem since you're running such a heavy duty coilover.
    You have time. Takes 15mins max to remove it. It's only connected by 2 brackets and 2 rods I think.
  12. Aug 13, 2017 at 11:20 PM
    SamGoingHam
    Sam
    Phoenix, Arizona
    That's Sexy AF Bro
