Sway Bar Issue
Discussion in 'Suspension' started by AFButters, Oct 10, 2009.
  1. Oct 10, 2009 at 6:36 PM
    AFButters
    AFButters [OP] Rigger, Please!!
    "Butters"
    Albuquerque, NM
    2008 335xi BMW
    I took the sway bar off of my truck when i installed my OME Lift, well today i was cleaning out the garage and noticed that one of the joints had a small hole in it and the grease/lube inside the joint has leaked out.. it appears from moving it around there was still some inside.. is there anyway to fix this easily.. or is my sway bar f**ked.. you know incase i wanted to put it back on again at some point
  2. Oct 10, 2009 at 7:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Just replace it. Its an end link.
  3. Oct 10, 2009 at 8:17 PM
    AFButters
    "Butters"
    Albuquerque, NM
    2008 335xi BMW
    its not the end link its the middle link
  4. Oct 10, 2009 at 8:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    WTF are you talking about?
  5. Oct 10, 2009 at 8:37 PM
    AFButters
    "Butters"
    Albuquerque, NM
    2008 335xi BMW
    its the second joint.. not the very end one
  6. Oct 10, 2009 at 8:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its one peice, Man...Its an "End Link" or "Stabilizer Link Assembly". Dont sweat it, and if you are gonna run it, get a new one.
  7. Oct 10, 2009 at 8:49 PM
    AFButters
    "Butters"
    Albuquerque, NM
    2008 335xi BMW
    aight thanks chris..
  8. Oct 10, 2009 at 8:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  9. Oct 10, 2009 at 8:55 PM
    DTacoms
    DTacoms Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
    I had similar issue. The rubber at the joint connecting to the knuckle got torn. Do I really need to replace it or is it ok to continue running with it? How much does it cost?
    I see some guys removing the sway bars, so having a sway bar with this condition may be better?
  10. Oct 10, 2009 at 8:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its not a big deal if it gets torn. It will still work. You might get a clunking noise from it, but if it gets bad, just replace the end link.
  11. Oct 10, 2009 at 9:52 PM
    DTacoms
    Frisco, Texas
    05 4x4 DC LB BSP
    I'll take your word Chris. Thanks.
    But, I will Toyota extra care to see if they'll cover it.
  12. Oct 10, 2009 at 9:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good idea.
