Sway bar keeps coming loose
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ronixtaco, Sep 25, 2016.
  1. Sep 26, 2016 at 1:53 PM
    #41
    TakeNoteS
    TakeNoteS Well-Known Member
    Luke
    Kalama Washington
    2022 Silver Taco SR5 LB 4X4
    well best of luck to you ! :burnrubber:
    ronixtaco[QUOTED][OP] likes this.
  2. Sep 26, 2016 at 1:54 PM
    #42
    ronixtaco
    ronixtaco [OP] Instagram @la_redtaco
    Brandon
    Central Louisiana
    25 SS Red TRD Sport 4x4
    also talked with another tacoma owner, he has a 15 also and had to flip his back around to factory position because of steering vibrations
  3. Sep 26, 2016 at 1:54 PM
    #43
    ronixtaco
    Brandon
    Central Louisiana
    for sure, thanks!!
  4. Sep 26, 2016 at 3:00 PM
    #44
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    My ProComp lift, yeeeeeeaaaaaarrrrrs ago, had it in the factory position. The end of the threads on, of the link had to be trimmed some, to clear the coil. Other than that, no steering issues. The link's boots didn't like the angle though. Adjustable swaybar end links can fix that.
    ronixtaco[OP] likes this.
  5. Sep 27, 2016 at 8:25 AM
    #45
    ronixtaco
    Brandon
    Central Louisiana
    Thanks!!! I've talked to 5 or 6 Tacoma pro comp lift owners and they all have different thoughts about it also, some can run it flipped and some can't, weird. Anyway thanks for the info :)
  6. Sep 27, 2016 at 8:33 AM
    #46
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yes sir.
  7. Oct 15, 2023 at 4:58 PM
    #47
    Bange1
    Bange1 New Member
    Bob
    2016 Tacoma TRD Sport
    2" Rough County Leveling Kit 1" Pro Comp Rear Block 265/70/17 Toyo Open County AT 2's 17x8 TRD Wheels 2017 TRD Pro Grill Sits with 3/4" positive rake.
    I have the same ProComp 6” lift on my 2021. My sway bar link keeps coming loose. It appears to be a design error. The upper sway link attaches directly to the knuckle. ProComp tapped a hole to thread the link into vs the OE nut and bolt assembly. There’s no way to achieve the factory torque spec with a 6mm hex head. It’s unfortunate and a big over look by ProComp. I used thread locker today. Hopefully it holds.
  8. Oct 17, 2023 at 5:57 AM
    #48
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    ProComp drilled/tapped a new hole in your spindle?
  9. Oct 17, 2023 at 6:05 AM
    #49
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^6" lift kit includes taller Pro Comp spindles/knuckles.
    Use aftermarket links, Mevotech TTX or Moog. They have wrench flats at the base of the stud. Thread them into the knuckle with Loctite.
