Sway Bar link broke Dealerships fault!!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Country, Jun 26, 2012.
  1. Jun 26, 2012 at 10:45 AM
    Country
    Country [OP] Well-Known Member
    Country
    East Texas
    2010 Dbl.-Everyone says it looks like a tank
    Pro Comp 6in lift w/ Icon Coilovers,AllPro UCA's, AllPro Baja Leaf pack, Bilstein 5150's in the rear. Tires Mickey Thompson MTZ 275/70R18 w/ procomp 7089 wheels. ARB front bumper with mile marker winch, Custom made all quarter inch steel rear bumper. Demello rock crusher slider's. CoverKing neoprene seat cover's, AllPro trail armor All-pro U-bolt flip kit with Timbren bump stops and many many many other mods, way to many to list.
    Classic Toyota of Tyler broke my sway bar link and half of the link shaft is still stuck inside the spindle. My stealership will not fix there mistake. I need help on how to get this out, I am installing the ALL Pro's heavy duty sway bar links and cant do so until I get that broken shaft out. I have Pro comps spindle on and its hollow all the way through, I tried using a punch and pushing it out and it wont budge. Please send me some ideas on how to get this out.
    Thank you
  2. Jun 26, 2012 at 10:46 AM
    98tacoma27
    Ben
    Not Beech Creek
  3. Jun 26, 2012 at 11:08 AM
    Country
    Country
    East Texas
    I cant really get any pics of the broken shaft but I do have pics of the entire front looking at the sway bar link and cv boot, I will upload them now
  4. Jun 26, 2012 at 11:09 AM
    98tacoma27
    Ben
    Not Beech Creek
    I'm pretty sure I know what you're talking about, I just want to verify I'm on the same page.
  5. Jun 26, 2012 at 5:02 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    And they broke it but won't fix it why???
  6. Jun 26, 2012 at 5:10 PM
    98tacoma27
    Ben
    Not Beech Creek
    Judging by pic 3, it's been broken for a while. Try soaking it with PB blaster and then driving it out. You can also try drilling it out.
  7. Jun 26, 2012 at 5:13 PM
    Ryanv
    Ryanv Toyota Technician
    15 4Runner
    Looking at the rust on the end of the broken link I would guess its been broken for a while. If you cant get a allen key into the other end and wind it out the only way to fix that is drill and tap. Inside the spindle is threaded, if you try the hammer and punch method you will be there a very long time.
  8. Jun 26, 2012 at 5:23 PM
    Tacoma Mike
    Southern Maine
    How do u know THEY broke it ???
    That's been like that for a while.
    What did they work on ????
  9. Jun 26, 2012 at 5:28 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    And if they refuse to fix it, why didn't you press it further? What makes you think they broke it? Why is it rusty on the end so soon?
  10. Jun 26, 2012 at 5:30 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    My guess too...And I lack finesse-A drill would be my answer...
  11. Jun 26, 2012 at 5:32 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Ball joint press maybe. or smack both sides of the spindle at the same time with sledge hammers.
  12. Jun 26, 2012 at 5:32 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    since when is the spindle threaded? half the time when i put the nut on it, the shit spins which means there aint no threads in the spindle. you have to hold the "bolt" in place with an allen key while u screw the nut on.
  13. Jun 26, 2012 at 5:37 PM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    This
  14. Jun 26, 2012 at 5:37 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
  15. Jun 26, 2012 at 5:37 PM
    AcadianTaco
    AcadianTaco Well-Known Member
    Vince
    N.B. Canada
    2015 AC TRD OFFROAD
    OME 885X with Bilstein 5100, Dakars with 5125, Wheeler's bumpstops, LR UCA
    I would soak with a good penetrating oil (PB Blaster may be one) use a center punch (mark center of shaft), small pilot hole ( 1/8 drill or smaller), Then drill bigger hole and use an easy out. Drill bit need to match the easy out. If that don't work then driil and tap. Most important be patient. All this assuming the remaining shaft is threaded. I would prefere to remove the existing shaft than to retap. Tapping would be my last option but it may need to be done. Also use good quality drill bits. If not threaded soak and punch out or drill out starting with a centered pilot hole. I've been in your situation a few times. Good luck
  16. Jun 26, 2012 at 5:38 PM
    EL TACOROJO
    BURRY
    south mills NORCAK
    The dealership will not fix shit that they didnt break. Man up and fix it yourself
  17. Jun 26, 2012 at 5:39 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    The stock spindle is not threaded. The sway bar link is tapered and the nut threads onto the end of the tapered link. Nothing threads into the spindle.
    But, he said he has ProComp spindles so maybe their different (maybe causing the problem).
    And the broken end of the link is rusted, if it was a fresh break it would be shiny. The rust indicated the break or crack has been there for a while.
  18. Jun 26, 2012 at 5:39 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    It's not threaded in there, just a tapered fit. If you whack both sides at the same time, then hammer from the front with a punch and sledge, you'll knock it out eventually. You could also use a ball joint press in some manner.
    This all depends on you having taken off that nut on the front.
  19. Jun 26, 2012 at 5:41 PM
    wrmathis
    Bonaire, GA
    parts and stuff
    im pretty sure no spindles are threaded there. just tapered. mainly because you couldnt really start the bolt to get it threaded. it just pushes threw and you put the nut on, if for some reason it starts spinning the endlink, u use the allen key to hold it still while still tightening the bolt
  20. Jun 26, 2012 at 5:45 PM
    EL TACOROJO
    BURRY
    south mills NORCAK
    Open end wrench
    Allen wrench
    hammer
    a few minutes of time
    do that shit
