Sway bar link questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kens04Taco, Oct 24, 2017.
  1. Oct 24, 2017 at 6:24 PM
    Kens04Taco
    Kens04Taco [OP] Well-Known Member
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    hey guys so I bought a used swaybar off a Tacoma and it's 27mm thick. My truck didn't have a sway bar from the previous owner. I wanted to buy the bushinings for the frame mount and the end bar links that go to the control arm. I already purchased the brackets that hold the bushings to the frame from Toyota.
    Specs on truck
    2004 pre runner
    King coil overs set at 2.4 lift
    286/75/16
    I keep getting different links online and I was hoping someone could help clarify which ones I need?
    I wanted to buy energy bushings for the frame but they don't make end links. Any help would be appreciated as I'm trying to get the parts and install before November 3rd (road trip) thanks again .
    -update-
    (Just purchased the bushings for the frame, just need endlinks)
  2. Oct 24, 2017 at 6:49 PM
    Glamisman
    Glamisman Well-Known Member
    I would use the factory frame pivot bushings becqause they have a feltish lining for a quite smooth opperation. The "High Performance" bright plaastic ones make more noise in my opinion... everytime the lower a arm moves the the sway bar moves and it forces the sway bay backwards slightly and can create a bang/thimp/call it what you want noise.
    Kens04Taco[OP] likes this.
  3. Oct 27, 2017 at 10:48 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    I bought some end-links from RockAuto in 2013 and 2014. Had a problem with one of them (the ball came out of its fitting). RockAuto promptly issued me a refund. I paid $25 apiece in 2014 (plus shipping).
    I think the shaft on all sway bar end links is too small for rugged, off-road use. I've broken 3 of them so far, and they break right where the round shaft changes into a hex fitting. :( Don't see why they are made with such a small shaft diameter.
    When I installed the first ones in 2013 I torqued the top nut to spec, leaving the rubber bushings rather flat and without any give at all. When I installed them in 2014 I didn't torque them at all. I tightened them so the rubber bushings were squished to about 1/2 their original height and so far, so good (knock on wood).
  4. Oct 27, 2017 at 11:00 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I've never broken one. But then again, I just took my swaybar off entirely...
    For rugged off road use, they limit wheel travel/articulation, and as you've found out, tend to break. I don't even run one on the road any more. Sure, it's got a tad bit of body roll, but it's a lifted 4x4 truck, I don't expect it to corner like a Lotus. :)
    If you're dead set on keeping a sway bar (fast desert runs n stuff), I'd custom make some end links using heim joints or something. Or, get a proper sway bar kit built for desert running.
  5. Oct 27, 2017 at 11:41 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
  6. Oct 27, 2017 at 1:25 PM
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    So I pruhased a set from rock auto (moog) with the zerk fittings. I won't have my sway bar on when I go wheeling it's more because it's my daily and I drive a lot so just trying to improve the daily drive. Eventually I'm just gonna make a heim link for the ends. Thanks for the info I'll make sure not to over tighten them.
    Thanks guys!
    jbrandt likes this.
  7. Oct 27, 2017 at 1:29 PM
    jbrandt
    Justin
    Full disclosure: I didn't take my sway bar off (full time) until my truck wasn't a daily driver anymore.
  8. Oct 27, 2017 at 1:34 PM
    eon_blue
    Azusa, CA
    @Kens04Taco I just took my sway bar off a few weeks ago, I think I still have the parts lying around if you need the end links. I'll check this weekend, we can meet up and I'll just give them to you if I still have them.
    edit: nm looks like you already bought them lol. I haven't noticed hardly any difference with my sway bar off and I DD my truck every day. The 600lb coils on the Kings seem to compensate for it pretty well.
    Ritchie likes this.
  9. Oct 27, 2017 at 1:36 PM
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    Aww man I wish I woulda known before I bought these moogs lol oh well maybe if you find them hang on to them for me and if mine don't work or blow up I'll have a back up lol. Thanks man you rock
  10. Oct 27, 2017 at 1:45 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
  11. Oct 27, 2017 at 2:51 PM
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    lol yup, oh really? I figured id throw it on and see if it helps. I'm running the stock coils that you get with the Kings. I don't remember what they are rated at
  12. Oct 27, 2017 at 2:53 PM
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    Sicyota04[QUOTED] likes this.
  13. Oct 27, 2017 at 3:10 PM
    eon_blue
    Azusa, CA
    Should be 600lbs, that's what mine came with
  14. Oct 27, 2017 at 3:11 PM
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    I get some pretty heavy body roll and it was worse with the smaller tires? Lol
  15. Oct 27, 2017 at 3:12 PM
    eon_blue
    Azusa, CA
    huh, maybe I'm just used to it lol. I also tend to drive like a grandma on the street so that may be it too.
  16. Oct 27, 2017 at 3:23 PM
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    Hahaha. :turtleride:
