Sway Bar Link Quick Disconnects?
Discussion in '1st Gen. Tacomas (1995-2004)' started by FirstTimeFirstGen, Jan 30, 2017.
  1. Jan 30, 2017 at 11:46 AM
    FirstTimeFirstGen
    FirstTimeFirstGen [OP] Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    Anyone know if there are sway bar end link quick disconnects for the first gems? Do people normally just remove them for off road purposes?
    Sandeman likes this.
  2. Jan 30, 2017 at 12:03 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Remove. Nothing out there that can be bought. Some people make their own. But none that I've seen I would run.
    FirstTimeFirstGen[OP] likes this.
  3. Jan 30, 2017 at 12:03 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    There used to be QDs for 1st gens, but i cannot recall who made them
  4. Jan 30, 2017 at 12:13 PM
    FirstTimeFirstGen
    David
    Pacifica
    I was googling them but can't seem to find them
  5. Jan 30, 2017 at 12:22 PM
    SafetyDang
    SafetyDang get your facts straight
    Dang
    Anaheim, CA
    DC with 4x4 & MT Conversion
    Swapped to Manual Trans & 4x4
    Wabfab made them but they changed a ton of money. Cheaper to make them yourself. At the time they only had them available for the 95-2000. The sway bar on these are different.
    Frontrange also made a set. Which is no longer available.
    You can remove the sway bar and buy stiffer coilovers. Or remove them before the trail 10 mins tops.
  6. Jan 30, 2017 at 1:55 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    They newer sway bar has ball links on each end.
  7. Jan 30, 2017 at 1:58 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    @mstudt makes them
  8. Jan 30, 2017 at 2:06 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Newer sway bar you'd just need to care a 19mm wrench and allen wrench. Or what ever size it is.
