Sway bar link removal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Country, Nov 12, 2015.
  1. Nov 12, 2015 at 12:20 PM
    Country
    Country [OP] Well-Known Member
    Country
    East Texas
    2010 Dbl.-Everyone says it looks like a tank
    Pro Comp 6in lift w/ Icon Coilovers,AllPro UCA's, AllPro Baja Leaf pack, Bilstein 5150's in the rear. Tires Mickey Thompson MTZ 275/70R18 w/ procomp 7089 wheels. ARB front bumper with mile marker winch, Custom made all quarter inch steel rear bumper. Demello rock crusher slider's. CoverKing neoprene seat cover's, AllPro trail armor All-pro U-bolt flip kit with Timbren bump stops and many many many other mods, way to many to list.
    my 2010 Tacoma sway bar link needs to come off for a replacement. The Allen bolt that goes into the spindle is so damn rusted that it won't budge. I have let it soak over night in GM penetrating oil (didn't have any yota penetrating oil ) also applied insane amounts of heat to it and shocked the spindle with a 5 pound sledge many times. The Allen bolt still won't budge, in fact I snapped my Allen key doing so.
    Any other ideas on removing it would be great, if not I will spend the next hour drilling through it
  2. Nov 12, 2015 at 12:21 PM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    Blow Torch works on everything
  3. Nov 12, 2015 at 12:23 PM
    Red Baron
    Red Baron Let's call it livabetes, no more die
    Aaron
    Lost on a roundabout
    07 Radiant Red DCSB
    Things with metal, dog hair, more metal and lights
    drill away good sir, or hack saw angle grinder it off if you are replacing it.
  4. Nov 12, 2015 at 12:25 PM
    Country
    Country
    East Texas
    Let me rephrase myself. When I applied insane amounts of heat to the spindle, it wasn't with a match! It was in fact with a torch that produces a blue flame of fire.
  5. Nov 12, 2015 at 12:26 PM
    Country
    Country
    East Texas
    The link is getting replaced, so destroying it is no big deal. Bit drilling through the Allen bolt is what I want to avoid
  6. Nov 12, 2015 at 12:29 PM
    Red Baron
    Aaron
    07 Radiant Red DCSB
    dumb question but do you have any bolt extractors? give it a good twist to break it or you can always try tightening to break the rust seal.
  7. Nov 12, 2015 at 12:32 PM
    Country
    Country
    East Texas
    My father may have some, I will try tightening it and see
  8. Nov 12, 2015 at 12:34 PM
    Red Baron
    Aaron
    07 Radiant Red DCSB
    good luck mang
  9. Nov 12, 2015 at 12:35 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    you did take off the nut already......right?
  10. Nov 12, 2015 at 12:56 PM
    Country
    Country
    East Texas
    What nut? There isn't one at the spindle. I have an aftermarket spindle from pro comp that accommodates my 6in lift;
  11. Nov 12, 2015 at 1:06 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    ooohhhhhhhh, I see. thought it was a stock sway bar link?
    got a welder? I'm a fan of just welding a piece of small bar stock, or even a another long bolt actoss the head of the stripped one, creating a "t-handle" on the bolt. typically, you can then either turn it out by hand, or smack the end of whatever you just welded on, to break it loose. i'll do whatever I can to avoid drilling out a bolt.
