Sway Bar Links
Discussion in 'Buy / Sell / Trade' started by mstudt, Jan 17, 2017.
  1. Jan 18, 2018 at 6:15 AM
    #41
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    It allows your front suspension to be more independent from side to side. look up what a sway bar does and then imagine it being removed.
  2. Jan 18, 2018 at 6:56 AM
    #42
    mstudt
    mstudt [OP] Well-Known Member
    Eugene, Oregon
    The sway bar isn't 100% disconnected so you don't have to worry about moving it out of the way. This disco is a sliding style rather than a traditional disco.
    I do, and I'll get one posted soon.
  3. Jan 18, 2018 at 9:45 AM
    #43
    synergy10
    synergy10 @synergy10.sd
    San Diego
    Cool, thanks Mike!
  4. Feb 6, 2018 at 7:01 PM
    #44
    feesquivel
    feesquivel Well-Known Member
    West Texas
    Interested, sent PM. How bad do the disco’s squeak?
  5. Feb 12, 2018 at 8:14 AM
    #45
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
  6. Feb 12, 2018 at 8:20 AM
    #46
    HCJ
    HCJ Well-Known Member
    Virginia --> Texas
    '05 Taco with not enough miles
  7. Feb 12, 2018 at 8:26 AM
    #47
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    HCJ[QUOTED] likes this.
  8. Feb 12, 2018 at 8:50 AM
    #48
    ilubtimmyhos
    ilubtimmyhos Brewer
    Adam
    Haymarket, VA
    2012 Blue Tacoma 4x4 Pre-Runner
    4x4 Conversion w/ FJ T-Case, King 2.5 Extended Travel Coilovers w/ JBA UCAs, King 12" 2.0 Smoothies w/ BAMF relocate in the rear, OME Dakar leaf pack, 4.56 gears w/ ARB air locker, Archive Hammer Hangers w/ crossbar brace, ARB Snorkel, Custom Bed cap w/ Roofnest Sparrow XL, Retrofit Headlights, Wrapped in 3M Satin Perfect Blue
    I would need a relocation kit with my new coilovers so I think I'm good just going to keep it off.
  9. Feb 16, 2018 at 9:39 PM
    #49
    Rowan11b
    Rowan11b Well-Known Member
    2017 dcsb trd or
    So with a set of these I no shit would have a quick disconnect sway bar and It wouldn't Jack up my CV?
    mstudt[OP] likes this.
  10. Mar 20, 2018 at 12:35 PM
    #50
    Ras61
    Ras61 Well-Known Member
    Arlington VA
    '12 4wd TRD Sport Dbl Cab
    Icons front, Bilstiens 5125 rear, 35/12.5/17 MT/Rs and some trimming
    First off, this looks awesome. I'm super interested. I have a quick question. When you say:
    "My standard links are what I always recommend. Having proper length links will perform very close to disco's, and you won't have to worry about anything. Plus with the standard links you have the option to add heim boots, and powder coat."
    What do you mean they will perform very close to disco's? You'll gain more flex over stock because they are shorter and hold tighter to the spindle than the whimpy, stock one?
    I ask because if the travel benefit of standards vs disco is minimal, I may just grab the standards.
    Thanks!
  11. Mar 20, 2018 at 8:36 PM
    #51
    mstudt
    Eugene, Oregon
    I've never had any solid proof that one is better than the other. I've been running my own non-disco links for about 4 years now, and wouldn't consider disco's on my own rig. I don't have enough proof that they're better than my non-disco links, and I'm lazy as f*ck. I haven't been in a situation as of yet where I thought I'd be better off with disco's, and don't think I will.
    A lot of people "think" they need disco's to be able to gain more flex, and this really isn't the case. If you think about how a stock Tacoma performs, it performs very well for what it is. Now, it performs very well for "stock", but we all want something that performs better than stock. When lifting a stock Tacoma we all think about things that need to be change. You add coil overs, UCA's, LCA's, better leaf springs, shocks, and longer break lines. What about the sway bar links? This is the most commonly overlooked suspension component because most don't think they matter.
    The position of a sway bar from the factory is in the position for a reason, because it works. Getting your sway back to that position will give what most people are looking for.
    Masonkv, Taco-Obsessed and HomerTaco like this.
  12. Mar 21, 2018 at 7:21 AM
    #52
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    @mstudt Are you continually making these or do you just offer them from time to time? I would like a set of extended length for my 98, but I need to wait until I get a few other projects finished up first.
  13. Mar 21, 2018 at 7:30 AM
    #53
    mstudt
    Eugene, Oregon
    I'm always making them.
    cali04intx likes this.
  14. Mar 21, 2018 at 7:32 AM
    #54
    boostedka
    James
    NM
    Sweet :thumbsup:
  15. Mar 22, 2018 at 1:00 PM
    #55
    BCbuggy
    BCbuggy Beautiful B.C
    Mission B.C Canada
    2014 White Tacoma TRD DCLB
    3inch lift 33’s Sliders
    PM sent :spending:
  16. Mar 29, 2018 at 2:11 PM
    #56
    feesquivel
    West Texas
    Are your extended sway bar links compatible with the sway bar spacers included in some coilover kits? I have an icon ext coilovers and it came with a spacer that goes in between the sway bar bushings mounts (pivot point) and frame.
  17. Mar 29, 2018 at 2:49 PM
    #57
    mstudt
    Eugene, Oregon
    Are you referring to the relocation kit? If so than that won't effect the fitment of the links themselves. That's installed when running larger coilovers so your sway bar won't contact the coils. But yes, my links will work just fine with the relocation kit.
  18. May 1, 2018 at 12:06 AM
    #58
    MarvinL
    MarvinL Well-Known Member
    2018 Tacoma TRD OR 4X4 DCSB
    subd, might get me a pair soon
  19. May 27, 2018 at 11:38 AM
    #59
    jtrue
    jtrue Well-Known Member
    SLC, UT
    2014 Super White Tacoma TRD
    Interested in a set of standard links for 14 Tacoma. Assuming it's for a full set of 4, 2 front/2 rear? Send me your PayPal info.
  20. May 27, 2018 at 11:48 AM
    #60
    Moogle
    Moogle Dyslexic Stanist
    Glen
    Alameda, CA
    07 Silver TRD Sport DCSB 4x4 6-speed
    Blood of virgins
    It's only for 2 front. You have a sway bar in the rear?
    mac_2_nite and CowboyTaco like this.
