Sway Bar Links
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jdgshred, Nov 9, 2020.
  1. Nov 9, 2020 at 5:56 PM
    Jdgshred
    Jdgshred [OP] Member
    Hello, I am having unstable driving conditions on my 2009 Tacoma. I have had outer tie rods, wheel bearings, lower ball joint and control arm bushings replaced. But did not fix the problem. I noticed I could easily move my sway bar links by hand, and it appears one of the boots on it is no longer sealed. Would this cause those problems? It has 145,000 miles and they have never been replaced
  2. Nov 9, 2020 at 6:04 PM
    Bishop84
    Bishop84 Well-Known Member
    Yes they will cause a loud knocking noise, they should be firm and not move easily.
  3. Nov 9, 2020 at 6:24 PM
    Jdgshred
    I notice a slight knocking/popping sound when I am turning, not necessarily going straight though. It seems like the connection to the sway bar is tight, but I can easily move the whole link back and forth with my hand
