Sway Bar problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stormtrooper37, May 16, 2012.
  1. May 16, 2012 at 10:55 AM
    stormtrooper37
    stormtrooper37 [OP] Nutts
    Tyler
    Baltimore MD
    Toytec 2.5 Bilsteins Tint Rims Tires Exhaust
    So my sway bar came udone some how and ended up ripping my cv boot . Has anyone had this happen before or was a sabatoged ?
  2. May 16, 2012 at 10:56 AM
    kirkofwimbo
    kirkofwimbo Say no to Bro
    Clayton
    Wimberley, TX
    ‘17 TRDOR DCSB
    Sabotaged
  3. May 16, 2012 at 10:56 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    What broke, the sway bar, the linkage, one of the bolts come undone?
  4. May 16, 2012 at 10:58 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Take that sucker off completely and be done with it.
  5. May 16, 2012 at 11:02 AM
    stormtrooper37
    Tyler
    Baltimore MD
    the sway bar bolt is gone thats it . theres no way that just came undone right
  6. May 16, 2012 at 11:03 AM
    stormtrooper37
    Tyler
    Baltimore MD
    only on the driver side
  7. May 16, 2012 at 11:05 AM
    Country101
    Country101 Well-Known Member
    NW Arkansas
    08 tacoma access cab V6 4x4 manual
    dirty truck mod, custom trailer scratch on tailgate, husky floorliners, OME Lift
    I dont see how it would come undone on both sides without you knowing. yeah, there are guys that say leave it off, it dont make any differance, but it does. You would have noticeable front end dive in a hard turn. I have an 08 access cab that I just had mine off of. I put it back on and there is a world of differance going around a street corner.
    Before you holler sabotage though, how did it come off? My wife's car tore both sway bar links off. She drives like a bat out of hell on a mission to hit pot holes at full speed. Her car had 175k miles on it when this happened though.Not saying that all linkages will last that long, but still.
    If one side came offby the linkage ripping loose or the bolt coming undone, it could work the other side loose fairly easily I would think. So it's a toss up.
    Got anybody pissed off at you or have you just been driving like a wife or doing some wheeling?
    Edit: Beat me to it. Ok, if you just lost the nut on one side, I'd say it just finally had enough and vibrated loose.
    got anybody pissed off at you or have you just been driving like a wife or doing some wheeling?
  8. May 16, 2012 at 11:12 AM
    stormtrooper37
    Tyler
    Baltimore MD
    i Mean i offraod a bit but idk seems odd to me for one side to come out
  9. May 16, 2012 at 11:14 AM
    Pugga
    Massachusetts
    F-150 Mod
    It probably loosened over time and, once loose and unchecked, backed itself out.
  10. May 16, 2012 at 11:19 AM
    stormtrooper37
    Tyler
    Baltimore MD
  11. May 16, 2012 at 11:25 AM
    Country101
    NW Arkansas
    Not that uncommon for something to back out over time if not done right.
    I put a new caliper on my wifes car before and after about 2 weeks she started complaining about a thumping when she hit the brakes. I didnt have time to mess with it so I sent her to a guy down the road and about 30 minutes later he called and said that one of the bolts had come out and the caliper was just flopping around in there........ Ooooopppps. :eek:
    That's why I am going back over all the nuts and bolts I messed with doing my lift once they have a few miles to get settled in.
  12. May 16, 2012 at 11:26 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Have you worked on your front end recently?
    After I installed my lift, mine came loose a couple weeks later.
  13. May 16, 2012 at 11:31 AM
    stormtrooper37
    Tyler
    Baltimore MD
    yea we put in bilsteins about a month ago so that could be it idk though while we are on the subject anyone know where i can get just the sway bar bolt ?
  14. May 16, 2012 at 11:32 AM
    Pugga
    Massachusetts
    F-150 Mod
    Stealership or pull the other side out and match it at a hardware store if you can (make sure you buy a strong enough bolt if you go through a hardware store).
  15. May 16, 2012 at 11:34 AM
    Country101
    NW Arkansas
    you mean a nut?
    If yours are like mine, the linkage has two bolts that swivel and turn and go through the sway bar and to the hole on the arm of the suspension.
    If that is what you need, I may have a nut that would work that came off of something else on my truck. I can check it and see.
  16. May 16, 2012 at 11:34 AM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2018 T4R & '95 SAS
    SAS, dents, & scratches
    take the other one off and match it? or toyota stealership???
  17. May 16, 2012 at 11:35 AM
    Seabass
    Seabass Chrome won't get you home
    Adam
    AZ
    '06 Sport 4x4
    Let's be honest... you really only care about your own rig.
    sway bar hax
  18. May 16, 2012 at 12:02 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    What exactly is missing? You keep saying "bolt" but there is no bolt there - there's a link end that's threaded and goes through the spindle. And it's held on by a nut. But unlike the "mission critical" ball joints and tie rod ends, it's not held on with a cotter pin, because you won't crash if it comes loose.
    At any rate, you can get whatever's missing at the dealer. They're small parts so it ought to be reasonable.
    And yeah, with you having installed new shocks a month before - I'd say that's for sure the reason that it came off.
  19. May 16, 2012 at 1:57 PM
    stormtrooper37
    Tyler
    Baltimore MD
    Thstd what i meant nut sorry
