Sway Bar Problem
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ede-taco, Jul 11, 2017.
  1. Jul 12, 2017 at 8:59 AM
    TacoSauceHB
    TacoSauceHB Well-Known Member
    Brian
    Rathdrum, ID
    2017 _TRD Off-Road DCLB 4X4 Tech Package
    King 2.5 ext travel, Camburg uniball UCA, SCS Ray10 wheels, 285/75/16 Cooper STT Pro's, CMC , MBRP exhaust, K&N cai , OVTune 1.05 , T-rex billet grill, Rigid DS Pro ditch lights, SDHQ ditch light brackets, Leer 100XQ Shell, ShmellFab Sliders, Victory 4x4 Roof rack, LED headlights. SOS Concepts bumper, Smittybilt X20 Winch, Nitro 5,29 gears, ECGS clamshell bushing.
    I was a newb when I bought my 1st gen Taco back in the day and I remember thinking how cool the aluminum spacer looked. Now when I see them on other trucks it makes me cringe
  2. Jul 12, 2017 at 9:06 AM
    SeanDub
    SeanDub Well-Known Member
    Sean
    Morgan Hill, CA
    2017 TRD Off-Road
    Icon Stage 4
    Attack of the spacer lifts!
  3. Jul 12, 2017 at 9:22 AM
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    OP, take the sway bar off and put it in storage. If you're taking your truck off road the sway bar inhibits articulation.
    stun gun likes this.
  4. Jul 12, 2017 at 10:14 AM
    tacitos
    tacitos Tah-Key-Toes
    16 TRDORDCLBJBL
  5. Jul 12, 2017 at 2:11 PM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Best thing I ever did.
  6. Jul 12, 2017 at 2:24 PM
    TacoSauceHB
    Brian
    Rathdrum, ID
    How does it handle on the street?
  7. Jul 12, 2017 at 2:32 PM
    stun gun
    Aaronski
    Tacomas.
    I have a pretty tight s turn on my way home that I've grown very accustomed to. In the 01 and factory 17 I hit it at 45 without breaking the lines (not apex to apex) on the 17 sans sway bar, I hit it at 45, don't break the lines, feel some (but not much) body roll. You just have to know it's not there. I off-road more than I drive on the interstate. If and when I drive in the interstate, I'll be mindful that it's not there. Plus there are a handful of other nanny systems in here that retard wheel spin based on speed and yaw so if I swerve to hit a deer Tom sweers will save me.
  8. Jul 12, 2017 at 2:42 PM
    chucklefunkk
    chucklefunkk Well-Known Member
    So. AZ
    2016 TRD OR
    I'm assuming all the relocation brackets are similar. The brackets relocate your sway bar forward and down. Keep that in mind when installing the brackets. Here's a link to Fox shocks install guide including relocation bracket.
    https://www.ridefox.com/dl/truck/manuals/605-01-063-co-toyota-web.pdf
    Best way that I found was to jack up front end, remove front wheels, disconnect left and right sway bar end links, remove sway bar brackets, install relocation brackets, attach sway bar to relocation brackets, install left and right end links, torque everything, install wheels, lower vehicle. jack stands and chocks are your friend.
    econwatch and broke_down like this.
  9. Jul 12, 2017 at 2:59 PM
    Ede-taco
    Ede-taco [OP] Active Member
    2016 Red Tacoma TRD Off-Road
    Good info!
  10. Jul 12, 2017 at 3:06 PM
    rz2mbc
    rz2mbc Well-Known Member
    Thanks for the info........
  11. Jul 12, 2017 at 5:42 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    Yes, if you don't buy a spacer lift
  12. Jul 12, 2017 at 5:47 PM
    Z50king
    Eric
    Southern California
    Stock and loving it
  13. Jul 12, 2017 at 5:48 PM
    tacitos
    16 TRDORDCLBJBL
    I found out the resi mount for my king suspension will achieve the same result, so no need for the relocation blocks.
  14. Jul 12, 2017 at 5:49 PM
    Z50king
    Eric
    Southern California
    Stock and loving it
    There is no way they will replace that under warranty. Taking them off and going back without a crushed bump stop will also not fly
  15. Jul 12, 2017 at 6:26 PM
    #35
    AramsTRD
    AramsTRD Well-Known Member
    Aram
    North Hollywood
    2017 Tacoma Silver Sky Off Road 4X4
    6k LED headlights Baja Design Squadron Sport R fog lights CaliRaised Ditch Brackets w/ Baja Designs Squadron Amber Baja Designs Squadron Pro flush mount on Rear Bumper Kings 2.5 with Resi’s Front and Rear Icon Tubular UCA’s with Delta’s OME Dakars Leaf Springs Timbren U-Bolts Flips kit with Timbren Bumpstops Demello Offraod Front Bumper Smittybilt Winch9500lbs W/ Synthetic Rope TRD PRO Skid Plate for the front Pelfrey Mid, Rear and Gas Tank Skids Pelfrey Rear Bumper with Wilco Tire Carrier Welded on SCS F5’s 16x8 -25mm Wheels BFG KO2's 285 75 16 Prinsu Cabrac AllPro Rock sliders Import Equipment Red & Dark Grey Light Decals
    I am selling my Ome 2887's for 130.00. Let me know. It was on my truck for like a month
    Ede-taco[QUOTED][OP] likes this.
  16. Jul 12, 2017 at 7:12 PM
    #36
    TacoFister
    TacoFister Well-Known Member
    Josh
    2016 QS TRD 4x4 Off Road
    I am tempted to remove mine... Whats it like with it off?
    tcjacado likes this.
  17. Jul 12, 2017 at 7:15 PM
    #37
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Mangled.
  18. Jul 12, 2017 at 7:16 PM
    #38
    abqnurse80
    abqnurse80 Well-Known Member
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Bilstein 5100 all around, first clip front. AVS window visors, BFG AT KO2s. JBL.
    As others have said, like a condom, safer with it on, but it feels so much better with it off!!! Seriously, a little more body roll in corners, but softer, more compliant. I have found that I notice each front hitting bumps a little more independent if that makes sense. I like it a lot!!! planning to leave off. Just try it without, and if you dont like it, can put it right back on.
  19. Jul 12, 2017 at 8:53 PM
    #39
    Ede-taco
    HAHAHA made my day man
  20. Jul 12, 2017 at 9:04 PM
    #40
    aleriance
    aleriance Well-Known Member
    Jorge
    Naples, FL
    2017 TRD Off-Road 4x4
    CMC 285/70/17
    Spacers lifts are the chrome walmart rim cover of the suspension world. Please no.
    Hank Heel likes this.
