SWAY BAR PROS AND CONS?
Discussion in '1st Gen. Tacomas (1995-2004)' started by STEVEO13016, Nov 28, 2016.
  1. Nov 30, 2016 at 9:01 AM
    STEVEO13016
    STEVEO13016 [OP] Well-Known Member
    STEVEO
    2000 Tacoma Prerunner V6 2WD
    5100 Billy's set at 0" with 881 coils
    I have 32 x 11.5 R15 Falken Wildpeak A/T tires... and I believe there around 35 PSI... I already replaced the tie rod ends, upper ball and lower ball joints, steering rack bushings, coils, and struts.... I checked my body mount bushings and they are toast! may need to get that done soon too.... I will end up leaving the sway bar on and getting extended end links this weekend. Also I will make sure all of the suspension components are tight. Will see what happens... OH and my truck is 2WD so it cant be the CV.
    oh by the way, when I started my truck this morning, I heard a loud rattling noise in the front passenger side... almost like my front fender is loose or something... GREAT... l:help:
  2. Nov 30, 2016 at 9:17 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    I've replaced an end link on my 1998 TRD (stock) three times in the last 10k miles - twice on the left, and once on the right. I was not able to find any end links of which the shaft diameter was larger than the stock links. Too bad nobody makes nice, strong, beefy ones.
    And I noticed that when I torque the top nut to the recommended spec, the rubber grommets are really crunched down tight. :notsure:
