Sway bar quick disconnects???
Discussion in '1st Gen. Tacomas (1995-2004)' started by Wilgray2010, Sep 29, 2015.
  1. Sep 29, 2015 at 5:36 PM
    Wilgray2010
    Wilgray2010 [OP] Well-Known Member
    Northbridge, MA
    01 2.7 5spd
    Billy 5100s, 20% tint, s13we tundra calipers/rotors, super turbo muffler
    Does any one make them?
    Ive gone through 2 passanger side end links in 3 months. Is this from off road use? Or having a lift with the stock end links? I have the billy 5100s
  2. Sep 29, 2015 at 5:53 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
  3. Sep 29, 2015 at 6:16 PM
    Wilgray2010
    Northbridge, MA
    01 2.7 5spd
  4. Sep 29, 2015 at 6:22 PM
    devinzz1
    devin
    2023 aclb trd or mt
    Oh and you shouldnt be going through links that fast even with abuse. Cheap parts store ones or oem?
  5. Sep 29, 2015 at 6:23 PM
    Wilgray2010
    Northbridge, MA
    01 2.7 5spd
    They are moog
  6. Sep 29, 2015 at 7:33 PM
    devinzz1
    devin
    2023 aclb trd or mt
    Cant remember if these trucks have what looks like a little tie rod end at one end or rubber washers at both ends (These can be tightened and dont really go bad). Ive just left my swaybar disconnected.
  7. Sep 29, 2015 at 7:53 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    I believe if you lift your truck, your sway bar should be "lifted/extended" as well. i read somewhere some people made sway bar extenders that essentially were machined pieces of metal that spaced out the sway bar from it's original position directly on the chassis. Much like a body lift, it just spaces the sway bar further from the chassis.
    I think sway bars are mounted to the new cross member when you do one of those procomp lifts. but if you do just a shock lift/spacer, there isn't anything to adjust the sway bar.
  8. Sep 30, 2015 at 6:29 AM
    Wilgray2010
    Northbridge, MA
    01 2.7 5spd
    Ill have to just try tightening it befor i get a new one then.
    I think they sell extended end links. Gonna have to get those eventually
  9. Sep 30, 2015 at 7:12 AM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    Just remove the sway bar man. It will improve your offroad handling and you will quickly get used to not having it on the road. Many many people have removed theirs with little to no detrimental effects
  10. Sep 30, 2015 at 7:13 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Technically the suspension will still travel in the same path as stock (unless you extend the control arms). After lifting, your sway bar will be at a downward angle at the bushings on the end links during normal driving which can lead to premature wear (since the bushings are compressing more than normal). I ended up putting 05+ tacoma links on mine and now my sway bar is straight at ride height.
  11. Sep 30, 2015 at 7:18 AM
    Wilgray2010
    Northbridge, MA
    01 2.7 5spd
    I've been thinking about that but im doing 80 miles on the highway a day. They said it can be sketchy on the highway
  12. Sep 30, 2015 at 7:19 AM
    Wilgray2010
    Northbridge, MA
    01 2.7 5spd
    The 05+ end links are longer?
  13. Sep 30, 2015 at 7:21 AM
    nzbrock
    Noah
    San Marcos, TX
    Yes, just look at the coilover or strut setups, they always have an extension at the bottom. If you have a 2-3" lift they will work just fine.
  14. Sep 30, 2015 at 7:35 AM
    Wilgray2010
    Northbridge, MA
    01 2.7 5spd
    Awesome. Thanks man
  15. Sep 30, 2015 at 8:03 AM
    TIPICOTACO
    Tyler
    nw nj
    I would disconnect it, zip tie the bar securely so it doesn't hit into anything, and try it for a couple days to see if you like it. My SB has been off for 3 yrs now, my rig is lifted and heavy, and I've never felt like it was unsafe even a highway speeds. Of course I'm not cornering like a sports car, and I try to avoid sudden evasive maneuvers, but I think that the stronger OME 883s that I have make up the difference in the lack of a sway bar
  16. Sep 30, 2015 at 10:59 AM
    devinzz1
    devin
    2023 aclb trd or mt
    Ive had my sway bar disconnected for over a year and i can tell you 5100s with eibachs and swaybar disconnected felt more stable than oem rep. Kyb shocks and swaybar connected. My truck is my dd and i drive it on highway regularly without issues and havent felt the need to hook it back up. Do this at your own risk as it will help in an emergency situation where u need to swerve quickly.
  17. Sep 30, 2015 at 4:19 PM
    yotastaco
    yotastaco Well-Known Member
    NC
    2015 MGM TRD OR
    See Build
    Delete it.
  18. Sep 30, 2015 at 5:48 PM
    Wilgray2010
    Northbridge, MA
    01 2.7 5spd
    Looks like the sway bar is coming off this weekend then!
  19. Oct 22, 2015 at 10:08 PM
    TacoTuck
    TacoTuck Well-Known Member
    NorthWest
    2001 4x4 TRD SR5
    Leer canopy, OME 881 lift with dakar leaf pack, 265/75/16 duratracs, 16x8 KMC enduros, line-x bedliner and more...
    How come wab fab doesn't make quick disconnects for 01-04's? What would be different?
  20. Oct 23, 2015 at 7:57 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    I have adjustable 5100's on the 0 setting with Eibach 3" coils in the front and what is the advantage of taking of the sway bar? I also have Camburg UCA's too. I noticed 05 & newer Tacomas have a sway bar in the front & back of the front diff
