Sway bar removal problem.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by The tacoman, Nov 11, 2010.
  1. Nov 11, 2010 at 12:04 PM
    The tacoman
    The tacoman [OP] Well-Known Member
    Texas
    2006 TRD
    I was trying to remove my sway bar this morning and I could not get the top bolt to budge. It appears to be a little rusted. The two bolts on the frame look fine, but its the upper one I have been having problems with. I sprayed it down with WD40 and am letting it sit currently, hopefully that works. If not has anyone else run into this problem, or have any bright ideas?
  2. Nov 11, 2010 at 12:08 PM
    Pyro
    Pyro Well-Known Member
    Jon
    Garden Grove, Ca
    01 PreRunner
    Camburg Arms, Icon Coilovers, ProComp 9000 rears, Big Foot all-terrains, KNN Intake, Flowmaster,
    using a breaking bar worked for me.
  3. Nov 11, 2010 at 12:11 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    x2. or if you dont have a bar, try using 2 box wrenches connected together, like so:
  4. Nov 11, 2010 at 12:17 PM
    The tacoman
    Texas
    2006 TRD
    Pretty clever with the box wrenches. Never seen that before. Guess Ill go give it a shot.
  5. Nov 11, 2010 at 12:26 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    I was impressed when that trick was passed on to me also. It actually gives you a good amount of leverage! Not as much as a breaker bar, but it works :thumbsup:
  6. Nov 11, 2010 at 12:28 PM
    Timicha
    Timicha Timicha
    TIM
    Tillamook / Portland , Oregon
    04 White Tacoma
    Fabtech 4 inch lift, tinted windows, diff drop, 33 inch MTZ tires on Raceline Raptor wheels, ELITE OFF-ROAD bumpers and sliders
    be careful not to slip if you do the wrench thing, i've racked my knuckles so many times doing that
  7. Nov 11, 2010 at 12:28 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    This happens too...you might want to set up the wrenches, and tap the bottom with a hammer a couple times
  8. Nov 11, 2010 at 12:29 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    or stick a pipe on the end of your socket wrench
  9. Nov 11, 2010 at 12:30 PM
    Timicha
    Timicha Timicha
    TIM
    04 White Tacoma
    thats what i usually do
  10. Nov 11, 2010 at 12:58 PM
    Pyro
    Jon
    Garden Grove, Ca
    01 PreRunner
    oh yea, ive doen the wrench trick many times. It works perfectly. (do not buy cheap ratchets, You will break those bastards so fast)
  11. Nov 11, 2010 at 1:15 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    18" steel pipe from home depot. Comes in handy so many times. I got one wide enough to fit over my pipe wrench, ratchet & wise grips. Cost about $11...
  12. Nov 11, 2010 at 1:57 PM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    That's how I got my bell-housing bolts off when I pulled the engine on my nova :D
  13. Nov 11, 2010 at 2:54 PM
    The tacoman
    Texas
    2006 TRD
    Well I got it off finally. After getting all of the bolts/nuts off the hardest part was actually getting the sway bar out from the truck. Ended up having to take both of the tires off and having my wife help me twist it the the right way. Do you always have to take a tire off to get it out?
  14. Nov 11, 2010 at 2:56 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    much easier to just take off the 2 cross bars under the sway bar, so that it drops straight down
  15. Nov 11, 2010 at 2:59 PM
    The tacoman
    Texas
    2006 TRD
    Yeah that thought crossed my mind as i'd already taken the tire off. Wasn't sure if that would be the easiest way or not. Guess ill do that next time. Thanks.
