Sway-bar removal review
Discussion in '2nd Gen. Tacomas (2005-2015)' started by colinb17, Feb 17, 2010.
  1. Feb 17, 2010 at 3:01 PM
    colinb17
    colinb17 [OP] If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    Through the search feature I found a lot of comments from people who had taken their sway bar off in response to questions asked by other users. But i didn't find a full review of the handeling, positive/negatives of riding without it....so her's my review. i'll update it over time when experience different driving conditions, or notice something worth reporting on.
    First let me say: removing the sway bar, in addition to some benefits, can be very dangerous. to my knowlege, if you are involved in an accident without it, insurance will not give you a penny. for those still under warrany, i would not bring your truck to the deal without it on either if you are expecting to get something covered. I cannot be held responsible for anything that happens as a result of removing it.
    Disclaimers asside, Let's begin.
    I drive a 2007 double cab TRD Sport.
    I have a 2.5 in lift up front and the TSB 4 leaf pack in the rear.
    don't know if it makes a difference, but i have 265/70/17 Nitto, Terra Grapplers on stock rims
    This is not a how-to as it is fairly simple to remove, but my one tip is to remove the entire link on both end from the sway bar, not just unbolt from the spindle. it will make untangeling the sway bar from the frame and suspension components much easier.
    OVERALL:
    so far, my overall impression of the truck without the sway bar is nothing but positive. The lift I have made the suspension stiffer than stock, as most lifts will. so I am assuming that helps with some of the body roll issues a softer ride would have.
    ON ROAD:
    As most of my driving is on road, I was hesitant, fearing that my truck would just about fall over making any turn. Maybe it's because the suspension is pretty stiff, but i have been very pleased with the cornering of the truck. I'm not a crazy driver, and I am aware that it is a truck, so i am cautiouson all turns. but the body roll was much less then I expected. It really becomes more noticable when taking tighter turns (not just slight bends in the road) above about 35 MPH.
    doing about 55-60 MPH, lane changes are not a problem. I went to a long stretch of road with no traffic, and tried some harder lane changes and braking, to simulate an emergency avoudance manuver. what i did was not as severe as what you may encounter during a true emergencey, but it gave me an idea.
    For example: braking and turning at the same time resulted in a good amount or roll. potentially dangerous or even deadly if you oversteer. i found that if possible, in avoiding another vehicle, slow down first, then turn.
    OFF ROAD:
    I have not had time to get to any real trails, but after over 3 feet of snow, and not once seeing a plow, parts of the roads surrounding me have holes and dips in them so deep that it hung up my naighbors Lexus RX suv on the frame when the front left tire went into one of the dips. I will add more when i get a chance to wheel, but I can already tell that the off road characteristics will be improved a fair bit.
    The change I noticed the most was that, say my left front tire went into a ditch/hole....with the sway bar, the whole truck would tilt to the left in a pretty rough way. this is becasue the sway bar keeps both side of the IFS compressed about the same amount in most situations. but without the sway bar, instead of the truck "falling" to the left, the front left tire simple drupped into the hole on it's own , independent of the movement of the other side, keeping the kab level and comportable. I have found the same results when driving over potholes.
    Future: I will add updates in the future about further experiences with highway driving (i will be taking a trip this weekend and logging some highway hours). When i get a chance to do some real wheeling, I will make sure to comment. Lastly, once it warms up, it'll be time to tow the boats. i have a Hobie Cat sailboat that weighs about 2500 lbs with the trailer. this should not be an issue as you can't even tell it's back there most of the time. the 6400 lb wakeboard boat may be a problem. i may just have to put the sway bar back on before towing that...but we'll see; i have some more research to do.
    Sorry this turned into such a long post on such a simple item. I just hope it helps people who have questions about the matter.
    I will put all updates in a new post so people subscribed know i've added material, but i will copy the update into this original post so new readeers do not have to search through the whole thread.
    as always, DRIVE SAFE, and enjoy your tacos:taco:
  2. Feb 17, 2010 at 3:14 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    thanks for the pics. i was trying to explain how the cab will stay level, but the pictures show much better.
    i'm running stock coils, but the lift stiffened things up, so i know what you mean. it took a pretty hard turn at a decent speed to really get much.
  3. Feb 17, 2010 at 3:18 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Welcome to a true IFS :woot:
  4. Feb 17, 2010 at 3:21 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    funny you should say that, I was thinking about that the whole time i was removing the bar...makes no sense:notsure:
  5. Feb 17, 2010 at 3:23 PM
    08pretaco
    az
    Doesn't to me either haha but I love my truck that much more without it :)
  6. Feb 17, 2010 at 3:53 PM
    Jotun
    Jotun Well-Known Member
    Fort Rucker, AL
    DBL cab LB TRD Sport PreRunner
    That is very interesting I might try that....
  7. Feb 17, 2010 at 4:06 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    what makes you think this?
  8. Feb 17, 2010 at 4:15 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Nothing confirmed about this, but i have heard about this happening through a little research. it's not guarenteed they won't cover you, but since it's possible, i wanted to put it in there. jsut something to considder.
  9. Feb 17, 2010 at 4:16 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    I see, just seems like if they would make a big deal about that then they would also make a deal about the suspension in general being altered. Never ran across this, just wondering.
  10. Feb 17, 2010 at 4:19 PM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    I just took mine off this weekend. Haven't tried much yet, so nothing to report on. It feels fine on the road because I have 620 lb Eibach coils. Going wheeling this weekend. We'll see...
  11. Feb 17, 2010 at 4:22 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    that's a good point. i'm not an insurance expert, so this may be complete bs lol, but my guess is that some have had issues with this because altering the suspension may decrease safety, but removing a sway bar is actually taking away a whole piece of equipment that is put there as a safety measure (and for performance in cases).
    i'll do some more digging and see what i can find.
  12. Feb 17, 2010 at 4:26 PM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    I have had mine off since last april, all i can say is that it makes your suspension come to life,
  13. Feb 17, 2010 at 4:35 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    it truely does, i haven't had mine off long, but i can tell it will be staying off (unless towing the big boat becomes an issue).
  14. Feb 17, 2010 at 4:36 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    i've had mine off for months now, with no issues at all.....to be honest i doubt the adjuster would even realize that it is missing.
  15. Feb 17, 2010 at 4:38 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    yeah, that's the big thing. i'm sure if they were told it was removed, they'd make a big deal of it, but unless the person owns a taco and is really into it like we are, i don't thenk any normal person would notice.
  16. Feb 17, 2010 at 6:38 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    hence the disclaimer :). i would like to think that this wouldn't be an issue, but there have been a freakish amount of 2nd gen wrecks recently (thank god everyone's ok), and i would hate to see another one due to this and then also heve insurance completely bone them.
  17. Feb 17, 2010 at 6:47 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    My transmission just went out. I brought my truck to the dealer, it doesnt have the sway bar on, and they covered me for a new warranty. lol I win!
  18. Feb 17, 2010 at 6:59 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    magnuson moss act say they should replace your transmission...if your shock had blown it may have been a different story.
    glad to hear a positive story from a trip to the dealer though:)
  19. Feb 17, 2010 at 7:19 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Ah yes. Well at first they asked me if it had a lift and I said yes. So I got scared! But all is good. I dont plan on putting my sway bar back on.
  20. Feb 17, 2010 at 7:27 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    haha, i know what you mean, the dealer asked my if i had a lift (when i was still under warranty), i almost walked oyu withouth even answering lol
