Sway bar removal...
Discussion in 'Suspension' started by J1Time, Oct 13, 2014.
  1. Oct 13, 2014 at 12:41 PM
    J1Time
    J1Time [OP] That guy...
    Atlanta
    2014 Tacoma TRD Off Road 4x4
    When taking the sway bar off is there anything else that needs to be disconnected other then the two brackets and where it attaches to spindles? Once these are disconnected will it slide out to one side?
  2. Oct 13, 2014 at 12:42 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Prolly have to take off your splash-pan/skid plate.
    I don't think you can pull it out from one end.
  3. Oct 13, 2014 at 12:42 PM
    J1Time
    Atlanta
    Once the splash pan is out isn't there something else in the way then pr venting it from falling down?
  4. Oct 13, 2014 at 1:00 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Nope. Four bracket bolts and two spindle nuts. The spindle nuts are 17mm IIRC.
  5. Oct 13, 2014 at 1:17 PM
    teamcurtis
    teamcurtis Well-Known Member
    Curtis
    San Diego
    2015 DC 4x4 Super white
    285/75/16, snugtop xtravision, pop-lock
    im pretty sure it still needs to be pulled out to one side... I just had mine unhooked to install 5100s and it defn didn't just drop out the bottom once unbolted.
  6. Oct 13, 2014 at 1:25 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    In my experience it was necessary to unbolt the two splash pan support braces as well.
  7. Oct 13, 2014 at 2:17 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Right. I forgot - I removed those a while back to install my aftermarket skid plate.
    And I've never tried pulling the thing out with those mounts in place.
  8. Oct 14, 2014 at 4:15 AM
    J1Time
    Atlanta
    May be a dumb question...... Is it possible to remove without jacking truck up and removing tires?
  9. Oct 14, 2014 at 7:13 AM
    Westside
    Westside Southbound
    JT
    Nor Cal, East Bay
    TRD Sport 4X4
    I was able to fish mine out fairly easy without removing the support braces. But I might have uttered a curse word or two :goingcrazy:
  10. Oct 14, 2014 at 4:43 PM
    KenLyns
    Belly of the Beast
    ^I was afraid for the transmission lines and CV boots. The sway bar is surprisingly heavy. I think it's a solid rod rather than a tube.
    Very difficult to separate the links from the spindle without removing the tires. You can separate the bar from the links and just remove the bar. Make sure the dangling links don't jab into anything.
  11. Oct 14, 2014 at 4:55 PM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    Yes, that's how I've done it several times.
  12. Oct 15, 2014 at 5:23 AM
    J1Time
    Atlanta
    When you did it with wheels on does it still pull out to one side or drop down somehow?
  13. Oct 15, 2014 at 5:42 AM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    Just give it a shot and let us know how it turns out :cool:
  14. Oct 15, 2014 at 10:48 AM
    numbah57
    kahai
    Maui, Hawaii
    Drops down.
    Splash guards and braces need to be removed. With the curves in the bar, I don't think it'll pull out from ones side.
  15. Oct 15, 2014 at 10:49 AM
    numbah57
    kahai
    Maui, Hawaii
    Also keep a good grip on it.
    Didn't realize the weight on it the first time and had it attack my face hahahah
