sway bar removal.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pudge151, Jun 25, 2015.
  1. Jun 25, 2015 at 1:10 PM
    pudge151
    pudge151 [OP] Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    Does removing the away bar give a better on road ride? I don't off road much. I also don't want to compromise my safety. I know a ton of you guys have yours removed. Is there any benefit or risk for a truck that is a DD and rarely off road?
  2. Jun 25, 2015 at 1:11 PM
    Trucko
    Trucko Well-Known Member
    Summit County Colorado
    2005 Tacoma
    arb bull bar Smittybulit 9.5 winch topper shell with yakima basket piaa lights toytec boss coilovers Dakar leaf pack with boss shocks 28/75/16 bfg at ko2 Midland CB Home made trailer with CVT Mount Rainer tent and max coupler hitch
    sounds like you should keep it on then. i did just for safety.
  3. Jun 25, 2015 at 1:12 PM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
  4. Jun 25, 2015 at 1:12 PM
    pudge151
    Sean
    Connecticut
    That's what I'm thinking and have always thought. Just curious. I would like a smoother on road ride. I'm installing eibach 1.6" coils and have tsb rear with Firestone air bags.
  5. Jun 25, 2015 at 1:25 PM
    catattacksdog
    catattacksdog Well-Known Member
    Not Steve
    Not Kentucky
    07 dc
    Leave it on, please. If you don't plan on taking advantage of it off-road, you should retain it for on-road safety and drive-ability. Removing it will place you at a much higher risk of a roll-over accident.
    Lord Helmet likes this.
  6. Jun 25, 2015 at 1:48 PM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    If you do a little independent research on sway bars, you will likely discover that suspension geometry is stabilized and handling is enhanced (on road) by adding sway bars. I just added an aftermarket sway bar to the rear of my Tacoma to improve on-road performance. The down side of sway bars - they can limit suspension articulation in off road situations creating a need for disconnects, and the need to modify the sway bar on lifted vehicles. You should make you decision based on how you primarily use you vehicle.
  7. Jun 25, 2015 at 1:50 PM
    Pigpen
    Dan
    Northwest Montana
    If you're on the fence, leave it on. The only real improvement on road is when the road is shitty with holes and bumps. If you don't off road much, it's probably not worth it. With firmer coils the rollover argument is pretty much useless though. If I swerve hard enough to roll my truck, rolling is a better option than what I'm avoiding. These things are designed to handle frontal impact. I won't be swerving for cats, dogs, deer, elk, bear, (maybe moose), or anything softer than oncoming traffic. I've survived a head on collision in pretty good shape. Swerving is generally a bad idea.
  8. Jun 25, 2015 at 3:33 PM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    Don't do it. I did on a TRD Offroad model and it sucks it felt like a boat and when I made turns it leaned like a cholo
  9. Jun 25, 2015 at 3:36 PM
    catattacksdog
    Not Steve
    Not Kentucky
    07 dc
    I will leave most of this general argument alone, in interest of not starting a war. But I do agree with the point about stiffer coils. This was what I did to counter my lack of sway bar. (Adjustable compression actually)
  10. Jun 25, 2015 at 4:26 PM
    Pigpen
    Dan
    Northwest Montana
    It was a bit of a rant...:notsure:
