SWAY BAR-REMOVE OR NOT?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KAPs2013, Mar 31, 2020.
  1. Mar 31, 2020 at 2:35 PM
    KAPs2013
    KAPs2013 [OP] Member
    Washington
    2013 TX Baja
    K&N intake Headers Dual Exhaust JBA UCA’s ARB/OME 2”lift/level heavy duty front and rear springs. Cooper Discoverer AT3 XLT 265/70/17 on stock wheels. ARE Canopy with racks.
    I have the ARB/OME Heavy front and rear on my 2013 TRD DCSB. I don’t do any rock crawling as the truck is built for camping/overland. Should I remove my sway bar or keep it on. What’s the pro’s n con’s to this?
  2. Mar 31, 2020 at 2:37 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    I never put mine back on after putting my OME 884's and billie 5100's. I love the way it handles. Cloverleafs are fun AF.
    EdinCincinnati likes this.
  3. Mar 31, 2020 at 2:41 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Do you mean "worse on-road performance"?
  4. Mar 31, 2020 at 2:44 PM
    EricL
    EricL Tomahawk Chopper
    Greenwood, SC
    2015 Slowmobile
    SOS Offroad Concepts Armor
    Body roll FTW
    El Duderino likes this.
  5. Mar 31, 2020 at 3:14 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I ran without on for a while on my truck. Ended up putting it back on as lets face it.... 99% of the time our trucks are on road, and loaded up going to the camp ground was a much safer drive.
  6. Apr 1, 2020 at 6:38 PM
    2WD
    2WD Well-Known Member
    Pete
    2013 DCSB TRD Off-Road Pre-Runner Taco
    King 25001-119A, JBA HC and superbumps, EL095 leafs with longer overload leaf removed and 2 degree shim, Bilstein 5160 rears with fox roost shield on passenger side, King 2'' bump stops, B&M 70264 trans cooler, CSF FJ radiator, Leer Trilogy X2T bed cover, Scangauge, 34R AGM battery, weathertech floormats, Gold plug on the differential, fancy engine and diff oils, UNI air injection filter mod, Factory antenna chopped 4'', De-badged, Ram mount on A pillar, Cooper ST Maxx 265/75 R16.
    You will have to drive both ways for a while to figure it out. Off road and on road. Stock springs or not stock springs matters. I would totally leave it on if you have stock springs or like tigers.
    Mine fell off and can't seem to re-attach it:cool:.
    If you plan on driving a moose test, you want a sway bar. Might flip over even with a sway bar...look at the warning on the visor. But if you understand how to not be a crackhead with the steering wheel, you should feel OK about things right up until sudden rollover death. You will be able to feel and get used to the body roll when turning on the road. Off road you will not have that rocking boat left-right-left-right seasick swaybar nonsense going on with every bump. Truck feels planted and suspension can do it's job.
    EdinCincinnati and mac_2_nite like this.
  7. Apr 1, 2020 at 6:52 PM
    Nachomama2001
    Nachomama2001 Well-Known Member
    South Carolina
    2013 Tacoma TRD OR prerunner
    Bilstein 6112+5160s Air pump delete-Hewitt Technology Rear view mirror switch Hawk pads G2 BAK flip Roadmaster active suspension Seat lifters HVAC AJT knobs
    It’s a truck not a sports car...let that suspension eat.
    TRDtaco99, Bandit and KAPs2013[OP] like this.
  8. Apr 1, 2020 at 6:59 PM
    KAPs2013
    Washington
    2013 TX Baja
    I have Old Man Emu all the way around the truck with OME leafs. Seems like someone would have come up with a kit that would allow you to remove for off road and re-attach for on road.
    Wero94 likes this.
  9. Apr 1, 2020 at 7:02 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It is 100% subjective. Take it off and go for a drive. If you don’t like it, put it back on. /thread
  10. Apr 1, 2020 at 7:15 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Better yet, do you have a reason to remove it?
    KAPs2013[OP] likes this.
  11. Apr 1, 2020 at 7:22 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Keep it on.
  12. Apr 1, 2020 at 7:44 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    It's subjective.. try it out and see if you like it or not. I like turning at spirited speeds so I keep mine on. Tacos that see similar spirited use in rugged terrain could probably benefit from it.
  13. Apr 2, 2020 at 3:32 AM
    TacoTuesday1
    FL
    isn't that the point of a quick connect sway bar
    are there any for the Tacoma or can be they custom made?
    sway bars link the front suspension to reduce body roll, but limit it's travel. Which is fine on a flat road.
    But that also probably messes up the ride on uneven surfaces, because instead of letting each suspension corner do it's job independently, it now forces them to be locked together (such as front)
    Even on certain passenger cars, the ride is better over pot holes in a straight line if you remove the front bar, but then dives badly when you take a turn such as highway onramp
    depending on the vehicle and how it's balanced.
    For example Audi's tend to understeer due to their drivetrain being far forward. The rest of the car is probably designed with that in mind, to combat it, including suspension.
    BMW and Mercedes has it farther back.
    and so on. Longitudinal vs transverse. etc.
    or Mazda Miata's, however they are; I hear it can be beneficial to race them on track with rear bar removed.
    I've also heard of people changing suspension literally at a track if the weather changes, like changing out springs for a different spring rate.
    I have seen a quick disconnect one on a Jeep before.
    not sure if there are any expensive aftermarket suspensions (coilovers), or something else, that is good enough to function well without sway bars.
    IDK what type of suspension trophy trucks use, but they probably have more freedom/selection on what to pick because they don't have to accommodate any drivetrain parts into it, since it's RWD
  14. Apr 2, 2020 at 4:14 AM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    topic beat to death on this forum.....do a search
  15. Apr 2, 2020 at 4:19 AM
    93yotasr5
    93yotasr5 Well-Known Member
    Sacramento
    Get rid of it and never look back.
  16. Apr 2, 2020 at 8:53 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    just removed mine after installing a 2" spacer lift. didnt really feel a diffrence except when going over speed bumps. one tire went over the bump and the other tire cut between. much smoother.
  17. Apr 2, 2020 at 11:03 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    If you remove it you are going to die.
    If you don't remove it you are going to die.
    Plenty on here don't run one (myself included) but you should think about what @Crosis posted. Every mod should serve a purpose and fit with the end goal/use for the vehicle. The swaybar delete is free and reversible so it's worth a try if you think it fits with the way you use the truck.
  18. Apr 2, 2020 at 11:09 PM
    Texas T
    Texas T Well-Known Member
    TX
    '14 T Force
    My truck handles great for what it is but takes bumps like shit, my Porsche is better over bumps than my truck. I probably have way too much preload but have been considering removing the sway bar to see if it makes any difference
    will.i.was likes this.
  19. Apr 3, 2020 at 5:25 AM
    jbrnigan
    Midwest
    I installed the rear Hellwig sway bar on my sport. 90% of my driving now, is on road, and the sway bar makes a significant improvement in the ride and handling (but, it's still a truck).
  20. Apr 3, 2020 at 7:05 AM
    Westside
    Westside Southbound
    JT
    Nor Cal, East Bay
    TRD Sport 4X4
    Swaybar free since 2012. 110k miles ago
