Sway bar rubbing on left coil spring
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JESSMAN, Mar 25, 2010.
  1. Mar 25, 2010 at 2:15 PM
    JESSMAN
    JESSMAN [OP] Well-Known Member
    Jesse
    Reno Nv
    08 tacoma
    ARB BUMPER WARN M 8000 LIGHT FORCE LIGHTS Bill 5100 DOWNY FRONT LIFT RANCHO OLD MAN E REAR and JERRY CAN IN THE BED
    Dose any body know how to fix this?? just got new tires went from p245/75 R16 to p265 /75 R16. The smart guy that put on the tires said it was a bad strut!!! its not! its the sway bar rubbing on the coil spring!!
  2. Mar 25, 2010 at 2:16 PM
    Brunes
    Brunes abides.
    Rotorhead
    Have you attempted to install a sway bar relocate bracket?? Or considered taking your sway bar off??
  3. Mar 25, 2010 at 2:19 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    ^^ yup and yup...i've run mine for over a year w/ no swaybar and i love it. the stiffer aftermarket suspension deadens most of the normal bodyroll
  4. Mar 25, 2010 at 2:46 PM
    Anthony
    Anthony San Antonio Detailer :)
    Houston - Spring/Tomball area
    06 prerunner access cab 2.7L M5
    Nfabs Afe Pro Dry UWS linex'd toolbox
    sway bar relocate kit is about $40 shipped from toytec.
  5. Mar 25, 2010 at 2:47 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    I took my swaybar off a week ago and can barely tell a difference, it's a little different but not in a bad way; less fight from of the front to flex offroad too. Just take it off, but if you want to leave it on get a swaybar relocate kit, like $30 and it just moves the swaybar forward like 1".
    Either way, taking the sway bar off takes 20min and installing the relocate takes 20min, both are an easy job.
  6. Jun 30, 2010 at 7:30 AM
    28Gauge
    28Gauge Well-Known Member
    Brian
    Grapevine, TX
    06 PreRunner SR5
    Sockmonkey Graphics, K&N Drop In Air Filter, 265/75/16 Bridgestone Dueler A/T's, Weathertech Digital Fit Floor Mats, Dee Zee Bed Mat, Map Light/Dome Light LED's, Flo-Pro Muffler w/Stainless Steel Tip, Dome Light/Map Light Mod, Mobil 1 Synthetic Motor Oil, LED Cupholder Mod, Grillcraft with TOYOTA emblem, Vision 375 Warrior Wheels, Extra Bed D Ring Mod, TRD Skidplate, Bilstein 5100's on all four corners, Front 5100's set at zero with Eibach springs, Toytec 1.5" rear TSB add-a-leaf springs, Toytec swaybar relocate kit, Katzkin Leather Seating, Front Window Tint
    I am having the same problem. Last night, I installed 5100's set at 0 on Eibach springs. The sway bar on the driver's side is hitting the bottom of the coil and spring support.. I just ordered the Toytec sway bar relocate kit. I hope this fixes the popping sound.
  7. Jun 30, 2010 at 7:54 AM
    06redtacoma
    06redtacoma Well-Known Member
    Alabama
    06 Trd Offroad
    Lifted, Slider, stock rack, rear mounted winch in stock bumper, brush guard, Sound system, ipod to car, tint, wheel spacers, 285 bfg AT,
    it will fix it i had the same thing going on mine wasn't a popping sound it was like a nasty metal on metal grind. it made me feel like a real bada$$ every time someone heard me pull out of my driveway.
  8. May 1, 2012 at 7:38 AM
    tacomabrb
    tacomabrb Member
    Alberta, Canada
    Toyota Tacoma TRD Sport
    Hi. New member here. :)
    Not trying to hijack someone's elses thread, but I think I am having the same problem. On the driver side, the sway bar is rubbing on the coil. Makes a terrible squeaking noise. This is a 2009 Tacoma. Shocks were already on vehicle when I bought it used from the dealer. It was squeaking 2 weeks after I drove it off the lot. Is this something the dealer should fix?
    I can look at the shocks and send better pics if that would help.
    Learning as I go. First Tacoma, but still love this truck. :)
    Thanks
  9. May 1, 2012 at 7:45 AM
    jhodge83
    SC
    17 XLT Sport
    probably just need to purchase some swapbar relocation brackets if there are none installed. what type of coilovers are those? swayaway?
  10. May 1, 2012 at 7:54 AM
    tacomabrb
    tacomabrb Member
    Alberta, Canada
    Hi.
    I don't know what kind of coil covers they are. Where would I look on them to determine that? I can take a few more pics if that would help. The shocks on the back are Nitro Charger.
    Thanks
  11. May 1, 2012 at 7:56 AM
    jhodge83
    SC
    17 XLT Sport
    i think most have the name above the threads on coilover. rears are yellow? rears sound like OMEs.
  12. May 1, 2012 at 7:57 AM
    tacomabrb
    tacomabrb Member
    Alberta, Canada
    Yep, rears are yellow.
  13. May 1, 2012 at 8:01 AM
    jhodge83
    SC
    17 XLT Sport
    yeah...rears are OME. from the color on the bottom shaft of the front coilover, i think the could either be swaway or walker evans. walkers i've seen had red coils and have "allpro offroad" on the coils. they dont have the manufacturer name on top where the swayaways do.
  14. May 1, 2012 at 9:00 AM
    tacomabrb
    tacomabrb Member
    Alberta, Canada
    So do you think the dealer should pay for the parts and the install of the sway bar relocation brackets?
  15. May 1, 2012 at 9:20 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    Make your semi-independent front suspension fully independent front suspension by removing the swaybar. You'll enjoy the ride without it. Smoother on road & off. A very slight increase in body roll on road, but with only 1 shock & spring reacting to bumps & dips you'll get more flex & a better ride.
  16. May 1, 2012 at 10:13 AM
    jhodge83
    SC
    17 XLT Sport
    like 4wheelin said, yo can remove the swaybar if you want. you can go to toytec and get the relocation brackets aund install easily if that's the way you want to go.
  17. May 1, 2012 at 10:44 AM
    drsus
    drsus Well-Known Member
    Los Angeles, CA
    4Runner TRDpro
    stock
    take it off
  18. May 1, 2012 at 12:22 PM
    tacomabrb
    tacomabrb Member
    Alberta, Canada
    Thanks for the feedback. Really appreciate it.
  19. May 1, 2012 at 12:26 PM
    jhodge83
    SC
    17 XLT Sport
    with the aftermarket full coilovers, you should be able to remove the swaybar and not tell TOO much unless you take curves entirely too fast.
  20. May 1, 2012 at 12:28 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Get the relocates
