Sway Bar rubbing on tire.
Discussion in 'Suspension' started by bigH, Nov 20, 2020.
  1. Nov 20, 2020 at 8:55 AM
    bigH
    bigH [OP] Member
    Kevin
    2011 Tacoma PreRunner
    6 inch lift 33x12.5 20 Fuel Vapor
    Howdy,
    Did a 6 inch lift on a 2011 Tacoma. Put 33x12.5 on 20s. Lift went fine, no issues with rubbing. Drove the truck 3000 miles and did a tire rotation. After the rotation, the right tire rubs on the sway bar in a full left turn. (left tire does not) I checked the sway bar distances from the brackets and they seem equal (ie, no shift). Installed relocation brackets when i did the lift.
    There were no rubbing issues before i did the tire rotation...scratching my head on this one. oh, and yes, the tires are all the same size.
    Also, removing the sway bar is not an option. Any ideas/suggestions ???
  2. Dec 1, 2020 at 2:44 PM
    bigH
    bigH [OP] Member
    Kevin
    Looks like everyone else is scratching their heads too!
  3. Dec 1, 2020 at 2:48 PM
    Clearwater Bill
    Billy
    Largo Florida
    You may have to wait a bit.
    Not many fans of your parts combo around here to be able to share experiences that would help.
  4. Dec 2, 2020 at 4:49 AM
    bigH
    bigH [OP] Member
    Kevin
    What?!?! Parts combo? Almost every post I see has this type of combo. Really????
  5. Dec 2, 2020 at 3:40 PM
    Clearwater Bill
    Billy
    Largo Florida
    Maybe 1/10 of 1%. If that.
    Could be a lot of them in HI. Maybe post in that regional forum?
    LooneytuneSR5 and TnShooter like this.
  6. Dec 2, 2020 at 3:45 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I don’t see too many 6” lifts on this forum.
    And most people with “bigger” lifts take off the sway bar.
    How bad is it rubbing?
    Are all the front end suspension and steering components in good shape?
  7. Dec 2, 2020 at 3:52 PM
    bigH
    bigH [OP] Member
    Kevin
    It’s not too bad, it’s just that it didn’t do it before the tire rotation. It only rubs on a full left turn. It was driven 3000 miles with no issues. I’m beginning to suspect maybe a toe-in shift or some type of alignment issue. Drives straight, though.
    I don’t want to remove sway bar due to the fact that this truck is an everyday driver, primarily driven by my son. Would hate to remove a safety feature and have something bad happen.
  8. Dec 2, 2020 at 3:53 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    have you made sure that all 4 wheels have the same offset/backspacing?
  9. Dec 2, 2020 at 3:54 PM
    TnShooter
    Deogee
    STOCK
    I too am a fan of the Sway bar.
    I say keep them on, unless there is no other option.
    Then drive very carefully......I understand your concern there.
  10. Dec 2, 2020 at 5:35 PM
    bigH
    bigH [OP] Member
    Kevin
    I did check the back spacing. I even put the tires/wheels back the way they were before the rotation...still rubs. Strange.
