Sway bar size
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jonacevedo2012, Oct 29, 2019.
  1. Oct 29, 2019 at 7:23 AM
    Jonacevedo2012
    Jonacevedo2012 [OP] Well-Known Member
    Jonathan acevedo
    2016 magnetic grey tacoma trd off road
    Ov tune
    What size diameter is factory size sway bar in my for 3rd gen Tacoma?
  2. Oct 29, 2019 at 7:41 AM
    Jonacevedo2012
    Jonathan acevedo
    Ov tune
    Trim is double cab short bed
  3. Oct 29, 2019 at 7:51 AM
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    Off-Road has a 28mm sway bar. Sport/Pro have the 30mm.
  4. Oct 29, 2019 at 7:56 AM
    Jonacevedo2012
    Jonathan acevedo
    Ov tune
    Ok thanks alot man
    Wixo likes this.
  5. Oct 29, 2019 at 8:15 AM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    What do you plan on doing?
    Wixo and Skydvrr like this.
  6. Oct 29, 2019 at 9:20 AM
    Jonacevedo2012
    Jonathan acevedo
    Ov tune
    Just wanted to replace the bushings to moog and the links as well
    Wixo and stun gun like this.
  7. Oct 29, 2019 at 9:24 AM
    Mojlnir
    Mojlnir Well-Known Member
    Parker, CO
    2018 SR ACLB Utility Pkg
    Wait....you guys have sway bars? There's nothing on my SR.
    :eek:
    Wixo, tonered and stun gun like this.
  8. Oct 29, 2019 at 9:29 AM
    stun gun
    Aaronski
    Tacomas.
    Same
    tonered and Mojlnir[QUOTED] like this.
  9. Oct 29, 2019 at 9:49 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Wow. That is honestly surprising, esp for the heat that I get when I mention the SBD is perfect on my Sport.
    I would guess (a total SWAG) that your iron block (head also?) is probably close to the weight of the all aluminum 3.5l?
    stun gun[QUOTED] likes this.
  10. Oct 29, 2019 at 10:04 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    if you are an OR with the smaller 28mm diameter, energy suspension has some "universal" greasable bushings that work like a charm part number 9.5163
    No way your truck rolled out of the factory without a swaybar up front.
  11. Oct 29, 2019 at 10:52 AM
    stun gun
    Aaronski
    Tacomas.
    What basis do you receive heat lol? Because it’s a sport?
    aluminum head, iron block. Doesn’t matter, because the sway isn’t even negligible, I don’t even feel a difference, but I do feel a massive difference off road. True independence. Feels very stable and safe, and anything I can’t manage on my own, VSC ideally would step in and modulate the brake to straighten out the truck in the event of some weirdness.
  12. Oct 29, 2019 at 10:55 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Always because of the Sport. That's a given.
    The real heat comes from the SBD though. Just unsafe as it is said. IMHO, the SBD on my Sport feels like a stock OR but without the brake dive. At any rate, I like it and try to softly suggest it when folks say that they hate hitting bumps in the Sport.
  13. Oct 29, 2019 at 10:58 AM
    stun gun
    Aaronski
    Tacomas.
    It’s just people knee jerking. They’ll do it in this thread too. Anything that will roll a Tacoma SBD, will roll a Tacoma with one.
    tonered[QUOTED] likes this.
  14. Oct 29, 2019 at 11:02 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    True on all accounts.
  15. Oct 29, 2019 at 11:09 AM
    Brofessor
    Brofessor Well-Known Member
    Been meaning to try a BMRAIFSD, keep forgetting to do
    tonered likes this.
  16. Oct 29, 2019 at 11:24 AM
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    2019 TRD OR DCLB (Sold), Honda Civic TRD PRO
    ACRONYMS!
    tonered likes this.
  17. Oct 29, 2019 at 11:24 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The Sport is said to have 700lb springs (650lb on the ORs?). Combine that with the stiff SB and life is uncomfortable on an off road.
    Do you find yourself getting pitched side to said on uneven bumps? If so, the SBD does help. I have no idea about the Pro spring rates though. The roll might be too big on road?
  18. Oct 29, 2019 at 12:22 PM
    Brofessor
    BMRAIFSD (Big metal rod, across independent front suspension, delete)
    come on, man!
    im on AMSP
    stun gun and tonered[QUOTED] like this.
  19. Oct 29, 2019 at 12:24 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    stun gun and Bertw192 like this.
  20. Oct 29, 2019 at 12:26 PM
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    it was so obvious, how did I miss it, hahaha
    Surferzac, stun gun and tonered like this.
