Sway Bars
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NumNutz, Aug 22, 2010.
  1. Aug 12, 2013 at 10:21 PM
    #41
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    Can you send a link to the XII and Tundra Racing pages?
  2. Aug 12, 2013 at 10:33 PM
    #42
    hirod
    hirod Well-Known Member
    hawaii
    16 double cab short bed OR
    Xiiperformance.com
    Tundraracing.com
  3. Aug 13, 2013 at 7:07 AM
    #43
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    What is the cost difference between the two?
  4. Aug 13, 2013 at 9:45 AM
    #44
    hirod
    hawaii
    $220 for the XII sway bar (but you need to find the components to mount it.)
    $300 for the tundra racing kit
    $200 for the hell wig kit.
    You need to find parts to mount the XII sway bar. Its a sway bar with the bushings. Need axle mounts, end links, end link mounts, and hardware. Tundra sells their kit minus the sway bar but I forget how much.
  5. Aug 13, 2013 at 10:15 AM
    #45
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Thanks for the info, it would be hard for me to justify anything beyond the Hellwig for my needs.
  6. Aug 13, 2013 at 10:25 AM
    #46
    hirod
    hawaii
    Np. The hellwig is way better than stock. If I were to go back that route I'd try getting ahold of some poly bushings. I'd leave the frame side of the end links rubber and switch out the mounts and sway bar side bushings with poly. You can see how soft the rubber is when you jack up one side of the truck.
    Btw, I don't tow or off road so I have no idea how this would work for other people.
  7. Aug 13, 2013 at 10:32 AM
    #47
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Why leave the frame side rubber with the inner side poly? Seems like that would cause some "inconsistent" compression...
  8. Aug 13, 2013 at 10:44 AM
    #48
    hirod
    hawaii
    Are you referring to the hellwig rear sway bar? If so, I noticed the upper set of bushings (frame side) didn't really distort at all when I jacked up the truck. The bottom ones attached to the sway bar looked like gummy candy. Made me think the same thing happens on a lesser scale while driving. Prob cause the sway bar moves a lot more than the end link. Figured nothing wrong with the upper ones being rubber so if I put the hellwig back on, I'd leave em like that til I found out otherwise.
  9. Aug 13, 2013 at 5:35 PM
    #49
    2wheelnut
    2wheelnut Well-Known Member
    Angelo
    Vallejo, CA
    '11 S/C K.I.S.S. "Factory Enhanced" DC TRD OR
    TRD Supercharger, TRD First Gen CAI, TRD FJ Alloy, Toyo OC A/T II 265/75/16, 5100's Front and Rear, OME 885x with 1/4 taco lean spacer, Toytec AAL 1.5" non TSB. TSB not done. WheatherTech Side Window Deflector, Satoshi Grill, T Rex Eyelids, Matt123 Skid Black stamped, Modded Maglite with Maglite mod for driver seat, Bed extender. Full debadging
    Well, I'm convinced, after reading this thread I want a front and rear set. Driving home from a mountain road with my current set up was fun, but I had to be ginger with the steering.
    My question is, I wheel often, not overly technical but I do venture off to the beaten path. Would it be better to use sways or somehow get the X-brace from the x-runner on instead.
  10. Aug 13, 2013 at 5:43 PM
    #50
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Here's my recent Hellwig rear sway bar installed. It's night and day difference on how the truck handles. One of the best thing I ever bought for the truck. Front sway bar from Hellwig is next :thumbsup:
  11. Aug 22, 2013 at 12:03 AM
    #51
    hirod
    hawaii
    Don't think I mentioned this. The front hell wig sway bar comes with what appears to be poly bushings so no need to buy energy ones. Plus, its a lot wider than the energy ones. Was messing with my front end with spindle spacers and adjustable control arms. Even chopped my factory bump stops to give me a little more room before bottoming out. Well, had the wheels off and noticed a couple scratches on the bar near where the wheel would go when turning. Don't know if its a current problem, occurred while installing parts, or during the period where I was adding and adjusting components. For the record, my front end is far from stock. But, I'm going to plastidip over those areas and check it once in a while to see if it occurs again. Don't know if it would happen on as stock truck but please keep an eye on it. The more I drive, the more I think I couldn't live without it.
  12. Aug 22, 2013 at 7:24 AM
    #52
    StanBo
    StanBo Well-Known Member
    Stan
    Central NJ
    10 DCLB - 98 XJ 93 RX7
    Shoot so now I have to add the front to my plans.
  13. Aug 22, 2013 at 7:51 AM
    #53
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    sway bar if you tow and haul loads in the bed and disconnect if going off road...
    as soon as I put the sway bar on, immediate total control, especially helpful when towing, really stabilizes the rear end, HUGE...
  14. Dec 21, 2019 at 2:33 PM
    #54
    Camby
    Camby Well-Known Member
    Brian
    Denver
    2006 Tacoma TRD Off-Road
    Magnuson Supercharger TRD CAI Catch Can After market dual exhaust Heated Mirror Kit Install Aftermarket Head and Tail lights Several accessory Mods
    Anybody reckon quick disconnects can be done for the rear sway bar? Connected when normal driving, quick disconnect when looking to off road?
