SwayAway coilover lift kit... anyone?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jrloTACO, Apr 6, 2009.
  1. Apr 6, 2009 at 9:29 PM
    jrloTACO
    jrloTACO [OP] Member
    hi, i'm a noob looking to do a 2.5" - 3" lift on my '09 DC Taco TRD Sport 4x4. I've been looking at Toytec, Skyjacker, and recently a shop recommended SwayAway.
    I searched the forum, but only one thread popped up with not much info, but does anyone here have any opinions or experience with the SwayAway lift kits?
    thanks,
    jason
  2. Apr 6, 2009 at 9:49 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    Sway A Ways (or SAWs) are fantastic coilovers
    Mine ride GREAT
    scottalot likes this.
  3. Apr 6, 2009 at 9:59 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    x2, for the money they are great.
  4. Apr 6, 2009 at 10:35 PM
    P. Bauer
    P. Bauer Well-Known Member
    San Jose
    08 Tacoma 4x4 TRD Off-Road
    TRD S/C :: Intake Camburg SwayAway Magnaflow American Racing Donahoe Racing Wheelers OffRoad
    I've had -2- sets of Sway-A-Way/Camburg coilovers, the 2.5s both times (2002 Tacoma/2006 Tacoma). They are really well built, they perform great on the street and awesome offroad as well.
  5. Apr 6, 2009 at 10:39 PM
    jrloTACO
    great, thanks guys! i think my mind is made up then. SAWs it is... now i've just got to wait a week for the parts to come in. :)
    one other noob question... if i run a 3" lift, will i need a diff drop kit, or am i ok without it?
  6. Apr 6, 2009 at 10:43 PM
    jrloTACO
    wow, sweet truck. so you're running 2.5 inches up front? what about the rear? blocks? AALs?
    the shop i'm working with is recommending i go with the coilovers at 2.5" up front, and blocks in the rear, but only if it's needed.
    thoughts?
  7. Apr 6, 2009 at 10:44 PM
    P. Bauer
    San Jose
    When I initially installed the kit, I ran just the front coilovers, rear AAL and 1" block with Donahoe remote reservoir shocks. It ran fine, alignment was OK, not perfect.
    Since then, I have added the Camburg Upper Control Arms, Diff Drop Kit, and Driveshaft spacer kit. Runs smooth, better than stock on/off-road, and alignment is perfect.
  8. Apr 6, 2009 at 10:46 PM
    P. Bauer
    San Jose
    Actually, Sway-A-Way makes two coilovers (or used to), the 2.0 and 2.5s. The 2.5s ran a larger diameter shaft on the shock and a heavier duty spring. I am running at about 3" of lift front/rear. Rear is AAL, 1" aluminum block, Donahoe(IKON) remote reservoir shocks. Also installed f/r braided lines that were longer to accomodate the lift.
  9. Apr 7, 2009 at 8:45 AM
    PNWIW
    PNWIW Member
    western, WA
    07 TRD Off Road
    1" lift in rear, All pro coil overs in front.
    I bought SAW 2.5's. After about 150 miles, I noticed a knock in the right front when going over bumps in the road. Turns out the seal went bad.
  10. Apr 7, 2009 at 9:22 AM
    P. Bauer
    San Jose
    Even on $5K Ohlins suspension kits, seals go bad, shocks prematurely leak. The one thing not mentioned is the AWESOME customer service of Sway-A-Way. They rebuilt my coilovers for free and did it in 1 day due to an error by the supplier of the internal stops.
    I'd purchase them again, no questions asked.
  11. Apr 7, 2009 at 10:51 AM
    Rippin101
    Rippin101 Well-Known Member
    Jax Beach, FL
    2014 TRD Sport 4x4
    -Nitto G2 265/70/17 -Level 8 MK6 Wheels -Katzkin Leather Black on Black -BHLM -Weathertech -Extang Solid Fold -Bedlight LEDs -TRD Skid
    Yep! Great product!
  12. Apr 7, 2009 at 10:54 AM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    get them. plus when you get them they will be brand spankin new! i ordered mine over a month ago and have been on back ordered but there just waiting to be plated
  13. Apr 7, 2009 at 7:23 PM
    jrloTACO
    you've been waiting over a month? i just ordered mine through a local shop yesterday. they'll be here on monday. :D
  14. Apr 7, 2009 at 7:24 PM
    jrloTACO
    P. Bauer, what tonneau cover are you running? me likey. :)
  15. Apr 7, 2009 at 7:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Actually, The 2.5's run the same size shock shaft, but have a larger shock body for more oil capacity. The springs can be ordered 650#, or 675#. :)
  16. Apr 7, 2009 at 7:33 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
    does saw even make a 2.0 for the new tacomas?
  17. Apr 7, 2009 at 7:36 PM
    tacoskim
    Los Angeles, CA
    Stock
    yea they do
    to the OP thats great news!! that means mine should be on its way soon
  18. Apr 7, 2009 at 11:10 PM
    P. Bauer
    San Jose
    UnderCover from AutoAnything. Very easy to install/remove, nice hardware, still use factory bed rails, LED light included, tailgate seal too!
    Free shipping from AutoAnything.
  19. Apr 8, 2009 at 12:37 AM
    tacomajason
    tacomajason the anti mpg
    Arkansas
    09 ssm ac oc 6mt 4wd
    stock (for now)
    unless you plan on changing cv boots every 10k, then yes, get a diff drop. they are way cheap, and very easy to install...
  20. Apr 13, 2009 at 10:36 AM
    tacoskim
    Los Angeles, CA
    Stock
    so did your shocks come in??? cuz just talked to someone from there and their still waiting on a piece for the kits... still on back order :mad:
