SwayAway gurus: coil question
Discussion in 'Suspension' started by nvdeserted, Oct 28, 2010.
  1. Oct 28, 2010 at 2:12 PM
    nvdeserted
    nvdeserted [OP] Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    I'm looking into a new bumper and winch right now, I fear that I will have to crank my SAWs down even more to accomodate the weight, and it might preload the spring too much and make for a crap ride. I have the SAW 2.0s, Race runner.
    What I want to do is just figure out the weight and get the appropriate Eibach (or any brand) coil-spring.
    Would I be better off getting a higher rated spring at the same length as the current spring, OR get the appropriate rate spring at the +2" lift so I can have the adjustment collar at the top, instead of cranked 1/2 way down.
    Would there be much benefit to having a longer spring as opposed to a shorter spring if the weight load was the same?
    I would rather have a longer spring= less threads showing for asthetics, but is there any pro/con?
    Thanks in advance
  2. Oct 30, 2010 at 10:14 AM
    nvdeserted
    Reno, NV
    c'mon nobody? bump
  3. Oct 30, 2010 at 8:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The more you pre load a spring, the closer the coils move to each other, and can reduce travel. Your better off getting a heavier spring rate. You can find the spring rate you have now, as it should be printed on one of the coils. It may be a 10 didgit number, but if you can post it up, I can tell what you would need.
  4. Oct 31, 2010 at 1:06 PM
    nvdeserted
    Reno, NV
    OK. So the SAWs are adjustable, I can just screw the to adjusting nut up or down to lower or increase the height of the front. If I lift the front, via the adjustment nut/collar, at some point I will be able to create enough preload to acommodate the extra weight of a bumper/winch. The spring currently on there will work.
    ...But I'd rather get a longer coil with a higher rate so that I can have the adjusting nut/collar all the way at the top but still achieve 2-3" of lift, and not cause binding and shortening of the coil as Chris mentioned.
    I know I could just get the same length spring with a higher load rate for the bumper/winch; I know how to figure out spring loads and preloading, etc, but I figure I might as well get a longer one too for ride quality and looks; I don't like the look of having the collar cranked 1/2 way down.
    Look in the picture below: I'd like to have the same amount of lift but have the coil go all the way to the top of the threads; not have 3" of threads showing. I think that having a longer spring would make for a better ride than a shorter spring..?
  5. Oct 31, 2010 at 1:19 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    Damn you have that cranked half way down the shock. I would get a heavier spring
  6. Oct 31, 2010 at 1:49 PM
    nvdeserted
    Reno, NV
    Ha!, They aren't that bad now, that's a picture from when I first put them on, I've lowered it over 1" since that picture (it was just a good reference for my question).
    And actually they work great and ride great as they are now; I spent a good chunk of time fine tuning them. But once I get the extra weight up front I don't think they'll handle it well.
    I'm also a bit concerned about how a higher rate spring will work with the current valving of the shock... I guess I can worry about that later tho.
  7. Oct 31, 2010 at 1:55 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    I replace the stock springs on my saw 2.0s with eibach in the equivalent. They are 650lb spring. I think they are 14" long.
    It rides much better then before and handles the bumps much better. Mind you this is with stock bumper.
  8. Oct 31, 2010 at 2:18 PM
    cummins6speed
    You could always go with a longer spring of the same rate if you like the current spring rate
  9. Oct 31, 2010 at 6:21 PM
    snorola
    snorola Well-Known Member
    Brett
    Canmore Alberta
    06 4x4 Dbl Cab
    SAW 2.0 Coilovers Eibach 14" 650lb springs Camburg UCA's All pro expo springs OME rear shocks All pro front bumper All pro IFS skid All pro sliders SCS f5 matt black rims Lightforce blitz 240's
    mine are exactly the same.
    I have about 3" of thread showing which gives me around 2.5" or so lift
  10. Oct 31, 2010 at 6:39 PM
    S.B.
    Sean
    San Diego
    15 Taco
    FYI: the stock coils the come with saws SUCK. I replaced mine with Eibach in the same size and rate and had to back off on the driver's side (couldn't on passenger side) and got a little more lift and a LOT better ride.
  11. Oct 31, 2010 at 6:41 PM
    cummins6speed
    Did your SAW's not come with eibach coils?
  12. Nov 1, 2010 at 11:11 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    For what its worth, I have the newer SAW 2.0s that came with Eibach 650#, silver colored coils. They've been on the truck since last May. About a month ago I installed a Relentless Fab plate bumper and a Smittybilt XRC8 winch. The winch and bumper weighed in a 160#, a net gain of 130# over stock.
    I can feel the added weight just a bit, seemed to have smoothed out the ride a little. I was expecting to see some sag from the added weight and have been checking for it but so far there is zero settling. No change in ride height so far.
  13. Nov 1, 2010 at 4:01 PM
    nvdeserted
    Reno, NV
    Ok, so I think I've gone and overthunk this.
    The current spring on there is a SAW 2.5x13 650lb with stock bumper.
    A little math: right now the 13" spring sits at 10" under current weight; also cranked down 2.5 inches for lift.
    So(?) if I got a 690lb spring (at the same length), for example, the spring wouldn't be compressed as much to achieve the same height (less turns down on the collar).
    So this means that basically I have 2 options: 1. Same length spring at a heigher weight-rate, or 2. Same rate spring at a longer length.
    Either of those will equal same lift but collar at top, not cranked down 2.5". Si?
  14. Nov 1, 2010 at 4:03 PM
    S.B.
    Sean
    San Diego
    15 Taco
    No I got them used. They were 2 years old last January.
  15. Nov 1, 2010 at 4:04 PM
    S.B.
    Sean
    San Diego
    15 Taco
    Just go with the higher spring rate. When I get my front setup (bumper and winch), I know I will not need any different springs, because these eibachs will handle it unlike the stock SAW coils (red).
  16. Nov 1, 2010 at 4:12 PM
    nvdeserted
    Reno, NV
    Another interesting tidbit, at some point, SAW ditched the 13" red coils like I have (at 650) and now they use a 14" silver coil (at 650); this allows a bit more spring travel and less cranking on the collar.
  17. Nov 1, 2010 at 4:15 PM
    nvdeserted
    Reno, NV
    The fellow at SAW said basically that too. Upgrade to the silver (Eibach) springs, same rate at 650 but 1" longer.
    Thanks
  18. Nov 1, 2010 at 4:16 PM
    S.B.
    Sean
    San Diego
    15 Taco
    And because their coils sucked and sagged like crazy so they went with a trusted/proven brand.
  19. Nov 1, 2010 at 4:17 PM
    S.B.
    Sean
    San Diego
    15 Taco
    About 6 or so months ago I called them and thats what they told me, was to get the eibachs.
  20. Nov 1, 2010 at 4:41 PM
    snorola
    Brett
    Canmore Alberta
    06 4x4 Dbl Cab
    any idea on the cost for these?
