SwayAway RaceRunner 2.0 Coilovers - Extended Travel 95-04 Tacoma
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by capturecolorado, Aug 23, 2016.
  1. Aug 23, 2016 at 6:58 AM
    capturecolorado
    capturecolorado [OP] Well-Known Member
    Alex
    Grand Junction, CO
    01 4Runner SR5 with some things attached
    Sold!
    Dcsleeper408 and FirstGen Jer like this.
  2. Aug 23, 2016 at 7:06 AM
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    Good deal you've got, Alex. What did you replace then with??
  3. Aug 23, 2016 at 7:06 AM
    capturecolorado
    Alex
    Grand Junction, CO
    :spy: something big, silver & black...
  4. Aug 23, 2016 at 7:12 AM
    RigginsTaco
    RigginsTaco Well-Known Member
    Andreas
    Boring taco with mods
    Stuff...
    How long did you ride on the 500lb springs
  5. Aug 23, 2016 at 7:13 AM
    capturecolorado
    Alex
    Grand Junction, CO
    To be honest I don't recall when it was that I installed them, I want to say they've been on the truck for 4-5 months now.
  6. Aug 23, 2016 at 7:15 AM
    capturecolorado
    Alex
    Grand Junction, CO
    Looked back, installed them mid-March.
    And cycled the suspension without the spring on. #becauseracetruck
  7. Aug 23, 2016 at 10:15 AM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    ADS??
  8. Aug 23, 2016 at 11:56 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Do you know the dimensions of the springs? or part number? I'm looking into getting some lighter springs for my SAWs but they are the standard travel.
  9. Aug 23, 2016 at 12:11 PM
    Moosedog
    Moosedog Well-Known Member
    Bryan
    Harrisburg, Or
    99 tacoma SR5 TRD v6
    kings, dakars, relentless front bumper, NWTI rear bumper
    How much to ship to 45044?
  10. Aug 23, 2016 at 12:17 PM
    Taco Addiction
    Taco Addiction We found Jimmy
    Houston, TX
    2004 Black TRD Offroad
    Kings, SCS Wheels and other mall crawling crap
  11. Aug 23, 2016 at 4:33 PM
    shootmymime
    shootmymime Well-Known Member
    Idaho
    00 4Runner
    What is the measurable length of exposed shaft? or shocks travel on these?
  12. Aug 23, 2016 at 7:07 PM
    capturecolorado
    Alex
    Grand Junction, CO
    I'm going to get some pictures here shortly, and rather than emailing them to everyone, I'm just going to post them here, so keep your eyes out, folks.
    Icon :bananadance:
    Here's a link to the coils I ordered (500lb). I'm not sure if 14" springs would work on the standard travel, I have the feeling they won't, but I'm not the expert... Maybe give Low Range a shout? Their customer service has been pretty solid for me so far.
    Shipping for most of the country is working out to be:
    Coilovers: $35
    Extra coils: $30
    Responded.
    Uh... Hold tight, I've got to go grab them. I don't believe the exposed shaft on these really equals available travel when installed on the truck (unless all the bump stops are removed and you somehow manage super-compression).
  13. Aug 23, 2016 at 7:47 PM
    capturecolorado
    Alex
    Grand Junction, CO
    Pics & specs:
    Eye-to-eye length: 19.75"
    Top cap thingy to center of lower eyelet: 20.125"
    Visible shaft: 5.75"
    Available *actual* travel: maybe 5.5"? Not really sure.
    Condition:
    Functionally excellent. Zero corrosion or damage to the shock shaft.
    Some surface corrosion on the damper body/main body thing--merely cosmetic.
    One side had the set screw strip when I was replacing the coils, I retapped it, but then discovered that M10 set screws are not readily available, I replaced it with an M10 socket cap bolt. It ain't pretty, but it keeps things in place.
    One has a little bit more fading in the anodizing, so it's less red.
  14. Aug 24, 2016 at 5:00 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Any more info on the Bilstein shocks?
  15. Aug 24, 2016 at 6:11 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    The pictures aren't showing up. Or at least I can't open them
  16. Aug 24, 2016 at 6:42 AM
    capturecolorado
    Alex
    Grand Junction, CO
    I put them on about 8,000 miles ago, so not very old. I try to keep them clean around the seal and on the shaft regularly. To clarify, they're non-reservoir models... Emulsion style. I bought them through AllPro for $100 a pop, looking to get $100 + shipping.
    I'm planning on pulling them off the truck today, so I'll have better pictures when that happens.
  17. Aug 24, 2016 at 7:01 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Gotcha, wouldn't have any problems mounting them on basically stock mounts with timbren bumps would I? I don't think I'd be bottoming them out
  18. Aug 24, 2016 at 7:10 AM
    capturecolorado
    Alex
    Grand Junction, CO
    I don't think you'd have any problems, when I did the shock mounts I kept their locations pretty similar to the same, so I would guess you wouldn't have a problem fitting them. IIRC they sit about 50-60% into their travel, I'd guess you'll be fine. I think when Boxrocket did his shock relocation he used his original OME shocks which were ~9.5-10" travel.
    I used different bushings than stock, I swapped the bushings around to work with 1/2" bolts.
  19. Aug 24, 2016 at 7:14 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I'll take a peek through you're build and check.
    Well pending pics I think I'll take them. Any chance they could fit in a suitcase? I'll be in Colorado Springs next weekend :rofl:
  20. Aug 24, 2016 at 7:16 AM
    capturecolorado
    Alex
    Grand Junction, CO
    According to the specs they're just shy of 26" long... so maybe! I'll shoot you some pics when I yank 'em out.
    BYJOSHCOOK[QUOTED] likes this.
