SwayAway RaceRunner Coilover Questions
Discussion in '1st Gen. Builds (1995-2004)' started by Digiratus, Mar 31, 2010.
  1. Mar 31, 2010 at 8:35 PM
    Digiratus
    Digiratus [OP] Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I have several questions about the SAWs. Forgive me if all these questions have been asked before. I did some searching but didn't see anything specific to my questions.
    I just received a set of SAW 2.0 Coilovers from NWOR and noticed that the springs appear to be different from what I've seen pictured at other places online (Wheelers for example). Does anyone know if they have always come with Eibach coils? I've always seen red coils but as you can see from the pics these are not red. One of the part codes printed on the coils would appear to indicate they are 650 lb coils, is that standard for the SAWs?
    From looking at the pics, can anyone estimate how much lift they are set for. It would appear that there is a lot more height adjustment that can be dialed in.
    I am also curious about the offset of the bushing at the bottom. Does the part that sticks out face towards the front of the truck?
  2. Apr 7, 2010 at 11:15 PM
    kumaWRX
    kumaWRX Well-Known Member
    Jase
    Oahu, Hawaii
    2004 TRD Offroad PreRunner 3.4L V6
    SAW 2.0 Coilovers, Wheeler's 3-leaf AAL, Toytec 1" lift shackles, Bilstein 5100 rear shocks, aFE Stg. 2 intake, Doug Thorley headers, Magnaflow muffler, 16x8 ProComp 7089 wheels, Toyo Open Country A/T tires, Pamalu bedliner, Bakflip G2 bedcover
    I installed my SAW 2.0s not too long ago and my Eibach springs were silver also, was kind of bummed but it still looks nice. I think Eibach stopped making red springs. Mine are 650lb springs which is normal and coilovers are stamped with 11/09 so I know they are fresh (received hem in December 09).
    DO NOT ADJUST THEM YET!!! I made that mistake, I adjusting both about 1.25 inches up before I put them on and my front was lifted about 4 inches! I would try put them in like that first then adjust them. They are a bitch and a half to adjust though.
    As for the lower bushings, mine didn't matter because I'm 2wd but if yours is 4x4 I think the longer bushing goes rearward, I did that just in case. Mine came with instructions. Lmk if you have more ?s.
  3. Apr 8, 2010 at 12:32 AM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    The 650lb springs are the standard on SAW's. About the red/silver, I wanted silver but got red, someone told me it's kind of a crap shoot, some batches are painted red and some silver.
    As for the lift preset I think mine were set with 2.5" of thread showing and it equaled about 2" lift on the truck (3" of thread showing on drivers side to even out the lean). Make sure that when you install them first rotate the adjusting collar so that the allen lock screw is facing outwards so you can loosen it. And as you adjust the collar up/down make sure the screw always ends up where you can get to it. They are a bitch to adjust, just a heads up. The ratio is 2:1 so to lift 1" you'll need to tighten down 2"s of thread. Make sure to take the weight off the wheel you are adjusting, jack up the truck and get that wheel off the ground with no compression, that will make it easier.
    As for the offset bushing, I called SAW and they said the long end goes toward the front. I thought I got 2 left shocks but you can easily pry the bushings out if you need to swap sides. It might be reversed on first gens but I highly doubt it.
  4. Apr 8, 2010 at 9:07 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Thanks. That sounds very much like what I got.
    Lol! I found out the hard way too. I cranked them down a bit after installing but before putting the wheels back on and putting it on the ground. Oopps! too much lift! :eek: With 1.5" of thread exposed above the adjuster the truck sat 3+" higher. mine is a 4x4 and the CV angles were way too much.
    I've since taken out most of what I added. One side is back down to 1" of thread above the adjuster, the other side is about an 1.125". Its level now, vibrations are gone and near as I can estimate I ended up with about 2.5" higher in front. I'm going to put in the 1" diff drop kit this weekend to see how that helps the CV angles.
  5. Apr 8, 2010 at 9:21 AM
    Its_Taco_Time
    Its_Taco_Time Well-Known Member
    Yorba Linda
    07 Tunda DC TRD Offroad
    CST spindles, Magnaflow, TRD intake
    The silver springs are the newer setup. SAW was having problems with sagging on the red springs, so they switched it up to silver, no it is not just a paint job haha.
    Be happy you got silver.
  6. Apr 8, 2010 at 10:59 PM
    kumaWRX
    Jase
    Oahu, Hawaii
    Sweet, at first I was bummed but now I'm glad I got the silver springs.
