swaybar disconnect idea?
Discussion in 'Suspension' started by allian04, Jun 5, 2011.
  1. Jun 5, 2011 at 9:14 AM
    allian04
    allian04 [OP] Well-Known Member
    Folly beach, sc
    03 trd tacoma 4x4
    arb bull bar, B.A.M.F. rock sliders w/kickout, 265/75r16 Wild peak, 3" ome 881 coils, dakars 5150s, deck plate, snugtop, viair on-board air,Simpson 3 rtt
    I have a 2003 tacoma with bad endlinks on my sway bar so i was thinking of making some disconnects for it instead. my idea is to use two heim joints with a threaded rod and two clevis pins to connect the link to the sway bar and control arm.
  2. Jun 5, 2011 at 9:42 AM
    TanSR5x4
    TanSR5x4 Hold my beer and watch this
    William
    Houston TX
    00 Tacoma SR5 4x4
    Deckplate mod, black KC slimlight fogs, hurculined bed, NRA sticker mod, painted rear chrome bumper black, black fender flares and front grill surround, HIDs, All-pro rear leafs and UCAs, Eibach coilovers, billys all around, flat black pro comps, 31x10.5x15 BFG KM2s
    i think the problem with making quick disconnects for the 1st gens is that the sway bars will still be right there sittin on the LCAs and messing with the suspension right?
    you cant have those just dangling there
  3. Jun 5, 2011 at 9:46 AM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Looks like an awesome idea op I say go for it
    You would still have to disconnect the bar itself but disconnects could make the end link removal a bit faster
  4. Dec 20, 2011 at 8:30 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    OP: Did this go anywhere? How's it workin if so?
  5. Dec 21, 2011 at 11:21 AM
    lonzorizo
    lonzorizo Well-Known Member
    Lonnie
    Hoopa, Ca
    2003 TRD OR, 2016 TRD OR Tacoma
    When I take the end links off I just zip tie the bar itself up to the frame. I'm interested in a disconnect for the endlinks...so subd for further info.
  6. Dec 21, 2011 at 11:27 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Take a look at these.... I had a set like this on my 96.
  7. Dec 25, 2011 at 8:52 AM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    With ball ends at each end it is going to be pretty loud when they are attached.
    Personally I would go with rubber bushings at one end as pictured in the later post.
  8. Dec 25, 2011 at 8:57 AM
    jandrews
    '09 FourDubDee TRD OR
    Just take the thing off, throw it away, and get some higher-rate coilsprings for the front.
    You won't miss it, believe me.
